Snohomish WA, 2024 3.6L Grand Cherokee
managed by VE Smart Network
rfuss928 said:This is a classic situation where a good "Surge Protector" or EMS would both protect the fault from becoming dangerous and probably identify the specific problem. Just sayin.....
I’d also wonder if it’s possible the 30 amp trailer cable is at fault. Again, hard to test until you have an alternate source of power.ScottG said:odd that the EMS didn't pick up the reversed polarity ahead of time as it has in the past. Is it possible the problem is with the trailer? Maybe something bouncing loose and creating a short when last in transit? Hard to test unless you can hook it up to another source of shore power to see if the problem resurfaces.
It's easy to implicate old wiring (and that may very well be the culprit) but anything that energizes the grounded side of the T@B's 120V distribution system could cause those problems.
I have a cabin wired in ~1960. There are ground related ghosts there that baffle me still after years. I understand electrical systems and grounds and bonding. I just would not attempt to trouble shoot a system I have never seen with so many details that could cause this issue. It seems , like you pointed out, there is probably something "upstream" related to this connection's issue. I can only hope the OP finds a workable solution.Bayliss said:@ScottG and @rfuss928, for whatever it is worth, as I mentioned earlier in this thread, both outlet testers and Electrical Management Systems (EMS) are not currently (as far as I know) designed to detect a reversed bootleg wiring issue, which is very unfortunate (and dangerous.) That is one reason I suggested it as a possible explanation. However, @dragonsdofly has apparently determined there was not a reversed/swapped hot and neutral found at the outlet in question.
I wonder if there could be a swapped hot and neutral at another outlet in the cabin (or other connection) upstream from the one the trailer was plugged in to. I don't know enough about it to say whether that could create the problem described. It will be interesting to learn if the issue goes away when the trailer is connected to a good 30-amp outlet.
I assume by the "power box" you mean the panel where the circuit breakers or fuses are installed. Your first statement referring to the "neutral and ground" being "wired into the same buss" implies a three-wire system. However, your second statement clearly states that you only have a two-wire system.dragonsdofly said:@Bayliss, husband has opened the power box. Neutral and ground are wired into the same buss. We have "hot" leg on one wire and neutral/ground on the other leg. Neutral and ground are tied into only 1 leg. Thus the wiring is only 2 wires. Husband is attempting to wire a separate ground as we speak, for testing purposes.
