Does any one have any advice about the Norcold 3 way frig not working on battery. It works great when plugged in to regular AC power and works on propane, but nothing on battery. Also if we can figure out how to get it fixed, can we leave it on battery while driving. We go boondocking and we have solar to keep the battery charged once we get to a spot.
0 ·
b] Lots of threads with negative/positive experience on using 12VDC Fridge while driving. Suggest you do a few searches on this forum. Several different factors can impact your specific results using 12VDC setting. Note Fridge draws a steady 11Amps, there is no thermostat temperature control on DC power.
Adventures: 54 Nights: 341 Towing Miles 43,780
Make sure you have the fan turned on. That’s the switch above the frig with the blue light. When I ran it on 12v it drained the batteries. Even when hooked to the tow vehicle and with solar.
As @MuttonChops said, the 3-Way requires 11amps continuous, which is quite a draw from your battery, as well as from your solar panel.
For your boondocking, you'd be better off depending on propane for the fridge. It doesn't use much - there are a few discussions on the forum here where people advise how much it will consume for an extended trip.
Lots of posts about tricking your alternator by towing with headlights on which may result in it putting out a higher voltage.
San Diego, CA
www.airbossone.com
Thank you. Until recently, we pulled our t@b with first a 2017 Jeep Grand Cherokee Trailhawk and later a 2020 Jeep Grand Cherokee High Altitude. No issues what-so-ever with the Norcold. It wasn't until we started pulling with our 2020 Ford F-150 that the Norcold issues began.
2020 F150 3.5 ecoboost
Columbus, OH
Our practice or routine is once we head out on a trip, we turn the solar switch to the ON position and leave it. On our recent trip, we departed home and drove 5-hrs and parked for the night at a State Park. When we switched from DC to AC, everything was normal. The next morning when we disconnected AC and went to DC again no issues. We then drove for another 4 hours and parked, doing the DC to AC switch without issue. We stayed parked for four days and departed. We drove for 2-hrs and stopped to restock and saw our Norcold flashing the error 6. Fortunately, it was cold so we just turned the system off, kept the solar battery in the ON position and drove on to our next stop. Once there as a test, we went to DC and all was well so we went back to AC for our two day stop. On our departure morning, switched to DC and got the error code. The manual says the trailer has to be connected to the vehicle and the vehicle running. This wasn't something we did with our previous tow vehicles, so I'm wondering if there is an issue with our 7pin connect at the truck and trailer.
We love towing with our 2020 F-150 and it has the factory installed tow package. I have no idea why we are now having battery issues with our Norcold. As I mentioned above, on our second outing we stopped to restock and when we opened the trailer to stock the Norcold we saw the blink error #6. According to the manual, a #6 error deals with DC power being insufficient. I have a question for you; is there a sequence you use when you start? Meaning when our tow was the jeep, the last thing we would do after we've connected the trailer to the Jeep and we're ready to travel is switch the Norcold to DC power. For the trailer to see DC power from the 7-pin, Ford says the vehicle must be running, a trailer selected, and the driver's door closed. Thanks.
Columbus, OH
Leadville Colorado
Fuse #30 is a 25A for trailer tow battery charge. That fuse exists in mine from the factory. @Blueespy You may want to double check that it isn't blown.
Columbus, OH
Don't ask me how I know this!!
San Diego, CA
www.airbossone.com
Thank you. I do the same and did this sequence today and had no errors. First I checked the strength of the batteries and their showed full. I then connected the trailer to the F-150 (after cleaning and greasing the 7-pin). Inside, close the door, foot on the brake, start and the trailer was recognized. Lights on and my Furrion camera was working. Used my blinkers and confirmed the trailer lights/blinkers were working. Went inside, turned the Norcold on, the selected A (according to the manual, the Norcold will select the best power option or the one available). After a few seconds, it recognized the batteries, showed the battery icon on the digital screen and started working. Oh, before turning the Norcold on, I turned on the fan. Everything worked as it should but I have a friend who does Mobile RV repair and he's going to help me check the 7-pin as well as the Norcold control board Friday. I have not noticed any lost of charge in the batteries while I'm towing.
I have a Mobile RV repair guy meeting me Friday to do a check. I'm handy but for some reason I'm all thumbs trying to figure out how to use a multimeter. I know if you put the leads on the ground and positive (DC) you should get a reading of between 11-13. Regarding the solar switch. My mistake, it's the battery on/off switch located just inside and to the right of the passenger side storage compartment.
I use a spray and it does a very good job and dries quickly. I won't ask but yep, I could see myself doing that. Thanks for the heads up.
Thank you. One of the first things I did. I thought since I had the manual brake control installed at the time of purchase, perhaps they were in a hurry and forgot about the fuse. Nope, it was there.
If the TV isn't running and disconnecting the umbilical causes the T@B's battery level to switch from drained to fully charged then I'd be stumped.
I tow with the fridge running off propane...a topic more polarizing than politics!
2008 Toyota Sequoia 5.7 L
When you are hooked up to your running vehicle, the vehicle supplies 12V power to the camper via the pigtail. This provides enough juice to run your fridge and also make simple monitors show a "full" battery charge.
Once you turn off your tow vehicle, the power is cut and the T@B battery takes over the 12V power supply. If the battery is not sufficiently charged, the fridge won't run and the monitor will reflect the battery's weakened state.
So, what you describe points to an undercharged and perhaps faulty battery, except that last part about everything working fine when the tow vehicle is taken out of the equation.
A guess--and a weak one at that--is that something related to the pigtail circuits is shorting when the T/V is connected and causing a big drain on the battery.
We have the Norcold N3104. The Norcold is reading the trailer battery but it is definitely a false reading that is somehow triggered when I turn the TV off.
We plan to try propane on our next trip, however, I've never ran it on propane so the other day I connected the tank, bled the lines of air, then switched the Norcold to propane and got an error 3 code. The Norcold support line was less than helpful and the two numbers they gave me for local service are both out of business.
Believe Fault Code 3 is failure to ignite.
Usually this means (i) the electrode that ignites the LP is either bad or the gap between the electrode and the flame port is incorrect (s/b about 1/4" or 3/16" if I recall) or (ii) you're not getting LP to the flame port. Shut everything down (fridge and LP). Open LP tank slowly but fully. Have someone stand near the back of the fridge with the panel off and the little portal cover open so they can see the flame port, while you turn the fridge on and select LP. You should hear a click and they should see a spark. If there's a spark but no flame, it's probably an LP issue and one issue could be that the valve just upstream from the flame port is not open allowing LP to flow to the flame port. The LP lines have also been known to get air trapped in the line that prevents the gas from flowing to or from the valve but it sounds like you've bled the system (how?) already and presume you've fired up your stove so you know you have LP flow.
If there's no spark, it's likely the electrode itself or the power board.
You can access the electrode and flame port with a little effort and clean them up. It may help. At least you've eliminated one possible nit.
San Diego, CA
www.airbossone.com
