I did search the forum and found some discussion about a broken fresh water fill cover. It seemed at that time that there wasn't a replacement part available but I just wanted to put it out there again, in case someone has found a source for the cover to the fresh water fill. Thanks in advance.
Kathy
2018 T@B 320S - Cl@ra
0 ·
In the end , I am in the process of replacing mine with a traditional RV style water tank fill with an actual cap , don’t care for that unique nucamp fill . Feels like it’s going to break every time I use it !
If I am able to retrofit a standard RV style fill port , I will have my old one one (2019 , so not that old !) available if you need one ! Will let you know if I can part with it when I am done with the changeover .
Our 320 is the grey with black trim color scheme , and I am growing tired of looking at the white hardware pieces . Kind of clashes wit the black and grey , lol . I have been able to find most of the items via direct replacement in black , but there are a few I can’t seem to locate in black . Refrigerator vents, a/c vent cover , power input , water fill port etc. I did find a black alde (and light and dark grey) exhaust cover but they are from overseas only and $$$ with shipping . I need to paint the a/c cover ,alde cover and refrigerator vents , everything else I am replacing with an exact match in black , or a close enough match to swap (like the water fill port, etc) .
Going to use Krylon Fusion . What kind of paint did you use, or recommend ?
Thanks !
ktsame - I will likely swap out the water fill port by the weekend , so I will let you know if I don’t need the original nucamp water fill port if the new one fits o.k. .
Btw , it’s no easy task getting to the water fill port , and city water hook up !
https://www.amazon.com/gp/product/B00C5SOXNU/ref=ppx_yo_dt_b_asin_title_o07_s01?ie=UTF8&psc=1
2011 T@B
Rockingham, NC
My guess is any junk yard with Class B's on the lot will have the part, if you need to go that route.
As far as replacements go screw caps are the norm now.
This type also looks interesting should you want the option to pour from a bucket:
https://www.etrailer.com/RV-Fresh-Water/Valterra/R920TW.html
One problem with a new model replacement is the screw holes won't match.
Here is the paint - worked GREAT. Perfectly matches the factory gray trim.
Have to think about this a bit more ..........
Thanks for the paint tip .
I was thinking maybe the cover screws onto the wall. No such luck based on this photo.
You may need to punch it occasionally to pop it open. Just make sure you do that near the triangle on the bottom where it says "push".
Sorry, ktsame, I think I may just “let sleeping dogs lie” . Breaking this fill port upon removal isn’t going’s to help anyone !
Maybe you can order a new complete assy. from nuCamp and see how hard it is to get the old one out , and how much it gets broken on the way out . If you have a direct new replacement , it really won’t matter if the old one get broken anyway .
Good luck !
Assuming it does come apart my thought was the flip lid is the only part you need from a junkyard.
Be brave. Take risks. Nothing can substitute experience.-Paulo Coelho
I did not want to break it , so I just left it in place and painted it (like Tabaz did) !
If anyone comes up with a way to remove it without breaking it , let us know !!!
Anyone???
https://tab-rv.vanillacommunity.com/discussion/4671/replacing-the-gravity-water-fill/p1
