I know. I know. There are a ton of battery questions and answers. But, being a newbie RVer who's picking up her new-to-me T@B tomorrow (!!!) I'm trying to determine if my thinking is right based on the many, many, many hours of reading this forum.
My husband and I have a weekend booked at a state park with no hook-ups. Originally, we were going to tent camp with friends, but now that we will have our new toy, we want to take it with us on our trip. BUT, we don't want to take the battery below 60% (per the discussions in this forum) and we don't have a generator or solar. We did purchase a battery monitor, so we can keep an eye on things.
We are totally fine just using the T@B for this weekend as a lovely tent alternative without using much power at all (I'm happy for this one to just not be sleeping on the ground.
Based on the info on page 31 of this awesome owner's manual (
http://tab-rv.vanillaforums.com/discussion/499/owners-manual-for-an-early-2014-s-m-x) it appears to me that we'll need 6 AMP hours to just exist -- so assuming for the 3 days that's 18 amp hours. We won't be using the fan, fridge, television, or radio -- and will use lights judiciously. My estimate based on this is that we should be ok for 3 days, but would love any sort of confirmation from more seasoned T@bbers...
Does turning on the propane stove pull any amps? I was assuming no, but this is all very new to us (and overwhelming really...though we are really, really excited.) Also, the water pump: is that running just when you're running water? Is it something that runs constantly if it's turned on?
Also, how much does your TV charge your battery as you're driving? Is it a significant source of charge? (Is this a dumb question? I feel like I have a zillion dumb ones!)
Thanks in advance. You've all already helped a bunch!
Live. Travel. Eat. Repeat.
2013 Orange & Grey T@B CS-S: Villa Ar@ncia
Follow my travels on Instagram:
https://www.instagram.com/cookwithkerrydotcom/
This was on the dealer installed 12V battery. We have since upgraded to dual 6V golf cart batteries which gives us a lot more power. Depending on your tow vehicle the charging through the 7-way is very small and more of a trickle charger. If you have a big alternator and good size wiring you may get better results.
Also note - do not depend on shore power and the on board converter to charge your battery, unless you leave it connected for a very long time. The converter puts out decent voltage but will shut the bulk charge off after four hours. Use an external battery charger like the Deltran Battery Tender Plus to charge your batteries to full.
The T@B we are buying is a 2013, so we might not have the digital Alde control panel. I'll have to research how to shut an older version down if we don't have digital. Also, we will be getting a CS model with the 2-way fridge, so no propane power for us. But, we'll keep it off. We'll be heading to Maine and are planning on mostly eating lobster rolls anyway. And a cooler will get us what we need this trip.
Follow my travels on Instagram: https://www.instagram.com/cookwithkerrydotcom/
In our experience the converter charges the battery just fine. We plug the trailer in the day before a trip to charge the battery and also pre-chill the refrigerator (on 120v).
You will love camping in your T@B. We also moved up from tent camping and now realize we should have done this years ago.
Enjoy your new camper. I've heard Maine is a great place!
Happy Trails Y'all
We are currently in Bar Harbor Campground - probably for another week. If you're in the area, stop in and say hello. Bring lots of questions if you wish.
Have fun!
Bob
Your Alde control panel may look like this. Make sure the far left slide bar (with the lighting bolts) is kept in the down position ("0") since you won't be on shore power. Move the center slide up to the propane flame about 1/2 hour before you need hot water for a shower. Slide it down to the off ("0") position as soon as you're done. The far right slider controls the cabin heater and hot water heater. The center position provides hot water AND cabin heat, while the top position just provides hot water (faucet only symbol). The rotary dial is the temperature selector. Start with the zero setting between 3 and 4 and see how hot the water is. Caution - the Alde can produce some very hot water! To eliminate any power consumption, simply move the three slide switches down to "0" when done.
http://wfcoelectronics.com/wp-content/uploads/2015/05/3-3-Operator-Manual.pdf
The paper manual that came with mine was similar, but also stated that the "bulk mode" activates only when the system voltage was less than "13.2" volts, or "less than 50%" of battery charge. This, however, makes no sense--I think it's a typo that should read "12.2" volts.
In addition, the paper manual adds that "float mode" activates when there is a no load situation for ~48 hours.
My voltage observations are consistent with the manual. When on shore power, I usually show ~13.6 volts (absorption mode). I've occasionally seen it drop to ~13.2 volts (float mode) after a period of disuse. I've never seen it go into bulk mode (14.4 volts), but my current battery has never been below 12.2 volts, so it makes sense that bulk mode wouldn't activate. I'll take it on faith that it will work if needed!
It's from the manual. Page 3 - Bulk charge - will switch to 14.4V for a maximum of four hours (it then goes into the absorption stage or the float stage). The manual does not indicate if it will switch back to bulk (14.4V) mode after a period of time. The absorption stage is only 13.6V which is on the high end of the Deltran Battery Tender float stage. This is a very slow charge and in my opinion a bit too low. That is just my opinion.
The manual does *not* indicate the amp charge rate, so four hours on bulk mode may or may not be enough to get through the bulk charging stage. If you have a small amp hour battery and the charge rate is good enough, it shouldn't be a problem. I had a problem on my dual 6V 230ah system and had to switch to an external charger to get the batteries charged to 100%.
I am a 100% off grid camper with no solar or generator, so I need to make sure I maximize the power available in my batteries.
My paper manual does state that if the converter cycles between absorption and bulk modes, it could indicate a "shorted battery cell or other issues."
I also find no info about the output amperage, but the implication is that four hours in bulk mode would be enough for a "typical" set up. @ColoradoJon, since your set-up is a bit beefier than typical, I can see why you might need to charge more aggressively.
Happy Trails Y'all
We won't be quite as far as Bar Harbor (it's on the list!)
It appears our model of T@B doesn't have Alde, but an Atwood furnace and water heater. I'll run some searches for info about that system.
Also it appears that our model only has a black tank and no grey tank. That was surprising to me after reading all about emptying both tanks. But I guess this makes it even simpler?
We enjoyed our first week of no shore power, but I was constantly checking the battery with both a voltmeter and the panel inside and found it would drop to 12.3 both in the morning and pm, we have a generator and I would charge the battery using a separate charger for an hour sometimes twice per day (the campground had generator hours of 11 - 5pm which made that hard as we were out most days. We barely used the radio/tv and fitted lights and used the pump as needed. We didn't use the roof fan and barely ran the fridge fan).
When we first had the trailer the car charge line was not hooked up correctly and I ran the battery dead twice by leaving the fridge fan on during our 5 hour drive.
Reading the above and other posts on batteries/power I now fear I damaged the battery, guess it's a good time to upgrade it before our next trip.
I will invest in solar even though we live in the PNW as I hated running the generator (its a Yamaha 2000w inverter type so very quite).
Any input greatly appreciated.
Happy travels.
Keep in mind that depending on what you are using for a charger, an hour might not be nearly long enough to fully top up the battery.
In October we are headed up to the Katahdin area of Maine. We are renting a T@B and spending a week at a campground with no hookups (planning to buy a T@B soon). We don't have a generator. I suspect we will want heat and refrigeration as well as lights. We can be judicious with the lights, but the fan for the heat and propane refrigeration are areas where I am concerned.
Am I in trouble?
Is it crazy to use my car as a generator?
(previous 2018, T@B 320 Outback)
I doubt you will need to run any fans for cooling purposes. The circuitry for both the fridge and the Alde require a little 12V to stay running. If you want cabin heat, you'll also need 12V for your Alde circulator pump. I don't know offhand how much power these devices require.
The water pump (if you plan to use it) and the lights tend to draw some juice. And you'll need some sort of lighting in October unless you plan to turn in pretty early.
With judicious use of a healthy stock battery (group 24) you may be able to squeak three days on a single charge, but who knows what you'll get with a rental. A week is almost certainly too long to go with out some sort of power infusion.
In theory--and assuming you have a functioning adequately sized 12V charge line at your 7-pin connector--you could use your car as a generator to run some 12V devices as needed. However, for various reasons it may not make for a particularly good battery charger. I've never tried it so I can't say for sure.
Have you considered getting a 100W solar suitcase to take along? As long as you get a few hours of good full sun exposure every now and then, you can camp indefinitely. YMMV depending on the conditions at your site.
https://www.amazon.com/Renogy-Watts-Monocrystalline-Foldable-Suitcase/dp/B00HR8YNK6
My conundrum is that I am planning to get a T@B outback S with the new factory solar panels. I don't want to invest in a suitcase when I suspect those will work for me.
If I do go that way, do I need the controller? Do I just connect it up to the battery terminals?
Be aware, however, that the stock leads on that Renogy are pretty short (maybe 10' at best). Sometimes it's hard to get the panels into the sun. I suppose in a pinch you could take the battery out of the camper and move the whole assembly to a brighter spot.
I don't know where you plan to do most of your camping, but one thing the northeast US and Canada have are plenty of trees. I almost never have a campsite where the T@B is in full sun, and sometimes even getting the portables into the sun is a challenge--despite having 35' of extension cables and the panels deployed full time.
I've noticed that while a 100W suitcase does a great job given a few hours of full sun, any amount of shading severely curtails their output. Under such circumstances, the panels still help, but my battery still slowly depletes over a period of days.
If you are planning to do extended dry camping in forested area, you might want to consider the advantages of a portable panel in addition to (if not in place of) panels permanently attached to the T@B.
I'd be interested in hearing others experiences with using solar (permanent or portable) in shady locations.
