Learned more about Alde, now need to know more about electrical. Will my T@B CS-S 2015 battery receive charge from my TV while I'm driving? Recently while I was parked for short while and the T@B was hooked up, my auto battery was drained. There was nothing on/using power while I was parked. Battery in Subie is 1yr old and recently tested. Battery in T@B is deep cycle ~4 yrs old and recently charged, but doesn't seem to hold or take a charge.
TV 2011 Sabaru Forester
0 ·
But highlights the point that everyone needs to understand how their rig is wired.
What is the best (easiest) way to determine if your 7-pin is actually charging the camper battery, and whether it is doing that only when the TV ignition is "on"? I was told that my 7-pin does charge the camper battery, and that it disconnects when the ignition on the TV is off (so as not to drain the TV battery), but I would like to independently confirm that. Thanks! (Greg)
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Sebastian
That said, I am currently testing the rate of discharge of our T@B's battery due to background electronics left running (not counting television which now has a power switch to turn off power supply), and it's not very much. After 5 days so far, here's our battery status:
It appears we are using 250 milliamps or 6AH per day. Surprisingly, we are still at 91% state of charge, I presume due to the Peukert effect. The "time remaining" is apparently not reliable, since it started at 10 days and is still there. It also appears we could last significantly longer than 10 days, but based on the Amp-hour usage, I'm not sure how accurate the SOC is either, unless that Peukert effect is really large at this slow discharge rate. Our battery is 150 AH.
Note that I have a single Battleborn 100 AH lithium battery, 200 watt lithium solar charger, and 30 amp lithium converter. The battery voltage w/o the Jeep connected was about 13.3 VDC and pretty much stayed at that voltage when the Jeep was connected.
Next, I checked the Jeep's DC voltage with the engine running (using the Jeep's built in display) and found that the alternator/battery voltage was only 12.7 VDC with the engine running. I confirmed the voltage with a digital meter.
So it appears that if my lithium battery is reasonably charged, the Jeep does not charge the T@B battery at all, and in-fact slightly discharges the T@B's battery when towing.
Based on this information, I made a wiring modification, adding a fuse between the T@B 7-way charge wire and the T@B battery. I left the fuse out, since the tow vehicle wasn't charging the T@B anyway. Should some situation arise where the T@B lithium battery voltage is very low (below 12.7 VDC, I can simply insert a fuse and then use the tow vehicle to charge the T@B battery.
I was a bit surprised to see such a low charge voltage from the Jeep, but maybe this is a new trend in automotive design. I don't think there is anything wrong with the Jeep since it starts and runs just fine.
So, I will rely on the solar and converter (lithium spec) to do all the T@B battery charging, and a Honda EU2200i generator (if I can ever buy one). I have always believed the charging a towable TV battery from the tow vehicle is a loosing proposition, but this experiment (with my setup) confirmed it for me.
Also, contrary to Awca12a, we installed a 10 gauge charge wire and ground wire and have had no problem recharging our TaB battery. Definitely more than a trickle charger.
@klenger forgive me if posted and I missed it, but did you replace the standard converter with one meant for charging lithium? I am also wondering if a minimum amp input is required to charge a lithium and if there is some sort of protection to keep the battery from being hurt by too low of a charge input?
Lastly, it never hurts to check the fuses in your TV.
PS:
Our TV charge line goes directly to the TV battery & is hot all the time. Before leaving our campground last fall, with engine idling & rooftop solar connected, our partially discharged T@B battery was receiving 6A from the car & 5A from solar - as I had shown at the bottom of this page..
http://tabforum.nucamprv.com/#/discussion/3847/what-battery-should-i-upgrade-to
I presume our TV battery was getting around 14+ volts from the alternator in order to be sending that much current, but no I had no measurements. Will have to look closer next time & look at higher RPMs. We may have been able to run our frig without propane, but never tried it.
Like sharon I upgraded my truck wiring to much heavier than standard and my alternator to a 250 amp, or somewhere thereabouts, to specifically charge the trailer batterys while traveling. Still trying to decide if a battery isolator is a good idea.....
I have already installed a contiuous duty relay that it tied to the vehicle ignition to turn the trailer circuit off with the key, But I still worry about a highly discharged battery sucking the TV battery dry even with my high amperage alternator.....probably me just being paranoid. But luck favors the prepared.
Regrading the breakaway switch wiring, I made sure that the brake system is powered from the T@B battery regardless of the tow vehicle charge wire connection.
For those interested in my (highly modified) wiring, goto http://www.klenger.net/wiring-diagrams.html and click on the "Owner Modified" wiring diagram button. The tow vehicle wiring is on sheet 1.
On a side note, I finally had a chance to boondock with this setup last weekend. Note that I have a 150 watt sine wave inverter and have switched out the TV to a 120 VAC model from Best Buy (works great). Running the inverter, TV, one or more lights, and the Alde (at night), total battery draw was around 3+ amps. By the next morning, my battery capacity was down to around 80% and the 200 watt solar charged the battery back to 100% by 11:00 AM and kept the battery at 100% till the sunset. I am very impressed with the efficiency of the systems in the T@B. On previous full size RVs I've had, the same loads would draw 10-25 amps DC.
I also looked at the battery isolation device linked above. From my brief review, it appears that you would need to install the device in the tow vehicle's electrical system to fully benefit from its design. It appears that the intended use is for motor homes that have split electrical systems for chassis and coach power. It may still help if installed inline inline with the tow vehicle charge wire in the T@B wiring but don't know enough about it to know in advance. I do believe that a simple diode would not help much because the 0.6 VDC drop would render the tow vehicle charge voltage ineffective.
Hope I'm not hijacking this thread too much.
