Hi Gang, So as the title says I am about to purchase the new 2021 320 S boondock camper. The prices I have qutoed seem to be all over the place, guess the closer you are to Ohio the cheaper the camper is, I am out in Oregon. So I have a couple questions..
1. I will be using this too for winter camping in cold temps and high elevations, will I be able to use the toilet in the winter? I hear of people winterizing their campers. With the toilet connected to seems to be the fresh water tank from the videos I have watched, will I have issues with the pipes potentially freezing?
2. Also, totally newbie in regards to trailers, how do they handle in the snow? The TV I will be using is a 5th gen 4runnner, the weight of the trailer is about a 43% of the tow capacity of the 4runner.
3. I am looking at add on's, what crucial ones do you recommend, certain hitch, brake controller, etc?
4. Some say the bumper/fender comes with the boondock model but the site says made to order, which is it?
Thanks for any input?
0 ·
1. Toilet is a cassette toilet, which is inside the camper so it should not freeze if cabin is heated. Fresh water tank is under the trailer, so drain it and blow out the water, would keep it from freezing and use bottled water to flush the toilet, and washing up, etc, kept inside the heated camper.
You can run the Alde with out water in the system, use by-pass valve, following the winter procedure. RV antifreeze can be used, but I prefer just blowing the water out of the tank and u dear trailer lines. Grey water tank is also under trailer, just add the RV anti-freeze, and in Oregon you should be OK from freezing lines or tank.
2. TV should be fine
3. You will need some type of brake controller, I use Kurt Echo Bluetooth controller, that does not require wiring to the TV. It works fine on my TaB 400, it should work with the smaller 320.
4. Ask the dealer, fenders come with the Boondock, similar to other models,rear bumper may me an add on extra, not sure, but dealer will know.
T@B is not a four season travel trailer design. This means (a) make sure to have extra propane or 120VAC power available. Not fun waking up in a cold trailer and the Adle has no energy source. And (b) water lines and tanks can/will freeze so best action is not to use them. That said I do use my toilet for short duration in below 32F above 10F conditions by keeping a jug of 50/50 RV antifreeze in bathroom and use that for flushing/rinsing the toilet . . . then dump as soon as possible. Side note; many public dump stations are closed in the winter months.
I've only done this on winter snowbird runs. While driving south/north in WA, OR northern CA. South bound fill water system in central CA, northbound empty water system at last stop before northern CA.
Would expect the 50/50 flushing mix would also work with a cassette style toilet if that is what your new unit has.
I guess I will just have to see how far I can stretch a full propane tank with the heater that is installed in the camper. Seems like the fender is an add on and not part of the boondock package. Good to know on the brake controller, will look into it. I really appreciate your words of wisdom, so thanks for your replys. I am excited, did a lot of research on campers and the 320 is what I choose. Thanks again and take care.
I would add antifreeze to the toilet mix, too. Also, the bathroom gets very cold. Leave your door open and it makes a big difference.
Yes, generally, the closer to the factory, the cheaper.
There is no true rear bumper option. A rear brush guard might be what he is referring to. It is an aluminum cage across the plastic rear end sheath on the back of the trailer.
Odessa, Fl.
Honestly, it’s the one thing that will drive me away from nuCamp if I decide to jump up in trailer size. I think it’s incredibly short sighted of them not to make a four season camper...and I’m not even into snow sports. I just want to be able to take mine out year round without having to compromise on how it’s used.
Boondock Package for T@B lists the fenders and the rear aluminum cage.
New surprises everyday
See beautiful world
I imagine an extensive redesign would be needed to move valves and such into warm spaces. Keep in mind we are talking about a design a no knowledge newbie could take out and not completely destroy on their first trip in cold weather.
There have been forum members who have modified their tabs to 3 1/2 season campers. The difference is these owners understand the risk and how the systems work. It works for them.
Initially I was thinking making 4 season package an option. How do you do it without opening your self up to a big stack of warranty claims from in experienced owners with broken pipes and fixtures?
There are 4 season trailers available......the answer doesn't always need to be nucamp
Q1. Everyone has differing expectations and experiences when winter camping. My own limited snow camping sessions for snowshoeing and ski touring have been along the lines of what @Denny16, @MuttonChops, and @jkjenn describe. I've done the approach with RV antifreeze added to black tank and gray tank, and I've done add-on electrical heating to semi exposed drains, feeds, and tanks. Both work, at least above 10F.
I've also looked exhaustively at recent model trailers under 18' that have 4 season capabilities. They're considerably heavier, which limits the choice of tow vehicles, and they often have wood frame elements which I'd rather avoid, in case of water intrusion. I'm sticking with the T@B, at least until we become a larger crew, since I get much better mileage with a smaller tow vehicle. But the larger problem, at least for me, isn't keeping things thawed while camping as long as the winds aren't too high. It's more dealing with travel in subzero temperatures. Unless you run considerable propane or electric heat in the basement while headed down the highway, things freeze up. Even with a model where the gate valves are fully enclosed. Driving with propane running gets mixed opinions, but I've heard it's not allowed in some areas. So I'm not sure the gains made by 4 season trailer capabilities are always worth the downsides. And the canister toilet should be even more winter proof if you can easily dump it before heading out again. Not always easy to find an open dump station for black & gray tanks in the winter. We have dual pane windows on the T@B, but as @VictoriaP says, our thinner walls will never be as warm as some 4 season campers with 5" walls. So I bring an extra tank of propane on longer trips, and leave the window shades open in the day... since you will go through more propane when boondocking than with a true 4 season camper.
Q2. FWIW, I've frequently traveled in 6" snow with snow tires, all wheel drive, and only chains when icy. The T@B doesn't feel any different behind the car, deepish snow or not. At all. I guess the trailer tires just travel in the TV tread marks. Both station wagon and trailer are the same exact 71" from outside of tire to outside of tire along the axle. Not sure what the 4Runner tread total width is. I've not had the T@B go sideways on me, but I travel pretty slow in winter conditions, unless I need to build a bit of momentum for a slick uphill. Used to camp and tear around the mountains in a modified Mini Countryman all wheel drive, before getting soft and buying the T@B. Can't have much fun winter driving when pulling a camper. Sigh. Braking on icy 5-10% downgrades on my most recent trip pre-pandemic was fine, but I replaced my trailer tires with slightly more aggressive 7/32" tread to go with the latest gen Blizzaks with 10/32" tread. I carry an extra long tow strap and portable winch just in case.
I've seen YouTube vids of snowkiting. Looks like a blast. Closest I've gotten is skijourning, but dogs can't get the same speed as a strong wind on a big enough lake. What kind of terrain does snowkiting work on? Up and down moderate slopes?
I do have Blizzaks on my 4runner and was thinking of upgrading the tires that come with the trailer for winter time too. Yes snowkiting is a blast, fresh tracks uphill, downhill and all over. Thanks for experience driving during the winter, that's a little more reassuring.
We've been looking at 4 season truck campers and with the exception of the Cirrus, they use forced blower furnaces, and basically you need hookups or a generator. And then you have to find a way to heat them while travelling, or you'll still end up with frozen pipes. It also appears that condensation under the bed in the cab over is an issue even with the best 4 season campers (NL and Bigfoot). I'm not sure "4 season" is really that much better.
2022 Ford F350 Tremor | 2022 Cirrus 620
NuCamp may even make it an advertising shot, or at least add it to their IG feed.
The electric heating I added to my 320 helped:
https://tab-rv.vanillacommunity.com/discussion/comment/130816#Comment_130816
A couple folks have enclosed drains and tanks, and have extended the Alde system to warm that area. You have options.
Yes the TaB is not a 4-season camper, but in warmer (above 20 degree) weather, with sun, no blizzards, the Alde should keep things from freezing inside the camper. The TaB toilet/shower is heated by the Alde as is the coach on all four sides from floor level up.
Issue is going down the road, and keeping the heat in the TaB, running propane can be a risk, a small one on the TaB, as gas only goes to Alde and stove, or running a generator to get 110 VAC 20 amps to run the Alde on the 1Kw setting which should keep the cabinets, toilet from freezing, and add RV antifreeze to gray and black tanks, allowing it to run down to the valves, by cracking them open till it starts to run out.
I took a Class B camper up to the Southern Calif mountains for winter sports camping, and the water tanks were inside the coach, under the dinette seat, holding black/grey tank under the other one. My GF didn’t want to run the gas heater whilst we were sleeping in the cab over bunk, and guess what — we woke up,to find the tanks frozen! This was in mid 20s F overnight, so it does not take much to get frozen systems.
