I am interested in a T@B S, but I don't really like the idea of having a black water tank for the toilet. I like the idea of the keeping the shower with the gray water tank and then putting a cassete toilet--the Thetford Porta Potti--in the shower when needed.
- Does anyone know if Little Guy would make that sort of customization.
- Has anyone done anything like this?
Thanks,
marc
T@B 360 Black Canyon, 2021 Jeep Grand Cherokee V6, Maryland
(previous 2018, T@B 320 Outback)
0 ·
I am am kind of wondering to myself if they are more concerned with a larger rv or camper discharging a large tank into the pit toilet, filling the pit toilet too fast.
The grimy hose is one of the things I don't want to deal with. Are you saying that you can discharge it into a bucket without making a mess on the T@B? That would be easier than monkeying with hoses.
I find the hose to be less icky than dumping a bucket. Once you drain the gray water it's pretty clean. I can just see too much going wrong carrying a bucket of that into my bathroom.
2022 Ford F350 Tremor | 2022 Cirrus 620
As far as those ridges - the outside ones never come in contact with bad liquid and when I'm at a relaxed dumpsite I fill the hose with a bleach/water mix and let it sit for a bit. Bet my hose is cleaner than your bucket :-)
A relaxed dumpsite is one where there isn't anyone else there - you can take however long you want.
Outside ridges / bad water - By bad water I'm referring to the black tank - So nope.
When I hear "cassette toilet", I think of the ones that are masserators and you pull the waste tank out the side and go empty it. That module is called a cassette. Looked into them years ago. Don't know if Thetford still makes them or not.
I have used a 5 gallon bucket with a lid to dump at home when I forgot to stop at a dump station. I pour it into the toilet in the house.
Dumping your tanks is only as hard as you make it. If I wear my blue medium weight nitrile gloves, everything will be fine.
And, yes, an occasional rinsing of your hoses with a mild bleach solution will help if there is a lingering odor in the hoses.
2008 DM T@DA — Towed by 2014 Dodge Durango — Full time since 6/29/17
"Travels With The Tiny"
Since there would be no real modification (since it would be just not putting the toilet hardware in and a cap for the black tank pipe) I can't see there would be any (or at least not much) of an extra charge for modification. Sadly you probably wouldn't get a savings for whatever the toilet costs, though! hahaha
2018 T@B Max S silver and black (aka TadT@B), Full-timing since July 2017
The other idea is just asking nuCamp if the manufacturer makes a shower only enclosure - then no possible leaks and water line mods or black tank involved - plus you have a warranty for not doing any mods.
I'm curious what you find out! The folks at nuCamp are so accommodating. I wish you the best!
When they are available I use pit toilets, but nature calls at midnight too.
Many/most T@B owners seem to frequent developed campsites and this changes the calculus on these basic decisions.
IMO, much of the attraction of the T@B was the elegant simplicity of every feature. Many aspects of the LG T@Bs have become much more complex.
