Since owning my 2019 Tab 320, I've pretty much just towed locally. From the dealership to home and local campgrounds all of which less than 30 minutes away. Occasionally around my neighborhoods to "practice" and towing and backing up. Towing, which was/is new to me, and generally OK though nervous and paranoid the entire time. Every bump, rattle, etc. makes my heart jump. I did get a hitch tightener which helped and seems better when packed up some rather than empty. Fyi...my TV is a Kia Sedona (3500 tow capacity); towing hitch, brake controller, etc. all installed by our dealer whom is great and I trust guided and outfitted us appropriately.
But soon I'll be taking a much bigger trip about 3-4 hours away and am getting more nervous as I get closer. When you were a "newbie" did you have the same nervousness? If so, what things did you do to alleviate you?
Any advice, reassurances, warnings, etc. are welcome.
0 ·
Backing a short trailer is a challenge. Try not to be too fussy. Learn to find pull through spots to stop so that you don't need to do more backing up than you need to.
You can practice backing...do that before your trip but know that half the fun the RV'ers have in organized campgrounds is watching newbies struggle with their gear. Some will offer to help out and all of them with have opinions and advice. It goes with the territory.
One thing that that it helps to remember is that if your TV can make it through, the trailer will follow.
It's the towing that has given me a little stress. Every bump, constantly looking on rear view mirror. Just not used to it yet I guess (hope).
Smooth driving helps, no quick steering or brake inputs if you can avoid it, leave more following distance and think ahead.
Learn to use and trust both side mirrors and check them very often.
Practice, practice, practice!
When driving your #1 priority should be driving, especially true towing, high alert at all times is good!
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
Concord, NC
- It is good that you are aware of bumps and rattles (and smells, like burning rubber or brakes) as suggested by @Mouseketab. If it is a smell (e.g., burning brakes), I usually give it a little time before I worry, to see if the smell goes away. A lot depends on where you are. For example, if you are at the bottom of a steep grade, starting to head up the hill, and smell something like that, it may actually be coming from a truck on the other side of the highway that is coming down the grade and riding their brakes too much.
- A bump here and there is usually no big deal and normal, but if it is a thump-thump-thump, or your tow vehicle or trailer begin weaving slightly and things just don't feel right, it could be a flat tire. The key is not to panic and to gently slow the vehicle and pull off along the side of the road or onto an off-ramp if you suspect there may be an issue with either your tow vehicle or trailer.
- As has already been mentioned, plan ahead and change lanes in advance of when you need to so that you can be sure you have plenty of room before switching lanes. Be sure to turn on your turn signals well before changing lanes so that drivers behind you are aware of your intention and will hopefully slow down to allow you sufficient room to move over safely.
- When making turns at a corner, especially when turning right, be sure to pull forward a little further before beginning your turn so that you do not cut it too tight. Same goes for turning in alongside the gas pumps at a gas station or truck stop.
- Consider purchasing a couple small round blind-spot mirrors and attach them to the lower outer corner of your side-view mirrors. If you are not used to driving with blind-spot mirrors, they may take some getting used to, but they are extremely helpful. They have saved my bacon more than once when I had to react quickly on a freeway, or when I had to make a last-second decision to change lanes. Beyond that, they just make it a whole lot easier to see vehicles that are driving alongside you and your trailer (in your "blind spot.") They are also extremely helpful when backing, because they help you see objects on the ground or alongside your vehicle, which might not otherwise be noticed when backing. Once you get the hang of using them, you will never want to drive without them.
- Learn how to properly down-shift your transmission when climbing or descending a steep highway grade. Let your transmission do the slowing on downgrades so that you are not riding your brakes. Downshifting on downgrades will also help you maintain control of your tow vehicle and trailer. Use a lower gear for extra power, if needed, when climbing a steep grade.
- Pull-through sites are not always available, especially in state parks or forest service campgrounds. Therefore, when backing into a campsite, I find it easier if I approach the campsite (when able) from the left (driver side) of my tow vehicle. It is easier, because it allows you to more easily see your backing path from the driver's side mirror. Also, as mentioned, because your trailer is short, you generally don't need to make sharp or wide backing movements. It also helps when approaching a site to slightly drive into the site entrance and then curve your tow vehicle outward and away from the campsite entrance a sufficient distance before backing into the site. This method is a good way to properly align your trailer for easier backing into the site.
- If you have not already learned this simple trick, when backing, it helps to put your hand at the bottom center of the steering wheel and turn the steering wheel with that hand in the direction you want the rear of your trailer to go. Move the steering wheel to the left and the back of your trailer will move to the left. Move the steering wheel to the right and the back of your trailer will move to the right. Give this a try in a parking lot and you will see how easy it makes backing up.
Beyond that, the advice to relax and enjoy the ride is probably the most important tip.(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Greg & Marlene (Tucson, AZ)
I stop at a gas station about 10 miles from home just before I get on the interstate and do another walk around checking all the various connections.
Tampa FL
https://www.amazon.com/dp/B001AJH1HK
After my first experience pulling the Tab, I am especially careful now about making wider turns at sharp corners, and the wider mirrors helped teach me how wide I need to be. On our very first trip after picking ours up at the dealer, I had to make a right turn at a city intersection onto a narrow street with a sharp vertical curb; but I was not wide enough & the wheel hit the curb & jumped up over it with a jolt. We ended up with a ding in the alloy wheel, but it survived otherwise. I had been accustomed to pulling a narrower 5x10 ft utility trailer, so was not new to towing a trailer. The mirrors make a big difference, once you get used to using them.
RV: 2018 T@B 320S, >100 mods
I use a very detailed checklist, which helps alleviate the worry of forgetting to do something.
One item I bought that made me feel better last year was a TireMinder. I always worried I wouldn't notice if the tires were going flat and any bump or odd sensation caused me concern. I could only see the drivers side tire in my rear view mirror too. I bought the version with four caps, but just use two on the trailer. I also had the valve stems on the trailer tires replaced with high pressure valve stems. (I actually also bought new Good Year Endurance tires). https://www.amazon.com/gp/product/B0797MT15V/ref=ppx_yo_dt_b_asin_image_o01_s00?ie=UTF8&psc=1
San Diego, CA
www.airbossone.com
The high pressure valves and tire pressure monitors are also a great idea. I have done the same.
https://www.amazon.com/Drive-Safe-Ultimate-Eliminate-Parallel/dp/B07G2PFZ38/ref=pd_di_sccai_20?_encoding=UTF8&pd_rd_i=B07G2PFZ38&pd_rd_r=c16486c1-ba44-4d9d-801e-3d3e2516b8d5&pd_rd_w=T88ij&pd_rd_wg=ptW7J&pf_rd_p=61ce50cf-2379-4458-9044-fa8b402c702d&pf_rd_r=REEE2ZWDDSDCKTQ55Q65&psc=1&refRID=REEE2ZWDDSDCKTQ55Q65
San Diego, CA
www.airbossone.com
Pulled by a silver 2017 Chevy Silverado
Leaves on T@bventures from Spokane, WA
2022 Ford F350 Tremor | 2022 Cirrus 620
I agree, I always start out super cautious and a little nervous. @Mousketab nailed with sounds and smells, and I would add feels. Be aware if you hit a patch of vibrations. Is it the T@b or just a bad section of concrete or a groved stretch of road? I almost always hit a patch of road that has me nervous that something is amiss and it usually ends before I have to pull over and check.
Make sure you monitor your tires. Check your tire pressure before you leave and it doesn't hurt to check it part of the way through your trip and before you leave to come home. I do try to check mine every day.
Other drivers were surprisingly nice about letting me in, accomodating our length, etc. Especially truckers. Maybe it's just a Virginia thing, but other drivers seemed more courteous.
So many whether towing or not, got one thing in mind and that is the destination as fast as they can, damn anything and everything else including safety.
Practice first — find a big empty lot, or other no traffic area, and hook up and un-hook the trailer, try changing the tyre, and practice backing up, where you have room and can see around the trailer. These are all skills we need to learn when first starting out.
I would also add to check your brakes and bearings for overheating as you drive along, especially at highway speeds.
2020 T@B 320 Boondock
Factory Victron Solar, Norcold 3 way Fridge
Clueless about everything electronic
2020 Subaru Ascent
Bainbridge Island, Wa
No, I haven't really noticed any increased noise.
Our Sienna mirror has a flat black plastic finish that hasn't suffered any adverse effects; although, it's 15 y/o, so we're not too concerned about cosmetics.
These mirrors are very secure when properly installed & tightened using the ratcheting straps & clipped properly over the edge of the mirror housing. I can imagine, though, that there may be some cars with mirror designs that just don't fit well with these clip-ons.
We've used them for over 5K miles in a variety of conditions, including 2-lane roads with trucks. We don't typically have the high winds that western states may have, but have driven at 70 mph on interstates before without any issues.
Only negative so far is that we are not able to use the Sienna's mirrors, because the clips interfere with its range of motion; but that's no loss, as I only use the wider ones anyway.
