Anybody notice this label in the corner of every window in their Nucamp trailer? I interpret it to mean that the shade should not cover the window when the sun is shining. The other, more obvious point, is to keep the windows closed while towing.
Those of you who have closed your shades when parked in the sun, camping or not, have you seen and damage done to your windows over the years?
I found no relevant information on the window manufacturer's website.
Not all necessarily agree with my view of it, but some do. See this discussion:
https://tab-rv.vanillacommunity.com/discussion/5210/window-shades-when-driving
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Southern California
Full-timer since 2019
As you will see in that thread, I wrote to Horrex about the clip and its purpose. They responded:
"It’s indeed to stabilize the system. If you pull down either blackout or plissé it will keep it together without the possibility to fall down. The blackout and mesh are tentioned with cords so without the clip it still won’t fall down. But it just to be sure."
From those comments, I concluded that even though there is tension created by the cords, they could still fail and the blind/screen (but especially the lower and heavier blind) could potentially fail and the blind may fall. Therefore, I figured if at least the lower blind is kept open/retracted while towing, there is zero possibility of it falling.
Looking at the label (affixed by the Lexan window manufacturer, Plastoform), it depicts the trailer in motion. The "X" (i.e., "No") is adjacent to the closed blind/screen, while the checkmark (i.e., "OK") is adjacent to the open blind/screen.
https://tab-rv.vanillacommunity.com/discussion/8823/clips-for-window-shades-screens
we close the shades in the sun to help keep the trailer interior cooler and again, to keep the dirtbags from casing the trailer at the the spot we are camping. god forbid I need a nap in the afternoon.
So far no issues with the windows melting, warping or other nastys regarding to heat from the shades.
If you can't close it in full sun I would think that is a huge design flaw.
2013 Tundra TRD 5.7L
Massachusetts
Southern California
Do you have a photo of how you use the Reflictix. I am curious how it stays in place.
Southern California
"The label is indicating 2 things.
Southern California
The original orientation of blinds/screens on T@Bs is where the screen lifts up from the bottom and the blind folds down from the top. Currently that is reversed, I believe due to feedback from forum users who wanted more privacy while screens are in use. Personally I prefer the original placement. That's another opinionated topic with multiple posts so let's ignore that issue for now.
My advice would be to lower whatever pleated portion is currently lifted up or retract both top and bottom.
T@B 400 users in particular may prefer fully retracted front and rear windows for see-thru visibility from their TV.
Does Plastiform even know what type of shades might be installed with their windows? (@jimcenname answers that above; mystery solved; raise or lower to your heart's content)
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
Using your photo, I did a reverse-image search on Google (should have done that earlier) and found this October 2016 T@G forum post:
"Had my T@G for two years---just noticed this sticker on the side window. Went to www.plastoform.eu/blanca and found these instructions. When traveling (actually moving down the road) I have been keeping my windows closed, latched, sunscreen up. I thought it would be good to keep sunlight out of the trailer when possible. However, as you can see from the "Safety Instruction" sheet on the website, they recommend leaving the shade down so as to prevent a heat buildup in the space between the shade and the window which could damage the plastic window."
The individual who posted those comments included a link to the safety bulletin, but it just takes you to the Plastoform site. There is nothing there regarding a user manual or safety bulletin.
I am going to continue to leave the shades open/retracted while towing. I can see the potential heat damage issue, but I have also read enough posts about folks having to re-string their shades to cause me to be concerned that driving with the shades closed might contribute to that problem.
Odessa, Fl.
I don't care about folks seeing in, when in transit, almost 100% of stuff is put away, nothing to see, move along. In storage with them 50/50 although nothing to see really, it is still very hard to see inside without a ladder on my Tab 400 Boondock, if someone wants to get a ladder and look, again, nothing to see so move along.
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
Southern California
