Almost ready to take my new TAB 400 out and about. However, need opinions. How do you make coffee? What works best for you? Interested in all thoughts.
Starbucks VIA for the first month, but it got expensive. Probably will transition to french press, even though I really don't want to mess with the (mess of) grounds...
2020 T@B400 Boondock Lite w/solar 2024 T@g 5-wide Black Canyon TV is 2024 Toyota Land Cruiser LCP Jeff --Front Range of Colorado
Another 320 owner...but I make coffee the same way I do at home, pour over method with paper filters. At home, I use a knockoff glass Chemex carafe and an electric kettle. In the trailer water gets either boiled on the stove if no hookups, or I use a collapsible electric travel kettle, then pour into one of these + a paper filter over my cup.
Toss the filter and grounds, no fuss and limited mess. Both home and travel units use the same size filters for convenience.
I’m an early riser, so I usually used a small isobutane backpacking stove outside to heat up water, then used an Aeropress for my morning coffee before anyone else was awake. Love the Aeropress!
I guess it depends on shore power or generator availability. If not, then a Moka Pot is probably simplest, pour over, French press AeroPress, etc. Which all only require a way to heat water IE: propane stove. If you have power, I guess any plug in method you use at home works.
I have a standard old whistling tea kettle I boil water in and then use a French Press. Thinking about an AeroPress...
I anticipate not always having hookups for electricity so even though at home I have a proper full espresso maker, I wouldn't want to have a mobile coffee solution that required 110v.. I will use my low-tech coffee solutions which produce acceptable enough results.
~Tananda
2019 T@B 320 S Boondock Edge named "Binky" | TV: 2016 Chevy Colorado Z71 with full tow package and a Leer Cap for lots of storage
We use a Capresso 5 cup coffee maker. It's perfect because it makes just enough coffee for two big travel mugs. It fits in the cabinets above the sink. It's only 650 watts so I just wake up, poke the inverter and in about 2 mins, it is time to get out of bed.
I'm an Aeropress fan. The ease of cleaning the Aeropress (the coffee grounds just fall out of the bottom) enables multiple cups to be made in sequence. The french press and moka pots are almost impossible to clean out and start over until the whole unit cools down.
If you want a true time-sink today, check over the "Boondocking coffee in the 400" linked in ScottG's post above. Many great ways to make coffee, and some spectacular photos of DougH's Electra lever espresso machines.
@VictoriaP, I never heard of a collapsible electric kettle and just googled it. That’s brilliant!
I love mine. Great for any kind of travel, it gets packed into even the smallest carryon for making tea multiple times a day. And because it squishes down, it fits well in the tiny overhead kitchen cabinets in the 320. They make so many great collapsible things nowadays, I really want a couple of collapsible cooking pots next.
2019 320s BD Lite, white with blue (“Haven”) 2015 Subaru Outback 3.6r (unsafe 200lb tongue weight limit until 2020 models) 2020 Subaru Outback XT Pacific NW
I got a stainless Melitta pour over carafe, and a collapsible silicone kettle for heating the water. No electricity or battery power needed, and the carafe keeps the coffee hot for a long time.
Our 10 cup Bialetti stainless steel moka pot was our go-to 'best coffee ever', until we discovered the AeroPress. Now that's all we ever use (unless there's company... Making multiple cups with the AeroPress takes too much time).
The AeroPress also tends to 'allow' me to use a lot of coffee for each cup... makes for expensive, but dang good coffee!
Chan - near Buffalo NY 2014 S Maxx 2011 Tacoma 4cyl ... edit: 2022 Tacoma 6cyl - oh yeah! A_Little_T@b'll_Do_Ya
We use this hand-turn coffee grinder at home and for travel. My husband and I both love it--so much simpler and more reliable than the electric ones. And this pour-over dripper. You wouldn't think it would matter, but it actually makes a much better cup of coffee than all the other pour-overs I've tried. Something about the rate that the water seeps through the "auto-drip" water reserve on top, maybe? Conveniently, it takes as long to grind the beans for one cup as it does to heat the water. We use them at home, and also pack them with us when traveling overseas.
Some of how you make coffee is going to depend on availability of 120v power either via shore power or a generator. Too taxing on limited battery storage in a Tab to use an inverter for any heat generating appliance.
I use an aeropress at home and that works good anyplace, but my current grinder is electric so have to use some different way of supplying ground coffee in the Tab.
If you have power, then your options are roughly the same as at home assuming you want to haul all the bits and pieces. Are you camping or glamping?
A moka pot on the Tab cooktop is probably one of the simpler methods or a pour over, both just need the cooktop for heat and you can manually grind beans or use pre ground coffee for an emergency means.
My wife and I decided we weren't going to take a bunch of stuff in our camper that we don't need. We have a plastic cone that sits on the cup and holds the filter. Heat water on the stove and pour it through. Takes up very little space, makes good coffee, doesn't require any power, and it's cheap.
We don't need anything else.
2019 T@B 400 BDL 2018 Ford F-150 2.7L Ecoboost with tow package PNW
Used to use a Cabela's stainless steel perk but have converted to a hot pot and Starbucks Via - less mess and faster. Plus the side benefit of the hot pot is hot water for dishes.
John & Cheryl 2007 T@B ClamShell by Dutchman "Goli@th" 2018 Chevy Colorado V-6 Edmond, OK
On our T@B400 with solar, just a regular coffeepot on the inverter. As long as we shut it off as soon as its done it's not too taxing on the battery. Solar will just about recover what it used, and have done a couple weekends boondocking like that. Wife and I like 2 full size cups in the morning so the 12cup coffeemaker was a must. Stores nicely under the sink when not in use.
2020 T@B 400 Boondock Lite - 2018 Toyota Tundra Platinum - Tempe AZ
I found the Stanley stainless steel french press and couldn’t be happier! Water heats quickly on my gas stove, much faster than a kettle does at home. It won’t break in transit, and I can use the main pot for cooking other things, like corn on the cob.
Stanley Adventure All-In-One Boil + Brew French Press , Silver , 32oz
Amazon'sChoicefor "camping french press"
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
My husband and I use a Coffee Gator Mug. I bought it as a present for him for one of our anniversaries, but then realized that I need it too. It is really convenient that everything you need to make coffee is already in the mug and you don't need to take extra bags with small details.
I have a stainless Italian style espresso maker with an actual steam wand on it. You can brew the coffee, open the valve to let steam pressure push it out, then heat some more to steam milk. Coffee van be anywhere from espresso rich to am Americano style, which is what I use.
I can get two six once cups on one brew or one 12 oz brew at a time. Works on the stove top, and is small enough to store in the TaB400 overhead locker. Makes great coffee, grounds stay in the top basket, similar to a percolator, but coffee is more of a stem/hot water extraction method rather than a drip brew.
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
French press with whole beans ground with a camping hand grinder that was recommended by Mandy and available on Amazon. Hot water provided by gas stove or better yet an induction Burner. Great coffee every time.
https://smile.amazon.com/gp/product/B001RBTSMM/
https://www.amazon.com/Capresso-426-05-5-Cup-Coffeemaker-Silver/dp/B0728C671N/ref=sr_1_3?hvadid=77996675051187&hvbmt=be&hvdev=c&hvqmt=e&keywords=capressa+coffee+maker&qid=1561389683&s=gateway&sr=8-3
https://www.amazon.com/RSVP-Manual-Coffee-Carafes-Thermos/dp/B000BUDDTY
PNW
Edmond, OK
https://amzn.to/3k4fDE2
YETI mug
https://amzn.to/2GIEVsU
http://www.cafelat.com/robot.html
