Has anyone towed a TaB 400 with a newer Audi Q5 with factory installed tow package?
i have the 2.0engine with maximum tow capacity of 4400 pounds. No weight distribution hitch allowed per manual. Would towing the Tab 400 nearly 3000 # weight be too much for the Q5 after fully loadinging the Tab, passenger weight and fuel.?
2019 T@b 400 “Hazel” Towed with a 2013 Ford F-150 STX 4X4 SuperCab 5.0L
table mod
0 ·
table mod
2024 T@g 5-wide Black Canyon
also I did take that heavy table out not that I am going to use the Audi but because I physically could not get it off the rail and set it up to be a Bed or couch. I guess I’ll just have to “borrow” my husband’s pickup when I want to go by myself.🤪
table mod
https://tab-rv.vanillacommunity.com/discussion/8865/new-owner-2020-t-b-400-bdl-w-solar-weights-pics#latest
-steve
2019 T@B 400
2018 Audi Q5
Sacramento CA
Two potential problems with this: 1) The Q5 appears to have unibody construction, which makes going overweight more dicey than traditional frame construction. Being over the listed tongue weight can cause structural damage that Audi likely will not cover when they determine you were towing over their weight ratings. 2) If you are in an accident while trailering and insurance determines you are over the listed weight limits for your vehicle, they may deny coverage for any damage or liability.
“Slightly” over on the tongue weight by 5-15 pounds is one thing. 60 pounds over, which is what most 2019’s weigh in at when loaded, is a lot.
The comment by. @VictoriaP is certainly valid and one I’ll consider.
Thank you both for your thoughts.
table mod
Tongue wt “rule of thumb” appears to be 10 -15% of total loaded trailer weight. That is likely how Audi comes up with the conservative 440 ‘limit’ based on their max 4400 trailer weight rating. The less conservative 15% would be a 660 tongue weight. Lets say a loaded 400 weighs 4000? That puts “rule of thumb” tongue wt in the 400 to 600 pound range.
2019 T@B 400
2018 Audi Q5
Sacramento CA
If you do some research on this forum, you'll find that there are only a few people who attempt to tow a 400 with a vehicle with less than a 5000 lb tow rating. It's not because they need the towing capacity, itself. It's because the 400 is tongue heavy and the hitches on vehicles with less than a 5000 lb tow rating usually can't take the load.
2019 T@B 400
2018 Audi Q5
Sacramento CA
2019 T@B 400
2018 Audi Q5
Sacramento CA
nüCamp: 2019 T@B 400 Boondock Lite
Non US specs are always higher, because towing overseas is legally mandated to be at significantly lower speed limits, over 1600 lbs requires a special license. And their safety standards are lower.
https://oppositelock.kinja.com/tow-me-down-1609112611
More bad news: not only are you way over tongue weight from the trailer side, but unless you are carrying virtually nothing in the cargo area, it’s even heavier still. Everything behind the tow vehicle axle also counts towards the tongue weight. You really need to figure out your actual real life trailer tongue weight. Easiest way to to get a tongue weight scale and do it at home. Concrete data will make it easier to figure out what you need to do.
1. the TV spec should be for rear axle weight, which would be the total contribution of TV load plus trailer weight at the tongue. Stating a max tongue weight, independent of TV load (which would need to include occupancy) is abit miss-leading and would need to be based on some conservative assumptions for safety and liability.
2. Hitch weight is meaningless, except, perhaps, as a measure of robustness of the hitch itself.
3. The 2019 T@B 400 seems to have an unfortunately tongue heavy weight distribution.
4. Good input on ROW #s. 😉
I’m not going to “mod” the Audi, but it would be nice to know what the assumptions were that derived the 440 “tongue” weight limit (see #1). I’ll keep researching. I suspect just the 2 of us and virtually nothing in the TV provides a good deal of leeway towards an appropriate rear axle weight.
nüCamp seems to acknowledge the 2019 situation with the 2020 mods. I can’t help but think the spare mounted under the tongue is a fairly reasonable target for tongue weight reduction. Too bad it doesn’t fit through the side storage door. A rear rack mount seems like an after market opportunity to migrate trailer weight distribution?
I appreciate the dialogue!
2019 T@B 400
2018 Audi Q5
Sacramento CA
#1 is again confusing terms. Gross Axle Weight Rating (GAWR) is an important spec, but you'll rarely know what the weight on the rear axle is unless you take your fully loaded trailer and tow vehicle to a CAT scale. For an initial look, what you care about is payload, which is what I think you're trying to talk about in #1. Payload on a Q5 is 1580 lbs, which is the weight of everything you can carry in and on the car, tongue weight included. Fortunately, for you, that is pretty healthy. If the weight of you, your wife, your cargo and the tongue weight of the trailer is below 1580 combined, you should be fine as far as carrying capacity goes.
But all of the specifications need to be observed, which is why @b407driver was absolutely correct when he said that you can't just look at one or two specs and conclude that you're safe. Way too many variables.
I'm sorry to break it to you this way, but you are overloaded. Just swapping out different specs won't change that. Your Audi is tow-rated at 4400 lbs. Your hitch is rated at 440 lbs. The 400 can weigh as much as 525 at the tongue. You have a problem.
EDIT: Payload on a Q5 is actually about 1047, not 1580. So, the payload consideration is even more important than I thought. Subtracting from payload max tongue weight of 440 and about 300 for passengers and you are left with only about 300 pounds for everything else in the car.
So, if you have a hitch with a weight limit of 600#, but a TV with a 3500 # tow capacity, the trailer tongue weight is limited to 350# - regardless of the hitch rating.
In SactoSteve’s case, the limiting factor is the Audi’s tongue weight limit of 440#.
That being the case the only option is to lower the tongue weight. Putting the spare (say 50 lbs) in the TV, would remove that weight from the tongue but add it to the TV payload weight, but thats handled by the suspension, more so than the chassis, if I understand your concern. The suspension is designed for 5 passengers which is way more than a spare tire would add and never a factor for our travels, so we should payload leeway. We never use the propane, (~ 37 lbs full) so that can be removed as well. We travel with gray and black empty and fresh low. So I can see reducing tongue weight by ~ 90 lbs being do-able.
2019 T@B 400
2018 Audi Q5
Sacramento CA
So, you're right--what can be altered is tongue weight, and you have a few good ideas, but you have to be careful with trying to transfer too much weight from your trailer to your tow vehicle, because then you start butting up against the Gross Axle Weight Rating for the rear axle (GAWR) and Gross Vehicle Weight Rating (GVWR) and payload limits. It happens more quickly than you think. You'll lighten the tongue load much faster by transferring weight behind the rear axle of the trailer, such as by filling the fresh tank, putting the spare in the cargo bay, throwing camping gear on the bed. This might sound unappealing, and it would be to me too. But the Q5 is being pushed to (and likely beyond) its limits on the hitch, so concessions have to be made.
EDIT: Payload is actually a bigger consideration than I thought. You should double-check the silver placard inside your door, but I think the payload on a Q5 is only about 1047 pounds, not 1580 as I initially thought. Your ability to transfer loads to the tow vehicle could be restricted because allowing for the weight of two passengers and the tongue weight of the 400, you probably have only about 300 pounds left over for cargo.
What we (2019 T@B400 owners) need is a “continental” pkg for the spare. 😊 I’ve seen 320 boondock packages with a rear cargo rack. That approach seems viable. Could still use the rear window for light and ventilation but not emergency exit.
thanks, again.
2019 T@B 400
2018 Audi Q5
Sacramento CA
According to the owner's manual for a 2018 Audi Q5, the maximum tongue weight capacity for the vehicle is 440 lbs. The factory trailer hitch is more than likely rated higher than this but that is a rather moot point as the vehicle is lower and will be your limiting factor. I do not have any information on the factory trailer hitch for a Q5 but there should be a sticker on the unit which lists both the gross trailer weight (GTW) rating and the tongue weight (TW) rating. If you were able to obtain a part number I am sure your local Audi parts department would be able to obtain these figures for you as well.
For reference, the Draw-Tite Max-Frame Trailer Hitch Receiver part # 76183 which is a fit for a 2018 Audi Q5 has a maximum tongue weight capacity of 750LBS>
