Lithium or AGM Battery Mounted Inside a 320 Cabin?
2»
  • BaylissBayliss Member Posts: 1,371
    Thanks @jkjenn.  I will check out your video.
  • tomtektomtek Member Posts: 48
    I upgraded to 280aH DIY Grade B Lithium Cells I assembled along with relocated battery in the cabin passenger side wheel well storage of 2021 CS-S.   I upgraded the converter to a PD4060(LI) and have upgraded wiring to handle the higher charge currents. Other notes is the addition of a 1200 watt inverter and automatic cut over switch for inverter.   Its been a major electrical overhaul but am extremely pleased with the result and it's possible I may add another 280aH of Lithium.  I watched @jkjenn video before my work and got a lot of great info from it and was able to make a more informed choice of my conversion.   Thanks @jkjenn great video with precise reasoning behind your decisions.   I have a few other electrical changes I am happy to share if there is a request.
    2009 Dutchman TQ - Sold
    2021 CS-S - Enjoying the new layout
    2011 Outback 3.6r
    Sharing is caring @tomtek  :)
    Start a new discussion, so we don't have to wade through all of this one to see your ideas. I find it hard to later look back at concepts when they're hidden within a discussion of a different title.
    2019 320 Boondock Edge
     - Sold Jan 2022
    Nice job Bayliss.
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,804
    @Bayliss Here is a VERY limited view of the driver side construction that I believe shows a thin, metal plate in the area behind the wheel.  Probably just to allow them to add in electrical and plumbing before the side wall is added.
    edited February 2022
    Thanks for the photo, @Sharon_is_SAM I don't believe I have seen that particular photo previously, but it does indeed show a metal plate at that location, albeit in a later year model 320 S.
  • ReenieGReenieG Member Posts: 211
    Cherokee said:
    Cool solution - storage space is always a rob Peter to pay Paul proposition.
    We are lucky that we can get by with two golf cart 6v batteries in series - thanks mostly to portable solar and California sunshine.
    @Cherokee do you find these work better than one regular 12v deep cycle? And do they both fit in the standard group 27 size battery box in your tub?
