Well,  we picked up our new camper.   The dealer spent a couple of hours taking us thru the nuts and bolts of everything.  He showed us the Alde  control panel,  and like other comments here,  said that we should set it for 1 up,  2 down (we plugged into the house)  3 is up for heat/water,  and finally,  most times we could leave the control setting on the circle.  So,  we get home and want to check it out.    But... We just get cool air.   I opened the fuse box and the 15 and 30 switches were both up,  the rest down.   There is a red light lite inside the box.....  Moving on...  The lights work,  the ceiling fan does not.   There is a blue indicator light on the TV,  so I assume there is power there.  The Stereo does not come on.
Thoughts?
2016 NuCamp 320 T@B Max S
T@bbey  Road
Appleton,  WI
0 ·
T@bbey Road
Appleton, WI
Slider 1 should be on 2 lightning bolts
Slider 2 should be on electric (if you are plugged into electric)
Slider 3 should be on Alde heat and hot water (middle setting). (Upper setting is for hot water only.)
The dial is to be set to your comfort--it's for the Alde temp.
All ll circuit breakers in the converter should be on--I have 5 circuit breakers.
to blow in or out.
How long has your Alde been on? This is not forced air heat, so the boiler has to come up to temperature. I believe you said you are from the Appleton area, you are cold starting the heat in 30 degree temperatures. Also, turn your propane gas on, light a burner make sure you have gas flow, then set your Alde 2 setting up to the propane flame. You will get a quicker temperature rise through the radiators by supplementing with the propane heat.
Speaking of which, I guess I'll have to get one somewhere..
T@bbey Road
Appleton, WI
The "breakers" in the converter are resettable, just light your circuit breaker box at your home. "Fuses" can blow and will need to be replaced, such as the fuse next to the red light in the converter box.
Please do a search (upper right corner of this page) for fuses to get a list of spare fuses you will need for your T@B.
I had mentioned all of the stuff I've been printing to Joe the dealer, and he said you could have problems listening to "those people".. Sneer Sneer...
T@bbey Road
Appleton, WI
The light in the breaker box indicates a blown fuse. The fuses are like automotive fuses, with the amperage printed on them to indicate what size to get to replace one.
All the breaker switches should be in the 'on' position - I don't remember if that's up or down, but it's printed on the switch.
If you need to, take a photo of the breaker box switches and fuses for us, and the Alde control settings.
(Edit: corrected two three bolts)
I had the analog thermostat for the first 7 1/2 months of my ownership and camping. I wonder how many nights he has camped in a T@B?
Once you you get everything working (keep notes on what "those people" helped you fix), it would be a wonderful help to his future T@B owners if you would tell him how "those people" helped you.
And for the record, Joe Kicos and Little Guy pay for this forum so we owners can help each other. He loves that we help each other.
Keep fixing, use the search feature, read your printed notes, and keep asking. We'll keep the light on for ya.....
T@bbey Road
Appleton, WI
But, with our camper in the driveway, and our amused neighbors looking on, we are sleeping in it tonight...
T@bbey Road
Appleton, WI
With hot air, you'll feel the warm air blowing around - with radient, not so much.
Here in Buffalo, we have different levels of warm - That'd be cold, colder, and frikkin cold.
But radiant heat is the ultimate. We love it in both our 1860s plank farmhouse and our 2014 Model 'S' Tab!
To simplify the lighting bolts on the Alde when plugged into AC. One bolt - regular 15amp 120v household. Two bolts - 30amp 120v (commonly at campgrounds or if you installed a 30amp fuse in your household electrical box). Three bolts - Ignore (as stated before, the Alde is European and we do not commonly use 220v current for day-to-day use in our households.
And as RollingLagrima stated, check the two small fuses in the Alde compartment. They are located in a green plastic holder. Very difficult to see blown fuse as the fuses are small. Check with a multi-meter if unsure. The fuses are 3.15 amps and you should have extras that came with the Alde. Also order more online as local stores usually only carry 3 amps, which will not work.
Durango, CO
2015 S Outback
I'm still calling mine a radient heat system ;-)
This is what the Alde USA site says:
How it works
Nothing can compete with hydronic heating
Hydronic heating provides silent, even-temperature, all-round heating. Natural, slow air currents provide healthy air with natural humidity. Hydronic heating provides discreet, unobtrusive, quality heating. Not only does the furnace provide cozy, silent heating, it also provides a constant source of hot water for the shower and galley.
Alde central heating is a hydronic system that works on the same principles as those found in many of our homes. The heat source consists of a propane furnace with a 230 Volt electric element that heats a mixture of water and glycol. The hot glycol mixture is circulated through the system's convectors and pipes with the aid of a pump.
The convectors, which are located along the outer walls, heat the air. The air then rises and heats the walls and furniture. Because heat rises, a boundary air seal forms in front of the windows, which keeps the cold out. When the warm air reaches the ceiling it circulates down to the floor and is heated again by the convectors.
Every vehicle needs ventilation, i.e. stale air must be expelled and fresh air drawn in. The fresh air supplied to the vehicle should be led through an insulated air intake and then up through a convector with tightly packed fins. In this way the incoming fresh air is heated when the heating system is running. The stale air is led out through roof grilles and ventilators.
If the installation is done properly, the natural flow of heat from the Alde central heating system will wrap the entire living space in cozy warmth that keeps out drafts, eliminates cold zones and even warms bunk spaces and cupboards.
We also recommend floor heating to achieve a complete heating system with maximum comfort. The heating pipes under the floor are connected together using standard fittings and are controlled either manually or via a by-pass assembly for convenience.
If you look at this link, you can see that under floor heating is available with the 3010, but the T@bs do not have it.
Durango, CO
2015 S Outback
Or maybe it's a furnace with a hydronic heat exchanger. Is that different from a boiler?
And is it really a boiler if nothing is actually boiling? Maybe it's really a simmerer...
http://www.alde.se/usa/products/mobile/?page=4504
Durango, CO
2015 S Outback
T@bbey Road
Appleton, WI
And BTW Terry, the ceiling fan has a small switch built into it and unless you crank the vent cover up high enough (and far enough to activate the switch) the fan motor will not activate and run. Try cranking the vent cover and see if the vent fan operates as I'm guessing that this is the real issue here.
Here is some additional information from the manufacturer:
Q MY FANTASTIC VENT WILL OPEN BUT THE FAN BLADE WILL NOT TURN WHAT IS WRONG?
A The motor ground is made or broken using a plunger switch, located on the hinge side of the dome accessible from the top of the coach, this plunger style switch can become dirty, sticky, or corroded from the elements and may need to be cleaned with some emery cloth or replaced. Most of the time when a fan will not operate this switch is the culprit. The nut is a 7/16” size if this needs to be removed.
