Somehow we filled up our graywater tank..in two days...and does it come up through the shower drain if that happens?
Still trying to figure out how we used that much water..in just washing dishes...and no shower taken...plumbing problem?
I must have done something at home before we left home..yeah, first trip on new trailer..oy.
0 ·
Next, I would suggest that you dump the gray water holding tank at a dump station and monitor your usage during the rest of your trip to see if the situation reoccurs. After dumping, be sure to check the tank monitor to confirm it indicates it is "empty," and then monitor the level as you use water/fill the gray tank.
And "YES," the gray water from the holding tank will back up into the shower pan if the tank overfills.
Because the tanks are so small, washing dishes in the normal way can pretty quickly add up to a full tank. Many of us have come up with alternatives to conserve both water and waste. I personally wipe dishes first with paper towels, then use a soapy scrubber with only a small amount of hot water to clean, followed by a rinse from a spray bottle of water rather than the faucet. Others will fill a small basin or two (one wash, one rinse). And some resort to disposables like paper plates so that only pots and pans need cleaning.
San Diego, CA
www.airbossone.com
I am going to empty everything and keep a very close eye on things.
First trip and working things out. Thanks ChrisandAlexis, I think we did a ditto.
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
San Diego, CA
www.airbossone.com
2019 T@B 400 BL
Now that we "moved on up to the East Side", we've forgotten some of those methods!
Whats old...is new again!
San Diego, CA
www.airbossone.com
Did you have the gate valve at the hose hookup open? That is usually a gray handle, but not always. If it is closed all the water from the sinks and shower (as one would expect) will stay in the gray tank until it is opened. However, it is not a good practice to leave your sewer connection open directly to the sewer at a campsite--either the black valve or the gray valve. Sewer gases (and maybe critters) can easily enter your trailer from the sewer system.
I had inadvertently turned that faucet on several times by shutting the sink top before fully lowering the faucet handle. But I think my wife has got me properly trained now!
Concord, NC
Yes, the gate at the valve hookup was open. Water had been flowing into the hose. But, where the hose connects to the park sewer system is an L-shaped connection which is higher. So, the water really has not been going to the sewer system and I think that's why the water was backed up. I raised the hose which was full of water and made sure the water drained into the park sewer system. But, the water in the shower pan is not draining and any water that goes through the kitchen sink adds to that. Since I have emptied the hose, I expect water to be able to flow into it. ???
I have solved the immediate problem of draining the water from the shower pan. I opened the second gate that is marked Sewer Connection. But, after the water drained, water kept flowing out -- looks like freshwater to me. FYI-- the sewer hose I set up is connected to the other outlet that is not marked "Sewer". I don't understand the relationship between the gray water tank and the black water tank. Is there a diagram available somewhere that shows the tanks, the pipes and the two outlets?
Concord, NC
The Gray water tank collects water from the sinks and shower. There is a separate Black water tank that collects water from the toilet only. The two tanks are not interconnected--unless someone in the past has done a rather inadvisable modification. Early model TABs had two separate hose connections--one for each tank--each controlled by a "gate" valve that you pull to open each drain. Usually the Gray tank drain handle is gray in color and the Black tank drain handle is black in color--but not always! Later models combined the two drains into one hose connection but each tank drain still has its own, usually color coded, "gate" valve.
The Gray tank is usually located between the frame rails and would be about 12 inches from the ground. It is a rather shallow tank that extends the width of the trailer. The Black tank sits higher and is above the floor of the trailer (someone with a 320 correct me if I am in error here). If the campsite hose dump entrance is at or higher than 12 inches it is possible that water will collect in the hose because there is not enough "water head" to push it up to the hose exit. "Water head" is simply the weight of the water pushing through the hose to the exit of the hose.
Labelling is not nuCamp's strong suit. Is it possible you originally had the hose connected to the wrong outlet? You can determine which outlet is for which tank by pouring clean water into the shower pan (a couple of gallons should do it) and the opening the Gray tank gate valve. Note which hose connection the water comes from. You can do this at home and since it will be a small amount of clean water you can just let it run onto your driveway.
Remaining question: when setting up the camper two days ago, my friend checked the water coming in and when he opened the valve (which I now know is from the black water tank), water gushed out. So, we both thought it was water that he ran through the sink, and we connected the hose to it. This morning, there was a lot of water in the hose too. I thought it was all the water that I had been using. Where would that have been from? I have not used the toilet at all.
One more question: With the proper connection, will water I use in the sink or shower go directly through to the hose or will it be going through the grey water tank? Does it collect there or go straight through?
Thanks to all of you for your help.
Any water you run into the sinks or shower will go first into the Gray holding tank and then, if you have the gate valve open, into the discharge hose.
https://tab-rv.vanillacommunity.com/discussion/7856/plumbing-resources#latest
WOW! Your support is amazing, y'all.
MuttonChops, thanks for the diagram. It definitely helps. Thanks also for the link.
Based on my earlier actions, I have effectively emptied the black water tank or almost emptied it. Looks like I should flush the toilet a few times to get some water in it so that it does not dry out as Denny16 emphasized. Correct?
With all your help today, I am hopefully all set to have this part of the camper working correctly for me. Wonder what my next challenge will be?
My approach is somewhat different.
First, I don't connect the discharge hose unless am actually going to dump tanks.
Second, dump tanks when black is nearing full or at end of each outings whichever comes first.
At end of an outing when black tank is not near full then I top-it-off with fresh water so tank is full.
Now while dumping there is a nice volume & tank water pressure to really flush out the waste.
Believe it also helps to drive on the highway some before dumping (when possible) to give
Happy Camper Mix and motion/vibration time to breakdown solids.
Third, always dump grey water after black to flush out discharge hose.** Also add fresh water to
grey tank to at least 60% full to increase the water volume & pressure while draining.
Thanks for sharing your method. As a newbie, I have chosen the wimpy approach of just using the sink for now, and not the toilet. This is my first trip and I have only two nights under my belt so far; I have also chosen campgrounds that have full hook-ups, thinking that I would just let it all flow into the sewer. I will definitely keep your tips in mind when I am ready for 'Phase 2'. However, having an older model (2015), I don't know how I would be able to tell how full the grey and black water tanks are. I think the newer models have a gauge.
As for the black tank, your only option is to take a peek down the hole while flushing. If the black water looks like it is lapping at the flush gate, I suggest you drain the black tank ASAP!
Glad you got it figured out and nothing is plugged or broken. Camp on!
