1. NoJay_and_Kat said:The wife and I are seriously looking at getting a camper so we can quit sleeping on the ground in a tent. We've been looking at something small enough to easily pull behind our Jeep (Gladiator) and discovered nuCamp.
So we're looking at the T@B CS-S as the external kitchen seems nicer than on the inside (plus, we're camping, why stay cooped up inside?)
Now, some of our questions, some of which we'll probably get answers to when we go to the camper and RV show in two weeks, that maybe you kind folks can help with:I think at the moment that about covers the worst of it.
- It doesn't look like it, but does the CS-S have a hitch receiver, that we could put a bike rack on?
- If it doesn't have a receiver, can a pair of 26" bikes be squeezed inside for transport? I've seen tongue-mounted bike racks, but MAN they are pricey!
- Reading some of the posts about the '22 models, how big of a deal is the new floor system?
- Are these suitable for multi-state trips? Say for example, Detroit, MI area to Texas?
- Can you squeeze a Yeti cooler (110 size) through the door to sit on the floor (again, for transport)?
We started with a 320 but got tired of having to break down and set up the bed/table every morning and evening. Went with the 400 primarily because the bed and table are separate. The extra room and storage space is a huge plus also.
Not saying that the larger 400 doesn't have it's advantages, but breaking down the bed doesn't have to be the determining factor. If you can deal with side-to-side sleeping, the 320S can work with some modifications. I'm 6' and sleep comfortably at a slight angle. The bed is permanently setup with a mattress that's 54" wide by 71" long. Much rather eat outside under our canopy, but we still have indoor seating for a quick bite on the road or when weather is really bad.
edit to add: Be sure to see @VictoriaP's post below.
To make this clear to anyone new to the forum looking at a Tab 320 to purchase, @AnOldUR’s Tab 320s pictured above has undergone pretty major modification. What he’s tackled isn’t for the faint of heart (or those of us with lesser or non-existent handyperson skills/adequate tools!) The awesome layout in that pic would also be tricky to impossible to replicate in the 2021 or later due to the much lower bottom on the upper rear cabinets. And it can’t be done at all in the clamshell that the original poster is looking at as the dinette of those units is much narrower.
It may be doable, but for a lot of us, an off the shelf RV that is designed with a separate seating versus bed area makes a lot more sense.
(I’ll note that for solo folks, this layout can be done with no mods at all, just lower the bench back for a twin bed and leave the small side bench cushions in place. The bed pictured above is full size.)
Edit: something else I’ll note…In the 320, your bed is made up of multiple cushions. Most of us end up with some sort of mattress topper both for cushioning and to combat the feel of all those crevices beneath you. The thickness + dimensions of the topper may limit both your access to the cabinets below and your ability to tear down the bed each day without finding a place to store that bulky addition. I mention this because I wanted to try to set the bed back into dinette mode daily this camping season, but then ended up with a back issue that now requires 5 inches of foam on top of those cushions. Believe me, there is nowhere in a 320 to store that much foam during the day! I guess I’m still stuck with a full time twin bed.
So when you are evaluating a 320 or any other “dinette to bed” style trailer, you need to think about where that bedding will go if you plan to use the dinette in table mode.
You are absolutly going to need a topper (in 320 and 400), as far as I'm concerned. As a solo traveler in the 320 the bed was a permanent layout for me because I had to get a 3" topper.
@Jay_and_Kat , @AnOldUR's modification is a very interesting and unique method of having it both ways (a full-time bed plus seating, and a table to boot!) The negatives of that arrangement for me is the reduced width of the bed, plus the loss of the rear shelf and storage it houses.
To piggy-back on @VictoriaP's comments, I am 5'11 (my wife is shorter) and we are very happy with the full-sized bed we have, which is 70" W x 73" L with a 2" thick mattress topper from Mattress Insider. Like @AnOldUR, I sleep at a slight angle, which is very comfortable. Although you have to put the bedding away if you want to use the table and seating (which we only occasionally do), it really is no big deal. Like many other 320 S owners on this site, we simply roll up the bedding and hide it behind the rear bench. It fits perfectly and we still have the rear shelf and storage available to store items. Also, as far as the width of the bedding, at night we often have some items set to the sides of the bed on top of the mattress and covers for easy access. Although I think I would have preferred a 400, simply for the benefits of better head room, a full-time bed and table/seating, plus a larger bathroom, I am extremely happy with our 320 S. We down-sized from a 5th wheel. You will be up-sizing from a tent, so it is going to be a huge improvement. We spend most of our time outside when we camp, including doing all the cooking outside, and use the trailer primarily for sleeping. Also, as already mentioned, if the weather is bad, you have a cozy cabin to relax in, plus you can cook inside, if necessary.
Sorry to hijack the post, but I would love to see a photo of the Lagun table mounting for @AnOldUR 's T@B. I would like to move my table from the rear bench area to make it easier to get in and out of the rear bed. Thanks!
@PNWtabber https://tab-rv.vanillacommunity.com/discussion/comment/177411#Comment_177411
I had it @AnOldUR’s post on that bookmarked. Unfortunately my Tab has a propane/CO monitor I would have to move to put mine there, the 2020 has a different arrangement of things on that side of the dinette from the 2019 and older models.
Edit to add: …and for newcomers, the legs of the pull out benches will block this mounting location on 2021 or later Tab 320s units. Man, it’s hard to remember all the model year differences when posting!
"Unfortunately my Tab has a propane/CO monitor I would have to move to put mine there, the 2020 has a different arrangement of things on that side of the dinette from the 2019 and older models."
Thanks, @VictoriaP , no wonder I was scratching my head. Yeah that area has a lot of stuff going on in my 2018 T@B. Darn.
@PNWtabber, I don't intend to step on @AnOldUR 's toes in responding to your inquiry, but I just happen to have previously saved the link to those photos, so here ya go............you may even see your forum name and a couple questions in that discussion as well. 😉
https://tab-rv.vanillacommunity.com/discussion/12150/where-to-put-the-lagun-table-at-night/p2
@VictoriaP & @Bayliss covered it with their links, but I'll add that moving the propane/CO monitor is really easy. That location can handle a lot of modding. Room to spare! 😁
If I may ask, why the BD version?. We have the 400 std and I’ve often wondered if the BD would be better for some reason, but with our “set up camp and explore in our TV” approach to camping, I haven’t seen the advantage.Jay_and_Kat said:…we have decided the 400 is more likely to suit us better (Boondock version, though.
