Well, as a rank TAB newbie who had trouble simply reading the status of the glycol overflow reservoir of our 2017 320 TAB U, much of this discussion was very detailed requiring much tenacity to get through. I had to skim some sections because my brain was a bit tired. However, let me say, thanks to all of you for spending the time on this. I too don’t know of many RV specialists who will deal with this issue. I had three shops tell me they wouldn’t even try to work on the Alde and only one email response to my inquiry to 3 dealerships. Let me qualify that I have a PhD so I have some basic smarts and tend to be detailed—nonetheless I had hoped that retirement with the TAB would be a refuge from such detail—perhaps a bit less of a challenge.
It seems the very real practical issue is the lack of a dealership network with the capability to competently/completely service it’s NuCamp products—in this case the Alde. Can you imagine your car dealership not being trusted to flush your transmission system—although the process is likely much simpler than with the Alde. Clearly, the RV industry is in it’s infancy compared to that of the automobile. Nonetheless, the problem is real and most owners need a solution. Your proposed solutions are praiseworthy, but beyond the scope of the typical TAB owner. I know I will find a working solution, likely what the factory allegedly does, but it seems a bit of a shot in the dark.
BTW: Any tips on how to read the reservoir? I was thinking of putting a dowel in the reservoir and if i knew how high the minimum level was from the bottom, I suspect I could figure the rest out.
(MOD NOTE: Discussion of this last question moved here.)
Thank you for your response. I recently inquired at the nuCamp Repair Center about this very issue and Austin replied, "Yes sir we use a proprietary pump system from Alde to fully pump out all old fluid. This insures all old fluid is out of the system & that there are no pesky air bubbles in the system to cause issues later." He went on to say in a subsequent email, "The issue is that you can not drain even a third of the glycol out with out [sic] using a pump because of the low & high points in the system so this violates the point of flushing the system."ScottG said:@MadCityJack, I sympathize with your frustration regarding competent dealer service. I've contacted supposed Alde service centers regarding parts and have gotten no response other than to be placed on their marketing email list.
That said, you can probably appreciate that much of this discussion is academic. It turns out even nuCamp doesn't bother flushing the entire system unless the glycol is visibly deteriorated. Under normal circumstances they just drain what they can from the low-point and then add back to the reservoir until the system is topped back up. Evidence suggests the glycol lasts much longer than the recommended two-year change cycle; an owner with even modest skills could do this every two years and probably keep their glycol in tip-top shape with minimal effort. The more thorough methods described here can be reserved for the gearheads and those (like me) who tend to ignore those mundane maintenance tasks. :-)
Of course the real issue will come when and if these units start needing real repairs. Fortunately, with the oldest units topping six years, there has so far been little discussion about Aldes breaking down.
