I hope everyone is staying safe and well out there. Getting things
ready for an outing (hopefully soon!) in our 2020 400 Boondock Lite.
We're looking for recommendations on mattress toppers for the bed. Any
suggestions would be welcome. Thanks so much! Happy T@Bbing!
0 ·
2013 Tundra TRD 5.7L
Massachusetts
https://www.mattressinsider.com/rv-mattress-topper.html
Also, break out the electric meat carver. You can trim these down to custom fit very easily with the handy little Procter Silex
https://www.target.com/p/proctor-silex-electric-knife-74311y/-/A-10836642?ref=tgt_adv_XS000000&AFID=google_pla_df&fndsrc=tgtao&CPNG=PLA_Appliances%2BShopping&adgroup=SC_Appliances_Keurig&LID=700000001170770pgs&network=g&device=c&location=9031317&ds_rl=1246978&ds_rl=1247068&ds_rl=1248099&gclid=Cj0KCQjwgo_5BRDuARIsADDEntSU5Tyjt9RJCCN7sViF3jXy-IaYDs0tZsoAf7X7Jz9grqaOgIoB29YaAtMpEALw_wcB&gclsrc=aw.ds !
San Diego, CA
www.airbossone.com
https://www.amazon.com/gp/product/B00UYG9WBS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I'd recommend it, yes. If your rig is designed like my 2020 400 there's an Alde radiator along the back wall, believe it's directly under the window but don't quote me on that. Don't think you want to narrow or block that opening.
Others with more knowledge can weigh-in and add color or correct me if I'm off base.
Cheers,
San Diego, CA
www.airbossone.com
Yes, that is the area where the Alde will radiate heat up for the bedroom. Probably a good idea to backstop yours with some spacers if it is really closed.
A 2" topper on top of the original bed cushions is the exact right height to avoid going above that radiator area. Worked out really nicely for me.
In preparation for the custom topper I ordered from mattress insider, I removed the trim panel and modified it.
1. Remove the staples in the lower corners
2. carefully peel back the cloth and padding
3. Cut a 3/4" wide and 1" high notch in the cardboard
4. Carefully trim the cloth to fit and fold it back over
5. Re-staple the cloth to the cardboard using 1/4" staples
6. Reinstall the trim
It now sits 1" lower and rests on the top of the bed platform instead of the side rails. The trim panel is much more rigid, I now have a more consistent gap all the way across the back wall of the camper which will no doubt help with the heating as the weather cools off in NC.
For me, it appears this will work well. If it doesn't, I will look into a thin piece of luan or otherwise to replace the padded trim panel.
***edit to add photos
Brad
Concord, NC
I did trim my down to the exact measurements...the topper I use is too dense to squish that much, and the convection heat opening is along the rear wall, that the topper (and mattress) fit up against. So you don't want to have that heat opening (which is somewhat flexible) to be squished shut.
San Diego, CA
www.airbossone.com
We cut ours into two separate 'beds' so they'd roll up separately, allowing one of us to 'sleep in', while the other (me) makes coffee... This also allows separate sheets (actually nice quality cotton zippered cases for the foam) for each bed.
We are very happy with it.
You will notice it is the perfect height to the modified panel for the heat vent in the rear. This is a better gap across the back than stock.
Fits like a glove, very pleased with Mattress Insider.
Concord, NC
Brad
Concord, NC
