Coming into warmer weather and looking for info on de-winterizing our 2021 T@B 400 with the Nautilus system. Are there any videos or manuals/instructions out there that would be helpful? Of course, any and all advice is welcome. “Experience is the greatest teacher.”
0 ·
https://us.v-cdn.net/5021717/uploads/editor/py/2wdph8ajpgb7.pdf
Do you know if you added antifreeze to the plumbing or just to the p traps? Do you know if there is antifreeze in the Alde?
SW Colorado
Page 1 of 1
DE-WINTERIZE (NAUTILUS P3)
1. Connect garden hose to inlet labeled “CITY WATER CONNECTION”.
2. Turn diverter handles on Nautilus Panel to following positions:
Blue diverter handle should be facing left.
White diverter handle should be facing down.
Red diverter handle should be facing up.
Green diverter handle should be facing left.
3. Connect other end of garden hose to water source and turn water on.
4. Open one plumbing fixture on RV. Keep it open until winterize solution has been flushed, then
close.
5. Follow above procedure until all inside and outside plumbing fixtures have been flushed.
Important! Make sure to flush both hot and cold lines including the outside shower.
6. Turn Diverter handles on Nautilus Panel to PowerFill Tank positions.
7. Fill Fresh Tank until it is approximately 1⁄2 full.
8. Turn water off at source.
9. Turn diverter handles on Nautilus Panel to DRY CAMPING positions.
10. Push “PUMP” switch so that light on switch is lit.
11. Using the outside shower on the Nautilus Panel:
open COLD faucet. Use the shower head to flush out any remaining winterizing solution.
Boston Northshore
SW Colorado
then follow the instructions to sanitize. After flushing and sanitizing is completed, then turn the Alde Bypass to normal.
https://us.v-cdn.net/5021717/uploads/editor/i2/ifvg1dabfs8z.pdf
Can anyone confim?
Picked up 2021 T@b 400 BD / Nautilus P3winterized from the dealer back in March.
I (believe) I understand all the above steps. Just wondering if, since there isn't an Alde Bypass valve on the P3, is it safe to assume that the hot water heater (Alde) is ok? (No AF in ALDE).
Since this is our first trailer AND our first time de-winterizing AND the P3 is new to everyone, I'm just a bit concerned that I might mess things up and somehow forget to get the AF out of the Alde or some other line.
I noticed that in the 11 steps above nothing is said about opening the low point valves (hot/cold/fresh water) or the Alde yellow valves is that something that we don't have to worry about due to the P3 system? In older videos they say to drain all the low point valves.
Th@nks in advance!!
Virginia
2021 T@b 400 BD (N@lu 'Ima Ola)
2013 Toyota Tundra Ext. Cab V8 5.67L 4x4
Ideally you do the flush out when you have a connection to a dump. Since your gray tank is large, you can let it go into your gray tank and then dump later.
After you flush the AF, then you will want to sanitize the fresh tank.
See my photos in the the document here of my recent endeavors of winterizing this same 2021 TAB400.
https://tab-rv.vanillacommunity.com/discussion/11969/tab-400-boondock-2021-winterizing/p2
Had to laugh to myself also as just about finishing winterizing
Juliet and Andy in Massachusetts
2022 F-150
Gratitude
