When I bought my T@B 320 S in January this year, I opted for the Tekonsha Prodigy RF Wireless Trailer Brake Controller because of the simplicity of the installation and no modifications to my tow vehicle (2019 Jeep Wrangler Unlimited V6). For the most part, I have been pleased with the operation of the controller, but have noticed that it seems to immediately "grab" the brakes as soon as slight brake pressure is applied at very slow speeds. I thought this was odd since there is really no deceleration happening, just application of the brake lights. My understanding is that the controller is supposed to be "proportional" by use of accelerometers.
Yesterday, while towing on the freeway, I was adjusting the temperature controls on my Jeep, and accidentally bumped and turned on the warning flashers, but did not realize it right away. The trailer immediately started bucking, so I pulled over on the shoulder, finally noticing that the flashers were on. I turned them off and the bucking immediately stopped. It appears that because the brake controller does not directly sense application of the brake light switch, it uses the L and R turn signals (also the brake lights on a 7 pin tow wiring harness) to determine application of the brake lights. When the brake controller sensed the L & R turn signals on at the same time, it interpreted this condition as repetitive application of the brakes and responded accordingly. I find this situation most unsettling. I have used brake controllers in vehicles towed behind motor homes for years, and they use the same interface to sense brake application, but require the turn/brake signal to be applied for several cycles before determining that the brake have been applied.
Due to this issue, and just general poor brake operation, I will be removing the Prodigy RF Wireless Trailer Brake Controller from the T@B and installing a Tekonsha Prodigy P3 Trailer Brake Controller in the tow vehicle as a conventional brake controller.
I'd be interested to know if anyone else has seen this issue, or would be interested in testing the operation of the Tekonsha Prodigy RF Wireless Trailer Brake Controller with the emergency hazard flashers enabled (in a safe environment). This could be done at slow speeds, even in a parking lot.
T@B 320 manuals and electrical drawingsConsidering a 2024 TaB 400 with all the option packages (full lithium),
1 ·
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
nüCamp: 2019 T@B 400 Boondock Lite
Finally! New Owner of a 2017 Tab 320S!
Woohoo!
You're supposed to use them when you're stopped or when you're in the process in stopping for an obstruction.
The only time I use them while towing is:
1) I've had to pull off the side of the road to check something on the trailer
2) There's an obstacle directly ahead of me (traffic jam) and I don't want to get rear-ended.
What the heck are people using their hazards for that doesn't involve braking?
https://blog.firestonecompleteautocare.com/driving/when-use-cars-hazard-lights/
https://drivinglaws.aaa.com/tag/hazard-light-use/
As stated in my original post, I accidentally touched the hazard flasher switch while changing the AC temperature setting in my Jeep Wrangler. The result was a dangerous braking situation caused by poor design of the brake control system. If I have been towing in poor weather conditions, the outcome could have been much worse.
I was looking at the Tekonsha brake controller comparison chart and Tekonsha lists the P3 as the 2nd best in performance, only topped by the RF model which I have now. It appears that Tekonsha ranks their performance by price alone, not by actual functionality.
I was approaching stopped traffic on an interstate last week and I turned my flashers on to warn those behind to be aware of something going on ahead of them. While my RF model display does flash, the brakes do not “flash” or “pulsate” at the same rate as the 4-ways.
In fact, every morning before I start out, I perform a full Circle of Safety with my headlamps and 4-ways on so I can test all of the lights, windows, tires, cargo doors, etc., and, yes, the RF display flashes then, too, which is how I discovered the flashing on my first drive.
My point is that is seems like the danger only exists if a driver is using the hazards when they shouldn't be using the hazards. There are all kinds of things in a vehicle that are dangerous if they're used improperly.
We just took out the curt echo on a week long camping trip. Overall it worked well and as advertised but there was one incident that seemed dangerous. We were going down a particularly steep grade and wanted to turn on our emergency flashers because we were going very slow. When we turn on the emergency flashers the brake controller started breaking In conjunction with the pace of the lights flashing. We were super confused and couldn’t get it to stop because we didn’t realize what was going on until we got to the bottom of the hill. This felt like a really dangerous situation. We were driving a 2009 Acura MDX towing a 19 foot Jayco trailer. 613895
I spoke with Curt about the trailer brakes pulsing with the hazards and according to Curt, this is a function of the wireless nature of the controller. With an older wired-in controller, a pulse prevention device could be used but because this is a wireless device it wouldnt work. Curt states that there isnt a solution for this issue.
-- Mike L - 03/28/2019It's disappointing to hear about this as I was ready to install one when my T@B arrives - now I'm not sure which way to go. Though better to know about it now rather than later, I guess.
It's been said before, if you have a pre-wired TV and if you do not plan to tow with another TV, the wireless unit does not offer any advantages..
Never mind the concept of a wireless safety system, not being able to use the hazard indicators seems like an extraordinarily unsafe compromise.
BTW, the whole concept of the "RF wireless" brake controller is more hype than reality. The only wireless aspect of the system is the connection from the hand-held control unit to the brake controller, but the wiring from the tow vehicle to the controller is still hard-wired copper. The "wireless" controller works the same whether the hand-held controller is plugged in or not. You simply can't manipulate the controller w/o the hand-held control unit.
What's really sad is that the wireless controller is at least twice the price as a conventional "Prodigy P3" controller and in some cases, considerably more work to install. Unfortunately, I was fooled by the hype and bought into it. Now I have to spend upwards of $180 to replace it (partially because I shortened the 7-way cable when I installed the wireless controller and now have to replace it).
My wireless controller will go on eBay if anyone here is interested in it after all this discussion. It is in excellent condition and works "as advertised".
the issue with the wireless is it takes a lamp input and makes assumptions based on the lamp voltage. Turn signals and brake lights often share the lamp lamp filament, One lamp on the driver has the turn signal on, both lamps on the driver is applying the brakes.
The fix is when climbing a long hill and feel the need for hazards is to turn off the brake controler or dial it back to the point is has a minimal impact.
It is a compromise solution at best.......
@klenger a timed delay? how can that work? a jackknife happens is split seconds. Looking beyond the T@B world these wireless controllers are used on rigs weighing tons more. Then we delve into the impact this has on TV's with or without ABS.
"Was that a brake command? Or just Hank Williams on single side band?"
For me? No thanks. I'll have a large order of hard-wired please....To go...
WilliamA
2017 T@G XL
@klenger, is it possible that when you shortened the Prodigy 7 pin you shorted something? I hate to see you invest in a whole new system if you can repair the RF brake controller.
