I had just filled the fresh water tank today with bleach solution and was priming the lines. After the air was expelled & water flowed from sink faucet, shower & toilet, I noticed the pump didn't stop, but ran with brief pauses every second or so. I turned it off, then checked everywhere I could for leaks & found none. No leaks on pipes going into & out of the pump that I could reach. Using a mirror & flashlight, the floor below the pump area looked dry. No leaks in valve area or inside cabinets under sink.
Outside in the front I noticed water dripping at multiple points all along the seam below/rear of the diamond plate from the plastic covering forward of the frame. That plastic all across the front edge underneath is like a water balloon - I can press on it & feel water sloshing around under it along what I think is the wood beam that goes across the front edge of the floor. When I turned the pump back on, it dripped faster. After sitting 30 minutes, no more dripping, but water still sitting inside the black plastic underneath, mostly towards the center.
Tank is still about 65% full, & I'm not sure what to do next. I'm guessing there is a leak in the water supply line near the fresh water tank. Going to let the bleach solution sit for a couple hours & then drain the tank unless I hear a reason not to. I'm wondering if I should punch a hole somewhere in the plastic, so it can drain out.
Also, is there any way to get to the fresh water line near the tank to check for leaks, or is this going to require professional help?
0 ·
Though I don't see how that would keep the pump from reaching full pressure, as it doesn't stop on its own.
Not sure thatbis very helpful, but that is my line of thinking
https://tab-rv.vanillacommunity.com/discussion/comment/108758#Comment_108758
I was able to see & feel the gravity fill hose below the pump & it feels dry & intact. Repeat, floor looks dry in that compartment behind the toilet, but I can't really see clearly into the front corner next to the kitchen wall where there's a lot of stuff & can't reach there to feel.
@ScottG The plastic I described is not the heavy corrugated stuff under the frame, but the thin sheet covering the front underside edge of the floor between bottom of diamond plate & the cross frame of the A frame.
I am thinking I should punch a hole in that plastic to drain the water so that wooden crossmember doesn't sit in water indefinitely.
I am also rethinking what I said earlier about suspecting the supply line between tank & pump. I only said that because of the location of the water & the fact that I didn't see any in the bottom of the compartment behind the toilet. If that were the case, could a leak before the pump where water is being sucked up the tube cause the pump to keep running? I'm now thinking that should only happen if the pump cannot maintain pressure on the output side; so could a leak on the input side cause a drop in output pressure. I would not have thought so in a closed system on the output side.
Also, I forgot to mention that I overflowed the water tank when filling it up, so wondering if there is a connection. But again, there's the issue of the pump not turning off.
By the way, the water that was pooled inside the plastic liner has either found it's way out or has been soaked up by that wood beam.
I am going to try two other troubleshooting methods. First, I remembered I have a small Samsung 360 degree camera (or two 180's) that I can put on a selfie stick & monitor from my phone. I started to explore the cavity behind the toilet more closely with it, but the battery died, so recharging now. I did manage to get these two shots..
The second shot shows what looks like some water drops on the front panel at lower right, which could be coming from a number of places I suppose, including all those connections in both photos or even the waterline below these that goes to the back (not shown). They are spread out, so that would seem to indicate a spray, but possibly a splash.
The other tool I want to try is a suggestion Dale Helman made to someone with a similar problem, which is to pressurize the system with air as done for winterizing, and then listen & feel for air leaks.
More later if I find something.
1) turn pump on and use Samsung camera-phone to look for spray real time - or sequential pictures.
2) use a flexible grabber pickup tool ( https://www.amazon.com/RAM-PRO-Flexible-Grabber-Retractable-Retriever/dp/B01LM2L50I/ref=sr_1_4?keywords=RAM-PRO-Flexible-Grabber-Retractable-Retriever&qid=1553991291&s=gateway&sr=8-4 ) with a cotton ball or Q-tip to touch suspected leak points and see if it soaks up any moisture.
Interesting idea, @rajamar - it would be really nice to actually photograph the culprit in action, but I may have to weigh whether it's worth resoaking the wood beam in the floor & risking water damage to the camera. I still need to remove bleach-water from the lines, so maybe I will try the air pressure first & save your idea if I need more definitive proof.
Thanks too, @Sharon_is_SAM , for the link - that's where I saw Dale Helman's air pressure idea, and it had the picture I posted which I needed to refresh my memory on all the plumbing - there's a lot of stuff back there!
Thanks to all. I will share whatever I can find, though tomorrow is supposed to bring rain, so may not get much done right away.
ScottG created this. Found over in User Manuals/PDFs under Plumbing Resources.
When you say "fresh water fill line" do you mean before or after the pump? Maybe you can refer to this factory tour photo by Cincykid & identify exactly where your leak is located?..
Also, does your water pump either continue to run without stopping or start back up without faucets open?
The wood beam I mentioned is seen at the bottom in the above photo, and the next one shows how it is an important structural component used to fasten the top frame to the floor frame. They put a second smaller wood beam inside the aluminum floor beam to fasten the larger one to the metal floor beam..
There is a smaller wood beam inside the metal one at the left green arrow. I believe the elevator bolts at white arrows fasten floor to trailer frame. From underneath I could feel water pooling between the forward edge of this main wood beam & black plastic sheet below it.
I'm still wondering, if our leaks are at check valves or at pex tubing connectors, can these be tightened and does it require special skills/tools? I'm beginning to feel like finding the leak may be academic, if the fix is ultimately going to require a long drive to a repair facility. This may end up canceling our first trip reservation next week if we have no use of our plumbing. Bummer!
It's also a good remind for owners to check their pump filter for debris and any connections they can reach for tightness.
SharkBite 1/2 in. Brass Push-to-Connect Coupling
See this on Homedepot.com
OMSID#: 202270492
Store SKU#: 283602
@klenger, if your leak is only external at the city water port, then count your blessings!
The SharkBite requires no tools. Simply push on and pull off to reuse. Once on it can be rotated so no prealignment is necessary.
Good luck, look forward to your findings.
Passenger side; 180° from pump down to near floor.
From lower.
Other end of fresh water inlet tube connects to pvc pipe forward of the black vent pipe. This corner is so crowded, I could not even get the small camera down there to see the floor; wires come in from the outside distribution box & plumbing lines go in all directions including through the wall into the kitchen cabinet.
Now on to a pressurized air test & possibly a wet test if needed. For that I'm thinking about possibly feeding the pump line from a jug of water to isolate that segment of plumbing to rule it in or out.
@jkjenn, if you look at my second photo posted on March 30, at lower right you can see lots of small drops of water. That was taken just an hour or two after the leak. That location of the drops would be about the same spot where the camera was positioned for the first couple shots I posted last night (Mar 31). As you can see in those, there are lots of blue & red plumbing connections in that area, so that is my primary suspected location(s) at this point.
Unfortunately, I cannot reach those lowest pipe connections even with one arm, and it would take two for a repair. I have not been able to get a clear camera view of the actual floor, only the top surface of the forward end of the black tank, which looked dry. The front wall curves down & under lots of wires & plumbing before it joins the floor under the black tank; so the lower you go, the narrower & more crowded the space becomes. I am not rushing at this point, as we had temps around 30° last night for a few hours & will again tonight, so not wanting to flood the floor again.
