Grills and outdoor cooking - Everything finally came to a head with all the wind across Wyoming, Utah, and northern Arizona where I couldn't keep anything outdoors lit. Wind would constantly blow out the flame no matter how I positioned things - don't know how you folks without the indoor kitchen manage. Anyway, I needed to find something that worked and the most popular gas grill I've seen in campgrounds over the last year has been the Weber-Q so went out, checked them out, bought one. Great little grill and stays lit no matter the wind.
The one thing I've missed being out on the road is having an oven. There's been discussions of various ways to do it from little fold-down Coleman ovens you use atop a cook stove to dutch ovens. Turns out the Weber-Q works great as long as you figure out some way to deflect the direct heat. Started out just trying it straight up to see how bad it would be...Not good, burnt cornbread muffins...pretty crusty...
So, roamed Walmart and found a straight cookie sheet, a cookie sheet with holes in it (grill area, meant for veggies), some clips - Total = Less than $5.00...
Works great...no more crusty, singed muffins...
Did a big turkey breast (cooking bag) on it for thanksgiving and it turned out just right - Set the bag atop a piece of tin foil on top of the deflector sheets.
So, one turkey down, one batch of corn muffins down, wonder what I should try next - maybe an old fashioned hotdish.
Life is good :-)
Walmart is my last choice. I liked Fry's in AZ last winter because it is part of the Kroger chain. Stores are set up very similar and brands are same or close.
PXLATED - I have the Weber Q grill -- this is a great idea to put a cookie sheet with an inverted holed baking sheet on top!!!! I will try this. I love to experiment with cooking when I camp. I love good food and hate to eat out. Thanks!
In the pics, I have the two sheets clipped together. One could try with just the sheet with holes on there with the holes up and see what difference it makes.
Solid sheet was $0.88 - Sheet with holes was $2.88 <- Guess it costs a lot to punch holes
The temp in the Q only goes so low, so I'm guessing that your solid lower sheet probably goes a long way toward deflecting the heat from the flame/cast iron. Won't know for sure until we do some more testing, though. That's too bad, 'cause I sure hate having fresh baked goods in camp! :-)
On a related note, do you preheat the sheets or not?
The best thing is it requires very little fuel. We have a Coleman propane stove and I turn the burner down just about as low as it will go when using the Outback Oven.
Pxlated's solution does look interesting though!
ScottG - Ya, the Q diesn't do real low temps. Most of my baking is 300-425. Seems to work fine in that range. Have to monitor for the low temps. Yes, I put the sheets in, fire the grill, bring it to temp and then put the food in.
Baked Apples with brown sugar came out great last night.
Takes awhile to get it up to temp - gonna try it with just the pan with the holes next time - but holds steady once there. The medium setting gave me a nice steady 375 degrees.
Thermometer for the lid is on order. I'll have to measure for the pans, though; if you do have the larger Q that size may not quite fit on mine.
You can go through a lot of little Colman tanks when baking.
Burp!
As I've mentioned, the only thing I've missed on the road has been an oven.
