What kind of camera can I get to keep an eye on tailgaters on two lane roads? I don’t need a back up camera that only works in reverse but one that works while driving. Or is there a set of big mirrors I can buy that will let me see behind?
2017 Tab 320 S
2014 Mazda CX 5
Traveling very light to be kind to my transmission.
0 ·
As for mirrors, there are extensions you can buy for very little that snap onto your existing ones. I had a pair and they worked well.
https://www.amazon.com/Fit-System-3891-Universal-Trailer/dp/B001AJH1HK/ref=sr_1_4?keywords=Extended+View+Tow+Mirror&qid=1553533659&s=gateway&sr=8-4
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
NUCAM WR WATER RESISTANT HD WIRELESS CAMERA WITH NIGHT VISION, MAGNETIC BASE & BUILT-IN BATTERY
The magnet is one seriously strong magnet but there really isn't anything on a TAB to attach it to. I fabricated a steel plate and attached it to a quick-release plate to mount it on my tripod. I set the tripod on the bed pointing out the window.The camera is really a nice camera. It gives a good view behind but only has a 100 degree field of view. That however is enough. By the time a passing vehicle leaves the camera view it is well into my side mirrors.
The really nice thing, in my opinion, is that it does not require a monitor mounted on the dash. The signal is sent via bluetooth to your cell phone or iPad. You can record the signal on your iPad or phone to review later if needed.
The internal battery is usb rechargeable and the camera will function while plugged in. So far, for me, the camera batteries have lasted over 10 hours of continuous operation without being plugged into a USB port. A full charge (they say) takes 4 hours, so plenty of time overnight to recharge.
It is a bit pricey at $210.00 but has worked well for me.
The view is about like the view on a vehicle backup camera--"objects may be closer than they appear'--but you soon adjust.
Of course, neither of these techniques are as good as upgraded equipment, but they do help if it's all you have to work with.
Huntington LI
You should already be towing with enough mirrors to see down both sides, if not correct that, any wider mirrors may help, but not much if traffic is totally behind the trailer.
Odessa, Fl.
It surprised me at first, I expected folks to be in a big hurry, and intolerant, but no!
I take the same attitude as @GatorEgg, and pay attention to what's ahead of me, letting the folks behind me do the same. I've got enough to worry about here up front!
I'll keep a close watch in the side mirrors for 'passers', but that's all I can really do, is be aware.
emergency vehicules often comes from behind and all bit police cruiser have the acceleration to pass when ever they want. Some roads are just way to dangerous to attemp passing w/o the vehicule in front slowing down or moving a side just a tad.
But all this can not happen when you just look foward, thinking that what is behind you is none of your worries.
i am a Paramedic and a traveler. In our neck of the wood, we only have one road and it is a two lane with only a couple passing area, many turns and many hills! And that road is more than 400 miles long, no divided highway at all, no service road, hardly any dirt roads parrallel to this. So sharing the road is very important.
so not taking care about what is behing you, when you are simply driving around, and site seing at the same time ( yep, the panorama is also very nice) creates a lot of frustration to the people following, and at one point, some will take a chance and double when it is not the right time. So seeing what is behind you allows you to slow down a bit when a passing area is available, and or move a bit to the side and slowing down will let some drive by in a safe manner.
it will not prvent tailgaters, but it will rduce pressure from time t time.
the paramedic in me will thank you by hazzard blinking of some kind of signal light if I am in my personal vehicule.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
I used to haul a sailboat up to a lake at 7500' each summer. I did this for 10 years so I knew the road pretty well.
One year I was trucking up the mountain and there were a couple of guys in a beat-up old pickup truck in front of me who ignored every pull-out for at least 10 miles. I'm sure that it never occurred to them that the chick hauling the boat wanted to pass them. 😂
T@bbey Road
Appleton, WI
However, this option on Amazon looks to be rated quite a bit better, but needs to be hard-wired. I assume the Tab400 has a license plate light, anyone know if that's a valid option (compared to brake-light wiring)?
2024 T@g 5-wide Black Canyon
I see from the manufacturer's website that it released new firmware in November 2018. I am hopeful that the bad reviews are because the prior firmware was buggy and the update corrected the connectivity issues.
"XEN@ Road Warrior Princess"
Portland, Oregon
Looks like a good plan. 42" should be high enough to see vehicles behind you and certainly enough for backing into a campsite. If you mount it outside the trailer I would rig up some sort of safety cable as well. That magnet on the camera is pretty powerful but vibration and potholes may slide it off the metal plate.
I mounted mine on a tripod sitting on the bed in my 400 and looking out the rear window. That puts the camera at about 70" off the ground. 42" or 70", the view will be about the same if you have a semi right on your tail!
The orange bags are 5 lb sandbags from The Sandbag Store. The idea is to keep the tripod and camera from bouncing around when I go over the whoop-de-do's on our Interstates. If the tripod moves out of position the camera focuses on the window and not through the window. Rather disconcerting until I realized what was happening.
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
Two nights in in a row, I almost T-boned a car in a roundabout because the mirrors hid the cars from my vision. Scared me!
If you use extended mirrors, be very careful of the big blind spot.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
I have several theories why people might tailgate. I think that since the 400 has such a high profile, people get behind the trailer and stay up close in an effort to draft (if you will) and reduce the effects of wind drag on their vehicle on long stretches of interstate highway driving. Others might be trying to see inside the trailer and determine the manufacturer. The last time I was at the factory I picked up an extra nuCamp emblem, mounted it on the drivers side of the trailer and suggested to them they put an emblem on the drivers side too (as opposed to just the passenger side) so people can identify who built it.
But I agree, it’s frustrating when people tailgate on interstate highways. There have been times when this occurs on long stretches of interstate and if it irritates me I turn on my turn signal and will get over and ride in the passing lane if conditions permit. This usually works as the tailgater normally moves on up the road and things return to normal. When I see traffic ahead starting to slow down I also flip on my 4-way emergency flashers to alert drivers behind me that a problem is coming up and to eliminate someone rear-ending the trailer.
Distracted drivers who text and drive are the biggest safety concern out there today (along with alcohol & drugs) and this is another reason you need to know who’s behind you. I’ve seen it all and it’s a sad day when professional semi-truck drivers are texting, watching TV, etc. and not paying attention when hauling a 10K pound plus cargo laden rig down the highway and swaying from dude to side, going off the edge of the road, etc. You know who the real professionals are by their attentive and courteous actions.
On an interstate where there is lot's of room for passing...that's annoying. Worse yet is someone that pulls into your blindspot and hovers there without moving by.
