I bought my T@B one year ago and put 3,280 miles on it. I took it in to have the hubs repacked and the mechanic found that I had a bad seal that had to be replaced. The moral of the story is don't ignore your hubs. I plan to have them repacked each spring and more often if we do any major road trips.
Question, how long should the seals typically last? What factors might impact how long the last? I assumed that is is mileage but is there anything else?
2016 T@B M@X S grey/red 16 Foot Airstream, towed by 2014 Jeep Grand Cherokee V6 4x4, Central Connecticut
0 ·
"Ditto Verna! As mentioned, Bearing Buddies work well to keep moisture out... but are really designed for bearings that may get dunked in water. The issue with a "dry" bearing trailer -- like the T@B-- is that the spring pressure exerted by the bearing buddy may pop the inner axle seal and allow grease to enter the brake shoe area.
OK, terrible description, but that's the issue: pushing grease in with a grease gun through a grease fitting on a bearing buddy type of thing can easily overpower the inner axle grease seal and allow the brakes to become grease-soaked and ineffective. Not good."
To find the entire thread discussing the Bearing Buddies, please perform a search for Bearing Buddies, as that is how I found this quote from @irvingj.
Bearings are important, certainly. Keeping them clean and lubricated is a definite plus, beginning with cleaning out all the old grease and re-filling with fresh. Yeah, I grew up doing that by hand (literally!)....
In our T@Bs, it usually amounts to a brief "refresh" of the grease, unless you opt to start new. Be advised also: there are some incompatibility issues with different wheel bearing greases; best to clean out totally if you're planning to put in a different grease and/or don't know what type of grease was initially installed.
I'm surprised that new T@Bs are coming with spring-loaded "bearing buddies." Positive pressure on the bearings should not be necessary (unless you want to see if your T@B floats!), and there's always the danger that the inner grease seal will let go and allow grease into the brake shoe area if new grease is pumped in with too much pressure. IMO, THAT is the real issue.
Alan & Patty
Southern Az
I agree with Verna and Irvingj above that squirting too much grease into bearings is an issue and that too much grease could cause a seal to fail and allow grease into the brake drum area and mixing different lubricating bearing grease is never a good idea. I experienced a bearing failure out in Arizona about 5 years ago that damaged an axle spline, that required me to change out an axle assembly on a 5-wide Little Guy in a campground. This created a lot of uncertainty and anxiety for me at the time and thank God that Little Guy networked with one of their distributors, Tom's Camperland in Phoenix who removed an axle assembly from one of their new 5-wide trailers, handed it off to me and we were able to replace it at my camp site.
I am an advocate for proper wheel bearing maintenance & inspecting wheel bearings, and if you are unfamiliar with it you should hand this chore off to a qualified technician/mechanic and let a qualified individual perform this procedure to ensure that things are done correctly and to help eliminate issues when you are out in remote areas, far away from home and broke down along some deserted stretch of highway. Wheel bearings are the heart of an axle and I cannot emphasize enough the importance of proper maintenance and inspecting them as recommended by the factory/manufacturer.
Here is Dexter's bearing maintenance video and keep in mind when watching it that this is a video produced by the manufacturer, there is more to it than what meets the eye (been there and done it) and that the task of performing bearing maintenance and inspection is a bit more involved and tedious than what the video actually portrays. The information contained in the video below is spot on and accurate and when the bearing repacking/inspection procedure is performed as shown in the video it is effective and does work.
Good info, Mike. And you're absolutely right, a damaged bearing/axle can get real expensive real fast.
Evanston Wyoming home
Adventures: 55 Nights: 376 Towing Miles 46,920
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
Recently I manually repacked the bearings on my small utility and boat trailers. Messy, sure--but otherwise a very easy job.
For those of you who have done bearing maintenance on simple trailers as well as the T@B, how much more challenging was the T@B given its EZ-Lube innards and electric drum brakes?
I'll look for that other discussion, too. I know the topic has come up a few times but I happened to have this one bookmarked.
Here are a few old links that might have some helpful information.https://tabforum.nucamprv.com/#/discussion/comment/133133
https://tabforum.nucamprv.com/#/discussion/comment/142472
Since you have really stretched things you should pay particular care to a few things that you might not worry about if the PM was done on schedule.
After you clean off the axle shafts looks very carefully to see if there is any burnishing or scoring. If there is you should be sure that you replace the bearings and races. That's with very light burnishing...if it is pronounced you should probably put it all back together and take it to a trailer shop....for axles. Hopefully not!
If you have been using the Zerk fitting to push grease into the axles look at the rear seal and look for any signs of grease intruding into the hub. You'll be replacing the rear seal either way but grease in the hub can mean that the brakes are toast.
The brakes must be due for an inspection and adjustment. Make sure that the insides of the drum clean up and does not have wear grooves/damage. If they do, brake drum.....and shoes. If that all looks good then simply adjust them after you reinstall the bearings, hub and drum.
Keep track of the type of grease you are using...and perhaps keep an extra tube or tub for future repacks or if you want to give em a spritz with the Dexter Zerks. Grease types should never be mixed...the carriers can fail. If the carriers fails...yuck. the grease will ooze out like soup.
(this from my post some time ago)
Better safe than sorry!
I do have a question about the brake adjustment you mentioned. (I am familiar with the adjustor and have adjusted the brakes as needed.) When you say "tighten the brake adjustor" am I correct that I am actually backing the brakes shoes off of the drum? The video didn't mention this specifically, but it makes sense since tight brakes look like they would impede removal of the drum.
@irvingj, I've used the EZ-Lube zerk to add grease that matches the specifications given in the Dexter axle manual, So assuming they follow their own instructions compatibility should be okay. Regardless, if I'm going to take everything apart I'll likely do a total cleanout anyway. Thanks for the reminder.
When I eventually dig into this, I'll post what I find--good news or bad! ;-)
That will shorten the length of the adjuster and pull the shoes inward (closer together), allowing the normal lip that forms on the outer edge of the drums to clear the shoes when pulling them off.
It seems you can order parts direct from Dexter, but there are also numerous companies that make compatible parts (such as those available from eTrailer).
My inclination is to stick with Dexter, but for those who have done this, does it really matter?
