Heh! Just a little heads up for those single campers...
Note that the latch on the shower door does loosen up after a while. If left in the "pointing up" position, it can inadvertently wiggle itself down to the "locked" position.
It would be tough to reach, to unlock it, if you happen to be inside the shower at the time.
It might be a little awkward shouting out until someone comes to let you out. Imagine if you'd locked the Tab door too.
(I'm a natural paranoid, I moved ours up closer to the top of the door)
Chan - near Buffalo NY
It might be worth doing for those of use who travel solo. I could be trapped for days! In all likelihood, I would just bust it open, lol. But, I would rather not have to bust it open.
LOL! Of all the things that could go wrong on a camping trip! I'm going to start taking my PLB in the shower with me after reading this. Seriously, I will turn my knob DOWN when not in use. Thanks for pointing this out Chan.
Personally, I'm not taking any chances . . .
We certainly are a creative problem-solving bunch, here!
BTW, good luck on your current TearDrop Yoga poses as St_Bob directs you to check the trailer wiring!! Strrrrretch!
Stopped using the shower.
It's important to think of everything!
(Just don't lose sleep over it!)
2019 T@B 320 S Boondock Edge named "Binky" | TV: 2016 Chevy Colorado Z71 with full tow package and a Leer Cap for lots of storage
You could just move it, and leave the hole, or you could put a nice stainless steel screw in the old hole, so it looks like it belongs there.
Recently removed the 'factory latch' completely due to realistic fear of being locked in. Now use a small spring clamp at top of door during travelling. Can never be locked in and has a big plus of keeping the long magnet strip in place on wash-board roads
It sounds like the hole that your 'latch' is screwed into has loosened or stripped enough so that the latch will no longer stay in position (it's friction fit).
I'm assuming your latch is the same as mine, a simple turn-type lever that blocks the door from swinging open when it's turned 90 degrees toward the front of the Tab.
If that's the case, then the screw that the latch pivots on should allow for tightening to give it more friction to stay in the position to which you set it. If the screw won't tighten, then perhaps it's stripped, likely the hole in the aluminum frame of the shower has enlarged beyond repair.
If that's the case, then the solution I suggested would be the way to go - simply move the whole screw/latch assembly, abandoning the original hole, and filling it (the original hole, ie: for aesthetic purposes) with an attractive stainless-steel sheet-metal screw.
In hopes that this applies to your situation!!! Otherwise, (er, edit) what year/model is your Tab, and can you provide a photo of said latch?
