I'm in the beginning stage of installing a Renogy 2000W inverter in our 2020 320S. I have spent hours going over the many other installations posted here (lots of great information), but couldn't find everything that I was looking for. Hoping to gain from others experience and share mine.
First question. The Renogy inverter has "High Output AC Terminals". It says, "These terminals are for connecting 115V AC devices that require more than 15 amps to operate or for connection to distributed wiring that has multiple AC outlets". The only outlet I plan to hardwire to the inverter is the one above the sink. Can I simply pull the wires from the pass through outlet below the bench seat and connect them directly to these inverter terminals or is a circuit breaker required between the inverter and outlet?
Thinking it may be possible to break the tabs on the bench seat receptacle so that the lower outlet is fed by the inverter and the upper buy shore power? Not sure how the GFCI would work, but will check it out. Any electricians here know?
You don't need a circuit breaker, just like plugging into a generator with overload protection. Curious why you didn't want a inverter with a transfer switch for shore power?
Brad
Concord, NC
The question was, do I need to add a circuit breaker after the inverter when connecting to the High Output AC Terminals on a Renogy 2000W inverter (Model RGN-INVT-2000-12V-P2), or is there internal overload protection that will protect the circuit?
Thank you.
The output of the inverter can be connected to a circuit breaker.
Fuse or breaker specification calculation: Inverter power ➗ 120V ✖ 1.25
which is equal to 20.8A You can take the fuse specification nearest to this number. An oversize will not provide protection.
Huntington LI
I also split the wide breaker on my AC panel into two thin breakers and put my power converter onto its own AC circuit. When I power trailer AIr Conditioner I turn off converter to keep trailer cooler. I have solar to cover my needs. Also useful wiring to go full house inverter. Gives the option to deal with blown converter and still use rest of trailer.
