Hello Fellow Campers.
I am new to camping and I don’t know a lot about batteries, but I feel like my battery is discharging too quickly. I am currently on a camping trip and following is what I observed last night......
6:50 pm - 11.91v - 41% - I know I should not let the battery go below 50%, but I can’t seem to keep up with the charging.
7:00 pm - started charging with generator at 29.1 Amp, 373 watts.
8:00 pm - stopped charging and battery read 12.47v or 87%.
9:20 pm - battery read 12.23v or 63%. I did this reading because I understand from previous discussions that the battery will read higher than actual right after a charge.
9:00 am - read battery at 11.94v or 44%.
So the battery discharged from 12.23v to 11.94v overnight. All I had running overnight was the fridge at a setting of 2.5, water pump briefly to brush teeth, bathroom light briefly, and any parasitic drain. I feel like the battery is discharging too quickly.
Does this seem normal based on other’s experiences? Am I just expecting too much from my battery?
I am using a Victron BMV-712 battery monitor to do the above readings.
I have a Tab 400 with the 2 x 6v batteries.
Thanks!
Dan.
2019 Jeep Cherokee pulling a 2018 T@b 400.
Victoria, British Columbia.
0 ·
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Additionally, an hour of generator use isn’t sufficient to really charge a single depleted battery, let alone the 2 large batteries on your 400.
Two things you can do - plug it in when you get home and just leave it for several days to let the converter give you a full charge (and/or use a separate battery charger).
Then go into your BMV settings and hit the “synchronize” button in the settings so it knows you’re at a full charge. That should set 100% to 100%. While you’re there, make sure the battery capacity is set correctly as well. This is easiest in the Victron Connect app, but you can follow the steps in the manual to do it directly on the unit as well.
If you have the stock 2-way fridge (rather than the 3 way that comes with the 320S) it really shouldn’t eat up too much battery. We have the same on our CS-S and can get through a weekend easily without depleting the battery.
There are many unanswered questions....age of the battery's, what does the victron show as the current draw from the battery? That is the big question.
@dCliffhanger there are charts that circulate on the internet that give rough approximations on remaining battery capacity. The issue is they don't take into account age, temperature, or any history of battery. In my book it is a slight step up from the provided 4 light panel. The only way to know for sure is an inline amp meter
@webers3 - the 2018 400 comes with a 2 way that is pretty efficient.
https://tab-rv.vanillacommunity.com/discussion/8650/unofficial-nucamp-t-b400-resource-guide-finalized#latest
Your resting BMV draw should show 0.35 amps per line #2 of the chart where it says "Always Running" with everything turned off. Then, cycle-on the things you use each day and compare your draw numbers to the chart. If your numbers aren't way off then it's possible you have a bad battery cell and the battery isn't holding charge. Testing that will be a bear so first go through the process of looking at your BMV history for total battery energy drawn & absorbed from one day to the next. Post what you find and perhaps the helpful forum members can provide additional insight.
As far as putting an ammeter in series with your battery, with your Victron system, that is actually what you already have. The Victron utilizes a shunt in series with the battery set to measure current. That's what an ammeter does.
2 AGM 6v batteries can take a while to charge. If it were me, I would charge it with a smart charger to 100% and then reset the BMV 712 to calibrate. I would then. Then, next time you are out, pay attention to how much power you are using. Remember, the SOC, not the voltage is what you should rely on when you have the Victron. The voltage, as SAM said, shows your load.
You can use your BMV-712 to compare your T@B actual to the column called "400 AMPS"
Page 53 of the Resource Guide which can be found at
https://drive.google.com/file/d/1CTxMp8mzJ_tvvVb9FjmXF63E5WXZCO-2/view
Or use the full thread here:
Sorry I haven’t responded to any comments since I wrote the original post. I was camping with unreliable internet. I’ll try to answer some of the questions and provide additional information.
The fridge in the Tab 400 that I have only operates on electricity. I wish Nucamp would have installed a fridge where you have the option between battery and propane power. Has anyone out there ever tried to change the fridge? Any idea if this is even possible? I assume Nucamp did not rough in a propane line to the fridge area.
I only ran the generator for one hour in the example because I got back to camp late and only had an hour left. The provincial campgrounds allow 2 hours in the morning and 2 hours in the evening. Although running the generator 4 hours a day or running it every day is not a good way to make friends.
The batteries are brand new. This was only my 3rd time using the trailer.
I did not start the trip with 100% charge. I live in a condo and the storage facility where I leave the trailer does not have a plug in. I charge it as much as possible with the generator in the storage facility, but it would take a long time to get to 100% off the generator.
The current draw with the fridge off is 0.2 amps.
The current draw when the fridge switches on is 5.0 amps.
The outside temperature was 75 during the day and 55 at night.
My tow vehicle has a charge line. It delivers 8.7 amps / 103 watts while driving. Not a lot, but helps a little.
Based on all the comments and feedback, I am thinking that my battery is performing normally. Perhaps my expectations were just too high. Once I understand the limits, I can plan around them.
Another question. I live in British Columbia and our provincially owned campgrounds do not have electric hook-ups. I really want to start camping and exploring in the US. Do state owned campgrounds have electrical hook-ups?
Thanks!
Dan.
Just a word of caution, although AGM batteries are great, low maintenance items, best practice is to always fully charged prior to storage. If you can find somewhere to plug in a smart charger compatible with your battery before storing and charge it fully, you would be able start your trip with a full battery. Good luck!
Addressing a couple other things:
NuCamp does offer a 3 way fridge on the 2019 and 2020 Tab 400, but you sacrifice the closet area for that. I would imagine retrofitting a 3 way would be pretty pricey. My understanding is that the 2 way is fairly efficient on battery overall, but to use it that way all the time, you have to have a way to recharge efficiently as well.
You might also consider whether or not solar would be helpful in your situation. It’s tough to get enough sun in the northwest, but anything it added would be better than nothing, and unlike the generator there’s no noise limitation. As far as charging in your home area goes, do you have a friend or family member that can host the trailer overnight before a trip and offer you a power outlet to get to a full charge? Or can you occasionally use a full hookup park? Keeping the batteries in a constant discharged state can shorten their lifespan considerably, and the 400 does not use cheap batteries.
If you have solar on the roof it will also charge and maintain your batteries while your trailer is in storage, which would eliminate the problem of starting out with a less-than-full charge.
https://www.dcr.virginia.gov/state-parks/find-a-park
A few few people have mentioned getting solar panels installed on the roof. Certainly something to consider. Would I need to order these from NuCamp or are there good aftermarket suppliers? I’m a little worried about a dealer drilling into the roof to install solar panels in case it creates a leak. Has anyone had a problem with leaks?
Thanks.
Dan.
