TAB 400 BOONDOCK 2021 WINTERIZING
After consulting NuCamp, Nautilus, and You Tube, I think I have condensed the previously confusing process of Winterizing this RV. There were vast differences from the 2020 model while, the 2021 directions have not yet been released.
I hope this makes it much easier for the next TAB 400 2021 Winterizer.
Drain Fresh Water Tank
Turn Water Pump on & open all Hot & Cold faucets & Outside Shower lines. Do these (one line at a time). When water flow stops turn pump off.
Open Low Point Drain Valves, Hot & Cold (one at a time) & close back up.
Open ALDE Pressure Relief Valves (2 and they are yellow) One is for the Hot Water Tank & one for the ALDE flow. I have provided a photo below for one line. The other is there, but not in the photo. Easy to locate under the right side of the bed.
Drain Waste Water System. Black first, then Grey.
Set Nautilus to Winterization Mode. Make sure Red Lever is Correct! This is the ALDE Bypass Valve.
Connect short hose to City Water Inlet. Insert other end into Antifreeze Jug. Open kitchen faucet & turn water pump ON. You can use either the inside or Outside Water Pump Switch. Pump winterizing fluid into each Hot & Cold Line (one at a time) until pink antifreeze appears. Pump the fluid through everything that emits water.
Final: Pour ¼ gallon into every drain & toilet. ½ gallon into shower drain.
Please peruse these procedures and let me know if I need to edit. I would certainly appreciate your comments and I’m sure all TAB 400 Boondock 2021 owners will benefit from our effort.
Giota in Santa Fe
Definition of Success….”moving from failure to failure without any loss of enthusiasm” (Winston Churchill)
The initial step to drain the fresh water tank is accomplished by opening each faucet one at a time until the flow of water ceases?
Followed by opening the low point drains for the hot and cold water lines?
Can you fill me in on the location of the low point drains for the hot and cold water lines. I am sure I saw a picture of them somewhere but I cannot locate it now.
I am receiving my new 400 in January!
The valves for the two low point drains are accessed through the Nautilus. They are located right under the outside shower controls.
General comment on priming the pump:
For priming the pump, I did not need to blow into the hose. I did it by:
1. Hold up the end of the short hose that is connected to the city water line
2. Pour antifreeze into the hose until it was full.
3. Turn on the pump.
4. When the pump starts pulling antifreeze out of the hose, stick the hose into the antifreeze container and let it run until the pump has pressurized the lines and the pump stops running.
5. With the pump switch still on, start opening each of the different hot and cold water lines.
2019 Jeep Grand Cherokee Overland V6
Cincinnati, OH
Thanks for the great info. We have a newbie question. In the following :
"Open ALDE Pressure Relief Valves (2 and they are yellow) One is for the Hot Water Tank & one for the ALDE flow. I have provided a photo below for one line. The other is there, but not in the photo. Easy to locate under the right side of the bed."
which side of the TAB is the 'right' side? Are you referring to the driver's side (next to the Nautilus) or the other side? thanks--winter is upon us!
thanks!
2024 Jeep Grand Cherokee 4xe Trailhawk
2021 T@B 400
2019 Subaru Ascent
The Alde pressure relief valves are under the bed on the Driver's Side of the 400...or the Right Side if you are looking at the 400 from the front.
1)can I follow your instructions above but stop at “Set Nautilus to Winterization Mode” ? and be ok for a few months?
2)if it is drained, at what outside temp do I have to get it inside? Will it be ok at 28 degrees for a few hours? Looks like we may have a few nights hovering near freezing and then back to 40s and 50s. We would like to keep it in the driveway until Monday but not sure about those temps without winterizing??
2021 T@B 400
2019 Subaru Ascent
https://us.v-cdn.net/5021717/uploads/editor/py/2wdph8ajpgb7.pdf
Some TaB owners also add the RV antifreeze to get antifreeze protection in the various valves, like in the toilet on units that have a black tank, and some antifreeze in the black and gray tanks to get the stuff in the outside dumping/drain valves, which will freeze and can cause damage.
2020 Tacoma TRD Off-Road
SW Colorado
