Verna/ allVerna said:@ScottG I have run Interstate batteries in my vehicles for a number of years and I am a completely satisfied customer. I currently have an Interstate AGM battery in my Tacoma.
I had dual Interstate 6V golf cart batteries in my T@B S Max that were still going strong after over 3 years.
I do buy from the Interstate dealer as they do have more aH than those carried by the big retail/wholesale outlets. My dealer, Johnathan, has been extremely helpful in lifting the batteries to their final spot.
I have these, now. There was not an Interstate dealer close enough and these were very reasonably priced. So far, so good.R2DTab said:I recently bought 2 VMAX 6V 220AH batteries and they were small enough to both fit in the boondock front tub with the propane.
What do you recommend for a 12V AGM from Interstate?Sharon_is_SAM said:@lino - check out the Interstate Extreme Cycle Golf Cart chart and go with the highest 20 hr rating you can afford. They are all about the same size. The heavier the battery, typically means more lead and a longer life.
https://www.interstatebatteries.com/recreation-vehicles/golf-cart-batteries/extreme-cycle
Also, they have two 6 v Deep Cycle RV batteries with a 225 amp hr rating at 20 hrs. Not sure how they differ from the golf cart batteries.
https://www.interstatebatteries.com/recreation-vehicles/rv-batteries/deep-cycle
Does it have to be an Interstate battery? I couldn't find a good deep cycle option from Interstate - they don't list the 20 hour rate on their website.ELK said:What do you recommend for a 12V AGM from Interstate?Sharon_is_SAM said:@lino - check out the Interstate Extreme Cycle Golf Cart chart and go with the highest 20 hr rating you can afford. They are all about the same size. The heavier the battery, typically means more lead and a longer life.
