After reading previous posts about the benefits of upgrading Fantastic Fan to 7350 in my 400. I upgraded prior to a recent 3800 round mile trip to Florida which included some dry camping (Walmart, Cracker Barrel ..) and from 14 to 86 degrees. After the upgrade, the fan not only was remarkably quieter, had fourteen speeds instead of three and had a handy remote control but it appeared to be less of an energy hog. I received a Camping World catalog yesterday which had an interesting table of Amp Draw comparison between the three speed fans and the 14 speed Model 7350. The three speed fans draw 3 - 2.29 -1.86 A at Low, Med and High speeds while the 7330 only draws 0.2 - 1.9A throughout its speed range (low to high). Pretty remarkable that the draw at low speed is 15 times higher with the three speed fans.
I know others have noted increased efficiency with the upgrade but to see the actual numbers highlighted the advantage during dry camping even more.
2013 Tundra TRD 5.7L
Massachusetts
5 ·
Massachusetts
2018 320 S - "No Agenda Hacienda"
Tow Vehicle 2023 Honda Pilot AWD
Massachusetts
The factory was not aware that I, and many others, were not able to regularly use the 3 speed FF while boondocking due to the heavy power consumption. I can now use the upgraded fan daily to exhaust the heat (it’s finally getting warmer in the desert!). The remote control is an added plus.
2016 T@b Q
Lakeville, MN
For those of us not ready to invest the $$ of an upgrade kit, you might review the discussion to change the 3-speed FF to variable speed.
The remarkable thing to me is the fan motor and fan blades are the same but the performance and convenience is quite different with the bonus of significantly lower energy use at all speeds but the highest. My DW loves the fan and the ease of control.
Massachusetts
I can only assume it refers to ones spouce. But I’m guessing....
Dear Wife
Dim Wit
Dead Weight
Delightful Wonder
Massachusetts
Would you mind posting a link to the kit which fit your 400? Seems like a great boondocking uppgrade
Massachusetts
Massachusetts
Massachusetts
Massachusetts
It seems the remote only seems to want to work if I have it pointed directly at the fan in a very specific location. And it's pure luck if I hit the right spot.
Anyone else have that issue and have a fix? I searched to the end of the internet and have not found anything about it.
Massachusetts
Massachusetts
Now to experiment and see if I can program my Logitech Harmony remote to work with it so I can have everything controlled with just 1 remote, multiple remotes laying around irks me to no end
Jeff & Amy
2019 Ford F-150 3.5L Ecoboost with Long Bed
Massachusetts
