Mattress Topper Suggestions Please
I hope everyone is staying safe and well out there. Getting things ready for an outing (hopefully soon!) in our 2020 400 Boondock Lite. We're looking for recommendations on mattress toppers for the bed. Any suggestions would be welcome. Thanks so much! Happy T@Bbing!
«13
    We used a 3 inch memory foam topper for 22 months (over 100 nights camping in our 2018 400) and had very comfortable nights sleep. We just bought a full size 8 inch Zinus memory foam mattress to replace the topper and original mattress and other than a few driveway naps have yet to fully test it out.
    2013 Tundra TRD 5.7L
    Massachusetts
    edited August 2020
    @Boomzoom, we had our topper custom made to fit by MattressInsider (2" thick Brookside with 4 lb. memory foam.)  It includes elastic straps for all four corners, sized to fit the thickness of your T@B seat cushions.  It rolls up easily and we have been happy with it.  A little thicker might have been nicer, but it would have been bulkier when rolled up.  When we are not using it, we store it behind the rear fold-down bench on our 320 S.
    https://www.mattressinsider.com/rv-mattress-topper.html
  • anbaanba Member Posts: 27
    We use a 2" queen size topper from https://www.sleeponlatex.com and are very happy with it. Just had to cut off a little bit from one corner. An electric knife will work for the cutting.
    2020 T@B400 BDL w/solar | 2022 Ford Expedition
  • larryzlarryz Member Posts: 1
    I also bought the 2" Brookside Memory Foam topper with Organic Cotton from https://www.mattressinsider.com/rv-mattress-topper.html. I have a 2021 Tab 320. I ordered a custom size of 35" x 68" x 2". I can use it on either left or right (side running front-to-back) in the trailer, and can also use it running side-to-side across the back if I travel alone, allowing me to leave the dinette table in place with opposing seating.
    This company is amazing. They communicated with me by email several times, keeping me informed about manufacturing and shipping dates. I've only slept on it twice so far but I have found it to be very comfortable. The quality of their product seems very high.
  • treefrogtreefrog Member Posts: 95
    Another Mattress Insider fan.
    @Bayliss can I ask you what the custom size cost? 320s here  also,69”x70?
  • johnfconwayjohnfconway Member Posts: 295
    Mattress Insider fan as well. No need (in T@B 400) to cut off the odd rear/left corner. There is plenty of play in the system by the time you add a bottom sheet.
    2020 T@B 400 BDL towed with 2019 Nissan Frontier Pro-4X  Tucson, AZ
    We have a pretty simple 3 inch memory foam topper that has a fabric encasement.  I think we got it at Costco.  I trimmed a few inches off the long edge to fit the bed and make sure to maintain the open venting along the back wall for the Alde heat. It turned what was a surprisingly comfortable RV mattress into a very nice “I’m looking forward to sleeping in my camper” mattress.
    @4ncar, we paid $199.00 in June 2019.  Our measurements for a 2019 320 S Boondock Lite is 70" W x 73" L (which are the measurements in the T@B sales brochure for our model.)
    @Bayliss perfect, and thanks!
    I went with this one. That said, I'd likely keep it to a Full Size and 2". This thing is very comfortable but it's a bit of overkill. Also be mindful that that Alde radiates heat from a radiator under the bed against the back wall.
    Also, break out the electric meat carver. You can trim these down to custom fit very easily with the handy little Procter Silex
    https://www.target.com/p/proctor-silex-electric-knife-74311y/-/A-10836642?ref=tgt_adv_XS000000&AFID=google_pla_df&fndsrc=tgtao&CPNG=PLA_Appliances%2BShopping&adgroup=SC_Appliances_Keurig&LID=700000001170770pgs&network=g&device=c&location=9031317&ds_rl=1246978&ds_rl=1247068&ds_rl=1248099&gclid=Cj0KCQjwgo_5BRDuARIsADDEntSU5Tyjt9RJCCN7sViF3jXy-IaYDs0tZsoAf7X7Jz9grqaOgIoB29YaAtMpEALw_wcB&gclsrc=aw.ds
    San Diego, CA
    www.airbossone.com
  • ChrisFixChrisFix Member Posts: 743
    2" Queen size Latex topper - could not ask for a better bed - supportively firm, but comfortable for side sleeping. Truly look forward to sleeping in my T@B!
    https://www.amazon.com/gp/product/B00UYG9WBS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Just a side question. I have a 4" topper memory foam. Nuisance for getting to storage, but thats another story.
    I noticed recently, that there is a thin padded rail along the back of the bed by the window. There is a gap between it and the tab back wall. I think @Denny16 said it was to allow heat from a radiator underneath.
    When i cut the topper, i left it too wide which pushed this rail flat against the wall. So now its angled with little gap. Even now i cut the topper down.
    Think its worth fitting some spacers to keep the gap? The mounting for the rail seems pretty flimsy.
    @Tundra57
    I'd recommend it, yes. If your rig is designed like my 2020 400 there's an Alde radiator along the back wall, believe it's directly under the window but don't quote me on that. Don't think you want to narrow or block that opening.
    Others with more knowledge can weigh-in and add color or correct me if I'm off base.
    Cheers,
    San Diego, CA
    www.airbossone.com
    @Tundra57
    Yes, that is the area where the Alde will radiate heat up for the bedroom. Probably a good idea to backstop yours with some spacers if it is really closed.
    A 2" topper on top of the original bed cushions is the exact right height to avoid going above that radiator area. Worked out really nicely for me.
  • TabdrinkerTabdrinker Member Posts: 5
    I just ordered a 2021 T@B 320 S, and planning to get a mattress topper so I have it when my unit is ready for my first night on the road.  The one at https://www.mattressinsider.com/rv-mattress-topper.html seems highly recommended by many.   Any recommendations on what size to order?  72 x 75 seems about right?  What about mattress height?   Thanks for your feedback!
    @Tabdrinker, see my May 3rd entry (above) regarding the thickness/height.  I included the measurements for my 2019 320 S (see July 30th entry), but your mattress measurements are likely different based on the year model of your T@B.
    To get the gap back under the window and along the back side, you could add some spacers, I plan to do the same, as the topper pushes against it.  I am also looking into the idea of just adding a wood trim board across the back, attached to a bit of ply that would go under the bed cushions, to create a more rigid back bit for the bed to remove pressure to the Alde vent opening.
  • MischiefBrewingMischiefBrewing Member Posts: 30
    I have a 3" queen memory foam from amazon that I trimmed down with sewing scissors.  Didn't sleep well with it on top of the T@B mattress (too soft, can't roll over easily) but sleep like a rock now that I put it under the mattress.
    @Tabdrinker - the 2021 320 S model bed Is 71” x 72”.  Welcome to the forum BTW😊
    edited September 2020
    Denny16
    @Denny16, the existing trim is a heavy cardboard covered with fabric and foam. Behind this is a 1 x 2 that spans the width of the bed platform. Of special note is that the trim panel rests on top of the perimeter boards, so it is 1" above the deck surface, which prevents it from being rigid or as rigid as heavy cardboard can be. Even without adding anything to the top of my mattress, the panel in ours tended to want to be up against the back wall effectively closing the gap to prevent heat from rising up.
    In preparation for the custom topper I ordered from mattress insider, I removed the trim panel and modified it.
    1. Remove the staples in the lower corners
    2. carefully peel back the cloth and padding
    3. Cut a 3/4" wide and 1" high notch in the cardboard
    4. Carefully trim the cloth to fit and fold it back over
    5. Re-staple the cloth to the cardboard using 1/4" staples
    6. Reinstall the trim
    It now sits 1" lower and rests on the top of the bed platform instead of the side rails. The trim panel is much more rigid, I now have a more consistent gap all the way across the back wall of the camper which will no doubt help with the heating as the weather cools off in NC.
    For me, it appears this will work well. If it doesn't, I will look into a thin piece of luan or otherwise to replace the padded trim panel.
    ***edit to add photos
    Brad
    2020 400 BDL aka "Boonie"
    Concord, NC
  • TabneroTabnero Member Posts: 251
    one other thing you can do on the 320 or clam shell is buy a self inflating double wide air mattress. the kind that have a foam core and are only about an inch to inch and a hlaf or so. When you place the air mattress under the cushions it evens out any height differences in support panels. You can also adjust the firmness. It made the factory cushions much better for me and it is collapsible. Also a fiber or feather topper from Wamsutta over the top works as well. lightweight foldable, has big bands to attach to corners.
  • rhynorhyno Member Posts: 394
    *edited* @Dutch061 - Thanks for the pics!
    @ChrisFix - did you have to trim your queen topper down from the 60x80 size stated by Amazon to the 2021 400's 56x79 bed size or does wedging it in a bit help keep it in place?
    @rhyno
    I did trim my down to the exact measurements...the topper I use is too dense to squish that much, and the convection heat opening is along the rear wall, that the topper (and mattress) fit up against. So you don't want to have that heat opening (which is somewhat flexible) to be squished shut.
    An electric carving knife is a great tool for "customizing" your topper. And yes, be careful you don't collapse the upholstered frame against the back wall. Next little project is to insert a few small blocks in that gap to ensure it stays open.
    San Diego, CA
    www.airbossone.com
    +1 on 2" of latex foam. We went with 'organic' latex foam, if you can believe that...
    We cut ours into two separate 'beds' so they'd roll up separately, allowing one of us to 'sleep in', while the other (me) makes coffee... This also allows separate sheets (actually nice quality cotton zippered cases for the foam) for each bed.
    We are very happy with it.
    Here is the custom topper I had made. Less than 7 days from date of special order to on the bed. Looking forward to sleeping on it.
    You will notice it is the perfect height to the modified panel for the heat vent in the rear. This is a better gap across the back than stock.
    Fits like a glove, very pleased with Mattress Insider.
    Concord, NC
    @Dutch061 - Looks good. Did you go 55x79?
    56" at the top, 79" at the back, 73" on the front edge, and 49" at the foot of the bed. I was a little worried only because my measurements were different than what NuCamp publishes. I am very pleased with how well it fit, I was concerned with how the corner would fit in place "cut off". Just laid on it for a few minutes, I think it is going to sleep very well. Plus after making the modification to the "trim strip", I believe the heat will work much better too. Especially nice for my wife who sleeps way cooler than I do and the true season is just beginning for us as the weather cools down and the leaves start to change etc.
    Brad
    Concord, NC
