Typical 6" soft plastic plane bearing swivel trailer jack wheel - cheep, however good enough for smooth pavement, but difficult in course gravel
Croft's assembly doesn't come with a swivel. So I removed the jack and disabled it - outer tube shown with factory detents that engage a grove in the inner tube to prevent the jack from turning
I drilled out the detents and used black finger nail polish to finish out the holes
the reassembled assembly
Now the T@B can be easily maneuvered into place by my 115lb wife! All it took was about $90 and a little effort.
California, USA
https://www.amazon.com/dp/B07F7Z9T61
...and give her a small throttle remote? You'd have to have enough tongue weight though to avoid just spinning the tires.
Thanks, Jerry
Thanks, Jerry
Did you have to drill out the bracket?
And you said you had to cut off part of the jack?
Tampa FL
Maybe heat?
Anyway i replaced them with solid wheels, not air filled
And have had OK success just placing plywood under the standard wheel for short distance moves. That has got me wondering if the dual Wide Plastic 6-Inch Wheel might be a good solution.
Smaller size, easy to carry & store
Wider footprint, won't sink as deep/fast as standard.
Adventures: 58 Nights: 405 Towing Miles 50,180
For our purposes this works best. Pneumatic tires work pretty good on softer surfaces, but if you loose air pressure you are screwed. For soft terrain I roll on to a couple of plastic jack pads.
Although I have not yet had a chance to try it out, there is no need to cut the jack tube, thanks to the low profile of the tube attachment, as depicted in the second photo I posted above. The Croft kit will attach just like the stock jockey wheel. The bolt that Croft includes for attaching the wheels to the jack tube is a little too thick in diameter to fit through the jack tube. Therefore, if you want to use that bolt and nut, you would need to drill larger holes on the jack tube. However, as @bheitkamp has pointed out, the Croft kit easily attaches with the existing PTO pin that comes with the stock jockey wheel. That's what I intend to use. It is much easier (and faster) to use than a nut and bolt.
The Croft kit is really well made and worth the money for what you get. They shipped it immediately, so I received it not long after I ordered it.
https://www.crofttrailer.com/tjwk10-s-croft-pneumatic-wheel-kit-with-swivel-feature/
You suggested that the heat may have caused them to fail, which seems unlikely, particularly since you indicated it happened in the morning. Do you have any extras loaded on the front of your trailer that may have exceeded the carrying capacity of the tires (i.e., something in addition to the propane tank, battery, and possibly the spare tire?)
That Croft dual wheel set up looks real nice!
Have fun!
I had the double wheel system, purchased here in canada at Princess Auto, each tire was rated for 300 pounds. I have a 2021 TaB BD 320. The tires were new last year, for a 2017 TaG I had.
All 4 stabilizers were down, no one was in it. Nothing on the tounge. Sad the 15th night out so far this year in it
We have no idea why they blew, I'm just sharing my experience, so i switched to a solid tire
It works well & is more compact, but the truth is we rarely need to use it, and we keep a flat foot plate on most of the time (which gives the most flexibility for dropping the tongue very low - necessary for leveling in our extra driveway parking area). Also, I'm glad that I never cut any length off the jack post, because ever since I elevated our jack post mounting to clear a storage bin (and installed air lifts in the TV rear springs), we must crank up the tongue as high as it will go to get hitched up while using the short foot plate.
