While waiting for CA campgrounds to open I'm trying to complete my latest (and hopefully last) electrical project.
I have a 2013 clamshell that did not have a battery cutoff switch. So I'm adding a cutoff switch and the
Victron SmartShunt at the same time.
I bought an oversize battery box which will hold both my battery and the shunt, with a barrier between them. This eliminates the need for a separate watertight box for the shunt. I plan to mount the switch on top of the battery box. I've come up with a way to get a cable around the box so I can lock it all up.
The SmartShunt goes on the negative line per Victron instructions. My question: do I put the cutoff switch on the positive line or on the negative line? If on the negative line, do I put it 1) between the SmartShunt and the battery or 2) between the junction box and the SmartShunt? My inclination is to install the cutoff between the SmartShunt and the battery so there is absolutely no drain on the battery (even the SmartShunt) while the trailer is in storage (no power).
Discuss.
This will eliminate parasitic drain or shock if you were to contact a wire.
2019 320 Boondock Edge - Sold Jan 2022
(diagram on https://tabforum.nucamprv.com/#/discussion/comment/53031)
Oh yeah, I tried releasing the probe wires on the Smartshunt - I failed, short of calling Victron, anybody done it? I tried pushing a paper clip into the little holes under the probe inserts.
managed by VE Smart Network
2012 Jeep Liberty KK a/k/a "Libby"
BTW what AWG gauge of wire did you use to connect the -battery terminal to the corresponding terminal on the SmartS? I noticed @MarkAl used a 6AWG battery cable, but I was wondering if something less beefy would be as safe.
Watching the shunt I've found a better understanding of how the refrigerator uses the battery power and is key. With my two 6Vs I have plenty of energy for it IF I have a few hours of access to sun. We've needed to turn it off after 3 days if we haven't had sun. In the winter the sun is so low it's very difficult to get solar in a campground for any length of time. Battery energy state (not just the voltage reading) is key then.
Glad to hear you find it useful in spite of having to go outside. I never wanted the monitor display, so I’m glad Victron came out with this model.
Also interesting on the 170 AH Li battery for 4 days what is your remaining capacity at 4+ days? I think about switching but we plan on winter camping and I wanted to get some experience in real (cold) conditions before committing to Li. I should mention the 2 1/2 days gets me to about 78-80% based on my 215 AH Lead Acid. After that we've either driven home or the next site or sun came out. I'm still learning to trust the %, I seem to see the voltage only when the refrigerator is running and start getting worried on the 3rd day. I've never seen remaining capacity under 70% which is much better to monitor than the voltage!
I believe the shunt with monitor having a stronger BT signal has been mentioned around here previously. A little frustrating, since the whole point of the SmartShunt is BT!
