I have read a few threads describing bugs being able to get in through the window screens. This is a problem for us because my wife is a mosquito magnet and swells up like a banshee. Her bug bites continue to itch for at least a week after she gets them. So dealing with mosquitoes is a critical issue.
I found these skeeter beeater screens that magnetically attach to vehicles to allow the windows to be open and keep mosquitoes from entering. I am thinking I may need something like these to fully insulate the forthcoming T@B from the vicious little buggers. The only problem is that the screens attach with magnets. I am guessing that the window frames are aluminum which means that the skeeter beater wouldn't work. What recommendations do people have for a way to make sure a T@B is completely sealed from bugs (and please don't tell me to turn off the lights, they will smell my wife and come in anyway).
http://theskeeterbeater.com/
T@B 360 Black Canyon, 2021 Jeep Grand Cherokee V6, Maryland
(previous 2018, T@B 320 Outback)
0 ·
Check this idea out:
http://tab-rv.vanillacommunity.com/discussion/comment/47441/#Comment_47441
I do have a ThermoCell that I use to keep them away when outside - Works pretty well.
And you're right, everything is aluminum.
There is a diy adaptation to make noseeum screening covers for the windows of the t@b 320, but the same technique will work for the 400, simply changing the screening measurements to fit. This adaptation has weaknesses, as it does not have noseeum protection designed for the fan screen or screen door, but does get the mental gears turning. Good luck, and let us know how the adventure goes.
On a side note has anyone looked into changing out the blue ceiling light in the 400 with an amber light? The blue light is one of the most attractive colors for bugs. With the faulty screens it'd be nice to at least be able to have some sort of interior light on that won't attract so many bugs.
Place the magnets in accordance with the magnets on the screen so you dont have any large gaps. probably not the most aesthetic solution but it will allow you to attach the screen in the TAB. You could also try a roll of magnetic tape but in my experience the glue on the tape doesn't hold very well and quite soon peels off.
Ontario, Canada
2018 Tab 400
Ford F150 2.7 Lariat
When they do get in a small USB rechargeable hand held vacuum should work to grab them as they like to land on the ceiling. I'm thinking it will beat smashing them on it and making a mess to clean up.
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
Kevin
Kevin
"The only place where you start at the top is when you dig a hole"
Will post some pics when I get organized from unpacking.
"Just Enough"
"Just Enough"
