Didn't want to take the chance of doing our glycol flush and replacement with the new stuff wrong, so just over a month ago we scheduled it to be done at the dealer. They have a great reputation, so we also scheduled a Maxx
Air fan replacement. Could have done that myself, but wanted to patronize this dealer. They said it would be a total of maybe four hours labor. We were debating to wait while the work was done (maybe do some shopping in the area) or leave it there, but decided to leave it overnight. Got out early and towed the hour there this morning (Monday) to find that they had not ordered the fan and that it wouldn't be there until Thursday and that the work would not be done until sometime next week. The thought of our baby sitting in a lot on a busy road for over a week doesn't thrill us. Fighting the demons in my head telling me to go back and pick it up. It would probably be a "cut off your nose ..." kind of thing. Trying real hard to chill, but I just don't get it.
(only venting, thanks for listening)
As far as the phone call? Around here, that wouldn’t make a difference. You get a drop off appointment six weeks out and you drop it off whether or not they’ll be starting on your rig that day. (Hint: they won’t, and don’t expect to see your rig back for at least two weeks.) Miss your drop off, get back in line and wait, possibly another six weeks, until they have room for you. The demand for service is way higher than they can possibly fulfill, they really don’t *need* your business.
If you can DIY something, do so. If not, you’re at the mercy of the dealership, and they generally don’t know the meaning of the word. It shouldn’t be this way, but that’s the way it is, and it appears to be industry-wide rather than brand specific.
I constantly checked the color of the fluid in the various bleeder tubes during my flush to see when it turned clear, meaning the Century was gone. As I introduced the Rhomar I did the same and kept adding Rhomar until it appeared the same color as a fresh batch of Rhomar. This made me feel good that I not only got out the Century but also pushed out the water. Here is a picture of what mine looked like in comparison to each other. The sample on the right, with the sticker on it, is direct from the bottle and the one on the left is a sample from my bleeder tubes and the expansion tank.
2022 T@b 320 S / 2021 Subaru Outback
https://tab-rv.vanillacommunity.com/discussion/13409/switching-to-new-rhomar-glycol#latest
I am so sorry about what @AnOldUR is having to go through. This has convinced me that what I did on my last change with regular Century was more of a flush than some dealers are doing for the change out to Rhomar. I noted then it did take 15 gals of tap water to remove all traces of Century color in the flushed fluid, followed by 5 gals of distilled water, and then refilled with fresh Century. That much flushing did take time, and perhaps that is the rub for the dealers who don't see the need. And my Alde has never had problem one. So next year I will do it myself it seems with Rhomar. Thanks as always to the expertise on the forum.
And I get it, believe me. A combination of conflict aversion and perfectionist tendencies mean I run headfirst into the “fine, I’ll just fix it myself” wall all the time when someone else gets it wrong. But this is a $3k heating unit (probably more nowadays), and if the dealer doesn’t do this switch correctly, they could find themselves on the hook for a lot of problems with their customers. Giving them the chance to make it right, and involving nuCamp in the process as needed, is the morally correct thing to do. Even though, yes, it’s uncomfortable for you.
If they’re as good as you & others have said, they’ll make it right.
I would have the same concerns given that Rhomar fluid is blue/green with no hint of yellow, whereas your sample has yellow in it.
I understood when you took the trailer in, the Alde had the Century fluid. They were to flush the system per recommendations and refill with Rhomar. Others have done that via dealers and at NuCamp and on their own and no subsequent changes in color are reported. So apparently facts and truth hold little sway with someone at this dealership. I would let NuCamp know and tell this dealer you would like 5 gals of Rhomar for your trouble and then finish the job as Nucamp has recommended. If they can't provide even that consideration I would never use or recommend them again.
