Rovnblood posted a similar thread about this:
https://tab-rv.vanillacommunity.com/discussion/10725/5-37-amp-phantom-draw#latestI decided I would start my own thread since I have a 320 with no inverter.
I had issues with the stock battery that came with my tab. It was dying in the middle of the night. So I replaced it with a 100amp battleborn. But the same thing happened on Friday night. I was boondocking and the battery was charging fine all day, but then it just died in the middle of the night, leaving me with no heat.
When I got it home I hooked up an amp meter. I didn't have anything inside the tab turned on. No lights or heating system. But there was a 5 amp draw.
Does anyone know what could draw that much power? That seems like more power then even the refrigerator would pull.
I didn't even know about the E brake on my T@B. Where would I check that on a 320?
Thank you for the picture. This is a picture of my brake switch.
Am I supposed to have a cable there?
This photo and labels may be of assistance to you:
You are missing the cable to the left of your brake switch. The cable connects to your tow vehicle. Here’s what it should look like (2019 model, ignore the screw protruding above the loop in mine, that’s from the sway bar mount):
Is that something Uhaul should have installed when they installed my hitch and plug? To be honest, the techs at Uhaul didn't seem to really know what they were doing.
Have I been towing my T@B with the e-brake on this whole time!!??
Uhaul installed the Curt Echo bluetooth brake controller.
Be brave. Take risks. Nothing can substitute experience.-Paulo Coelho
https://www.amazon.com/Fastway-Foot-Breakaway-Cable-80-01-2160/dp/B004TR4IGW/ref=sr_1_1_sspa?crid=1T1ZP5YMIRXSQ&dchild=1&keywords=trailer+breakaway+cable&qid=1587939709&sprefix=trailer+break%2Caps%2C201&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExOEtEWTYyQzVEMklHJmVuY3J5cHRlZElkPUEwOTg4MTk3T0gzRk8xWTVWT1ZaJmVuY3J5cHRlZEFkSWQ9QTAxNzEyNTEzS0lGMzlHVVBUTTMwJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Since you have a brake controller, the new cable should work without any issues. Just plug the plastic pin into the breakaway switch and the other end of the cable, which has a loop, attaches to a secure point on your tow vehicle. You can research how to connect and use it on eTrailer.com or YouTube, or a general "Google" search. Also, take a look at the video on the post that @Sharon_is_SAM created.
Not only will you need the new breakaway cable for your electric brake system to work as designed, but (other than cutting the wires, which you don't want to do!!) you will need that pin inserted fully and securely into the breakaway switch to cut the constant flow of electrical power from the trailer 12V battery to the electric brakes. Otherwise, as long as your trailer battery is connected (without that pin inserted), it will continue to be drained since it will be sending full power to the trailer brakes.
Until you have the opportunity to replace the breakaway cable, disconnect your battery and re-charge it. Leave the battery disconnected until you get the new breakaway cable installed. Once you get the cable, you should then be able to tow the trailer safely. HOWEVER, be sure to adjust the brake controller as described in the brake control manufacturer's instructions before towing the trailer too far.
I just noticed that your trailer is a 2020 model, so if you have not driven it too much, the brakes and bearings should be OK. Regardless, if for some reason the dealer accidentally disconnected the emergency breakaway connection before delivery of the trailer to you, then they should check it all out for free to make sure everything is OK. Have them go over the braking system with you again............and, if they did not go over the trailer features and operation (inside and out) with you when you purchased it, have them do that for you. That is standard practice for a dealer and should have been done, if it wasn't.
(NOTE: The only other likely explanation for the pin being gone/pulled out is possibly that you were simply unaware of its existence and it became disconnected when you unhitched the trailer, assuming you have unhitched it, that is. However, if it was connected when you took possession of the trailer, the other end of the cable would presumably still be connected to your tow vehicle.)
I ordered a new cable from Amazon and I am making an appointment to have the brakes checked. I drove it about 500 miles and I am pretty sure the E-Brake cable was out the whole time. Better to have them checked just to be sure.
But, if he had the battery disconnect turned to off while towing the brakes wouldn't engage, right?
Tampa FL
When towing (tow vehicle ignition on), if properly wired, your tow vehicle seven-way wiring provides an electrical connection directly to the trailer's electric brakes, regardless of whether the trailer battery is connected or disconnected. HOWEVER, and it is a BIG HOWEVER, it is very important that your trailer's battery also be connected while towing so that an independent electrical connection to the trailer brakes is available in the event that your trailer should somehow become disconnected from the tow vehicle. The whole idea of the emergency breakaway switch is to immediately engage the trailer brakes and stop the trailer in the unlikely event of it becoming completely detached from the tow vehicle.
I too would expect some very noticeable drag of the brakes/wheels if the electric brakes were fully engaged during towing. There would also likely be noticeable smoke from the brakes or tire rubber rapidly heating up. The only thing that might prevent that from happening is if the brakes were not properly adjusted (i.e., very loose.) I'm guessing that maybe the brake cable was attached during travel, but somehow became disconnected during the unhitching process (although I would think that the other end of the brake cable would still be connected to the tow vehicle.)
@elbowwilham, can you shed any more light on this for the benefit of others on the forum? I know I would appreciate the info. Looking back on it now, do you recall any issues with the brakes while towing over the 500 miles?
I always disconnect the battery and close the propane before taking off. Never was told I should leave it on. Now I know, and knowing is...
As I mentioned before the fuse from my battery to my electric brake kept blowing about 10 minutes after driving. This would be the BLK cable into #6 on the chart above.
I just left the fuse out for the rest of the trip.
So with the battery off and the fuse to my trailer brake blown, its possible the brakes were not engaged?
Is your Tow Vehicle (TV) blowing a fuse? On Ridgelines that is a 20A fuse on the +12V (to trailer) circuit.
Or is your aftermarket Brake Controller Fuse blowing?
T@B trailer have 10-inch electric brakes; Dexter manuals state at 100% on one axle (two brake drums) will draw 6 Amps Total. So if your TV +12VDC fuse is blowing it's most likely not the brakes.
If a Fuse in the T@B is blowing . . . and from some of your comments that might be the case. Then there is a short in the T@B - - - So which fuse - - - WFCO DC Panel Fuse (value, location) or TV fuse is blowing?
Can you provide a description, or better yet, a photo of the specific location of the fuse that kept blowing? You indicated that the fuse from your tow vehicle (TV) battery to the tow plug (7-way plug?) was blowing after about 15 minutes. But you also described it as the fuse from your battery (tow vehicle? trailer?) to your electric brake that kept blowing about 10 minutes after driving. It is not clear if you were driving when the fuse blew. If so, how did you know it had blown (i.e., before actually inspecting the fuse?)
I am not familiar with the Curt Echo bluetooth brake controller and could not find any info online about it having a dedicated fuse. So, do you recall what you were doing when that fuse blew? Did that occur more than once? If so, what were the circumstances, or what you were doing at the time (e.g., towing, applying the brakes, checking a wire, etc.)?
Sorry for all the questions, but the answers may help resolve the issue and provide helpful info for all of us. Thanks, and good luck with getting the problem fixed. I am looking forward to hearing the resolution.
Have reviewed each posting for details.
- A - Assuming the Fuse that keeps blowing (you remove) is in the Tow Vehicle.
- B - The trailer brakes are on due to Emergency Breakaway Switch being engaged (pin pulled).
- C - This is most likely why the fuse is blowing. Not another short in the trailer.
- D - Expect your trailer brakes themselves are OK. You have been driving without trailer brakes after the fuse blows (or you remove it) as you have been setting the trailer battery cut-off switch to Off when towing.
Diagrams work better for me, so here we go . . . .
Your Ridgeline with U-Haul installed 7-Pin and Curt Echo Controller.
How it would look under normal conditions; Trailer Battery On, E-Brake not engaged (pin in).
How You have been towing for the first few minutes before the Ridgeline fuse to 7-Pin blows or you remove it.
Once the fuse blows (or is removed) there is no power to the Curt Echo or trailer. Trailer brakes will not work.
