So, I measured the car and it’s 16 3/4” to the car measurement (A) and 15 3/4” when I asked Den to get in the back of our Ford Edge to make it heavier. NüCamp says to expect 16”(B) for the Boondock. I understand both of these measurements may fluctuate based on weight in the TV and/or the T@B so I think we want an adjustable. We won’t be towing anything but the T@B. Is this what I need? Is there anything I am missing? Thank you so much! My brain is exhausted from reading and learning for sure.
https://www.curtmfg.com/part/45812?fbclid=IwAR3olH-sQPDJ3Jvd5JWOK1EjdxU1guUS4z38nt6hLLoDIv2dyvxEPupt-Igand then do you recommend a stainless steel ball so it doesn’t rust? It’s about twice the price.
https://www.amazon.com/Curt-Manufacturing-40052-CURT-Trailer/dp/B0009T6EBG/ref=sr_1_1?s=automotive&ie=UTF8&qid=1549656937&sr=1-1&keywords=40052+curt&fbclid=IwAR21fxL75paA7-ThOqBa0vrLYtwefe-slqZ6mu1ifPVpAzKPF1CjHFAd_dAI am a a nervous wreck trying to get all of this in order. Our T@B is off the line, Austin finishes our mods today so it’s time for that last minute hustle.
0 ·
https://www.ford.com/cmslibs/content/dam/brand_ford/en_us/brand/resources/general/pdf/guides/18RV&TT_Ford_Edge_Oct9.pdf
If you need to go out with a yard stick and get an eyeball measurement, then best guess the amount of drop or rise you need to hit the recommended height, then go to autozone, or oreillys or advanced auto find the right receiver and ask them to let you put it on your vehicle for a more precise measurement. A simple try it before you buy it. I would buy it from them just because its the right thing to do.
I have the old cheap ball, who cares if it rust, I take it off the truck when I am not using it. Cost me 5 bucks 30 years ago and has successfully hauled countless toys. Not sure why you need that fancy receiver hitch? Again I have a non adjustable cheapo from the car parts store, probably 30 years old as well. you can get a two inch drop with a ball for $25 bucks at walmart.
I am a kiss sort of guy, keep it simple stupid. that drop hitch looks too complicated and expensive for what it is.
Sold 2023 Tab 400
Sold 2018 T@B 320S
Alan & Patty
Southern Az
I was sure I'd measured everything right and had the hitch, ball and everything ready...
Got to the dealer, and he showed me how wrong I had it! Well, wrong enough to matter, anyway.
Luckily, there was a NAPA parts store right down the road, still open. Ran down there, picked up one with the right drop, and it came with the ball...
Edit: come to think of it, it didn't come with the ball, but they were kind enough to bolt on the ball for me, with their tools.
Only a $35 lesson. Not too bad.
Might be best to wait to 'try it on', if you can. Is there a parts store near your dealer? Or has the dealer a selection of hitches?
You can also buy a U shaped clamp that can take out the rattle where the reciever slides into the reciever hitch on the tow vehicle.
jeannie
I understand your frustration, establishing an even ride level between tow vehicle and camper is not easy. Unfortunately, a simple B-A=C equation does not allow for variables like typical tv and camper loads and impact of tongue weight on rear suspension, etc. The collection of your T@b from the dealer may not be the best time to make a correct judgement. When I first purchased our T@b, I already had an adjustable ball mount, which I use for a couple of utility trailers I own. This allowed me to adjust and test for the perfect ride height. However, once I had determined the correct drop (8" for my Cherokee Trailhawk). I purchased the appropriate mount. I would not recommend long term/distance use of an adjustable mount for a camper since that adjustment mechanism introduces an additional element of mechanical play that can be very irritating and uncomfortable. My recommendation therefore is to purchase an adjustable mount (or ideally borrow!) from somewhere that will allow you to return/exchange it for the perfect permanent mount. It is well worth taking the trouble to get it right. Hope this is helpful. Good luck!
2018 T@B Outback
2016 Jeep JKU TV
2019 T@b 400 Boondock Lite
2018 Ram 1500 Quad Cab Hemi
Central Alabama
https://www.google.com/maps/place/Missouri+Teardrop+Trailers,+590+NW+Co+Rd+M,+Centerview,+MO+64019/@38.8536826,-93.8912836,3a,75y,267.64h,90t/data=!3m4!1e1!3m2!1san0UhyiBx4Mtr6P3MNOmjw!2e0!4m2!3m1!1s0x87c15cbb9245e8dd:0x2831b9374e8ae70?gl=us
2017 T@b 320 - 'Smokey' 2017 Toyota Tacoma TRD Sport - 'B@ndit'
Dave - Tuscaloosa, Al
2022 Ford F350 Tremor | 2022 Cirrus 620
https://www.amazon.com/dp/B00631GSSI/?coliid=ISCIZNC3C1DJJ&colid=2H27GEXG9Z6A9&psc=0&ref_=lv_ov_lig_dp_it
Central Alabama
Central Alabama
