So last week we bought our first RV...a brand new 2020 Tab 400. We were really excited about this new adventure and couldn’t wait to set out. We had the Tab in the yard for a few days prepping it and all seemed just fine. But that was not the case and we are pretty angry right about now.
Day one of our maiden voyage was perfect. Camped at a very nice place in Quebec. Connected to shore power, ran AC all night because it was very hot and humid. It was a great first experience.
Day two started early and so did the troubles. Some are likely self inflicted, some are not.
- My brand new and expensive brake controller stopped working. No signals to the trailer. A three hour white knuckle nighttime drive to get to the nearest RV Care place solved nothing. We finally found a mechanic who installed a new controller and that seems to be working fine now. My RV dealer did not install the controller so I can’t really fault them. However, they did not confirm it was working properly during orientation and delivery so I have to hold them at least partially at fault.
- The first night we were connected to shore power but the next night we were on a Walmart lot near the RV Care place. When we parked after driving most of the day I discovered the batteries were down to 50%. I had expected the solar to generate some charge and the the TV to at least maintain the battery level. But it looks like no charge came from the TV during the day and no difference on day three. I’ve confirmed that a 12 v signal is being sent to the Tab so it’s possible I’ve blown a fuse? Another factor, due to problem #3, we have to run the fridge off 12 v. So I’m sure that had an impact.
- We have the three way fridge and cannot get it to run off propane. The LP is full but nothing is going to the fridge and I don’t have enough battery to run it. I can’t check the cooktop for LP flow because we didn’t bring a lighter. The manual for the fridge is severely lacking in advice on this so I don’t know what to do next.
- The rear camera monitor stopped working for a while but then it decided I had been put through enough and started working again and has been fine ever since.
- The solar seems to be working but either it’s too cloudy or the panels don’t generate enough energy to replenish the batteries quickly. And I have no idea how to read the app so that’s a work in progress.
- Since I have no power, that means I have no coffee. That makes me very cranky.
If anyone can offer me some advice I would be most thankful. I’m really disappointed in this first experience. If I’ve cause the issue through rookie mistakes then that’s fine and I’ll take my lumps. But the propane and battery issues really bug me.
Bummer about your controller. What did you have initially and what do you have installed now? To your point, not a nuCamp issue but nonetheless frustrating. Glad it's up and running.
Assume you're talking about Victron factory installed solar? There are some reports that the controller (below the bed in the front-center section) had wiring issues and/or a fuse issue. The fuse should be a black rectangular box inserted in the green (?) wire connected to the controller. Which controller do you have? Likely the 75/15. Check the Victron website for info on the app or check out several You Tube videos on the subject. They're straight-forward. BTW, be sure your Battery switch is on when travelling as it is required to ensure your emergency braking operates properly. Typically, the Victron bypasses the Battery switch so it should trickle charge the battery. Is it possible the battery was drained at the dealer without your knowledge? When was the first time you checked the battery status? And the Victron will take quite a while to "recharge" a battery that is 50% depleted. Hopefully such a discharge state doesn't harm you two 6V Golf AGM batteries as they don't like being drained significantly. If the batteries are still discharged, perhaps you put them on a 110V charger designed for AGM batteries to get them up to snuff. And yes...running the fridge on 12V is the biggest drain on your battery.
To run on propane the 3-way should be very close to level. These units are a bit less sensitive to that than in past years but nonetheless should be level. Open propane tank (might seem obvious but ensure it's producing gas), open your stove and light it. That will draw gas thru the lines. Addtional troubleshooting threads on this forum as well.
The rear view camera is a bit of a budget model and I know mine drops out from time to time then comes back on its own. It's a gremlin...there are after-market options there.
Solar is of course subject to...solar radiation. If it's heavy overcast the Victron will not produce significant charge to replentish a highly discharged battery system.
ARGH...no coffee! Yeah...that's crankiness to the highest order!
There are some serious SME's on this forum who can/will no doubt enlighted you (and me!) further. Hang in there...this too shall pass!
San Diego, CA
www.airbossone.com
Concord, NC
Norcold 3-Way Refrigerator, Factory Victron Solar
2019 Honda Ridgeline
nuCamp is not immune to making changes mid-production cycle.
Cheers,
San Diego, CA
www.airbossone.com
I am wondering if the TV wiring is right. If you were having trouble with the brake controller, and the fridge was running off of battery and TV was not charging the battery, that would explain how your battery became so run down.
San Diego, CA
www.airbossone.com
Sorry you are having issues, but this is what a two-day shake down cruise close to home is for, to learn what to do, and how to use the new trailer, and check,out that the trailer is working properly. We camped about 25-miles from home the first time, so if we forgot something or had issues, home was close by to return to.
The
A little homework here first would also have been a good idea, to learn from others who have a similar rig.
Sharon
https/www.amazon.com/gp/product/B07YVL8SF3/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
New Mexico
2021 T@B 320s (“T@Bañita”)
2023 T@B 400 Boondock (“Redwing”)
2020 Subaru Ascent (“Bubbles”)
You had the right idea camping in the yard for a few days. We also did that. It made a big difference in our understanding of what we needed but that still didn't keep us from making the most grand mistake of all, no TP. Luckily there was a store nearby.
Mellitta pour-over and good beans....makes the best coffee and has the easiest clean-up.
Tampa FL
On the wall of our 400. Daughter made it for me.
mer
Tampa FL
@2Jills
And no need to open the tank valve all the way...it doesn't "increase" the flow of gas. Just a half turn or so. If something does sideways and you need to shut off the flow of gas to the rig, you don't want to be standing next to the tank turning the valve repeatedly.
San Diego, CA
www.airbossone.com
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
I was brought up in a family of firefighters and it was stressed that there's no need to open the valve 100%. Just makes it more threatening to life if you have to close it in an emergency.
If that is not accepted practice, good to know!
Thanks @Dalehelman!
San Diego, CA
www.airbossone.com
2020 Toyota Highlander
San Diego, CA
www.airbossone.com
Good on you...onward! I'm still learning two truisms in life. Never, ever, post to a social media forum before you've had two cups of coffee...or after you'e had two cocktails! Someday...
San Diego, CA
www.airbossone.com
