I’ve had my tab before hundred for three months now. It was heating wonderful even in the mid 20s. Two days after changing propane tank it stopped heating properly.
Only the vents from the bed were working.
Could not get over 65°.
I thought at first that maybe there was air in the propane tank but the cooktop works and I was getting heat from the bed vents.
Compensate compensate I bought a little electric handy heater. It’s done the trick except for the bathroom lol however it doesn’t solve the issue.
The glycol is circulating properly and it is at a proper level.
Anyone ever have this issue or have any idea of what could be wrong?
Thank you
for example in cold weather my propane tank would generally be changed every four days. I started tracking it when I had only one propane tank and continue to do so now that I have two.
When all this started it was a couple days after I changed the propane tank. I put a new propane tank in January 9 and I did not have to change it until January 30.
Tested the Alde the other day in preparation for this weekend camping. Really haven't used it before (we live in FL).
I had plenty of heat coming out at the rear vents behind the bed, but little or no heat coming out of the vent under the passenger bed.
Does it just take longer for that area to heat up?
Tampa FL
2008 Toyota Sequoia 5.7 L
Boston Northshore
When everything is cold, that first stop along the rear convector is going to draw off a lot of heat. This would likely be exacerbated at start up when the glycol itself is not all that hot. Eventually things should equalize and the heat will be distributed more evenly.
Same could happen in the 400, though I don't know how the loop is configured in those units, or what area gets the heat first. It is suspicious that AmyS's problem surfaced with a propane tank change. I'd bet a nickel TerryHutchinson is on to something--maybe the propane is not getting through and the electric heaters (particularly on the lower setting) may not be keeping up. Just guessin' here, though.
- Shut down the Alde completely.
- Turn off your propane at the tank.
- Disconnect all power to the camper--shore power and battery.
No go for a long walk. When you return...- Reconnect your power supply.
- Slooooowwwwly open the valve on the propane tank.
- Set the Alde for "hot water only" and start it ONLY on propane (i.e., no electric heaters).
The Alde will go through a start-up cycle involving a series of whirs and clicks. If it is not getting propane it will shut itself down in short order. If it fires up and stays running (you might need to confirm this by going outside and listening to the vent) then propane supply is not your issue.I had an issue last season where my Alde wouldn't start on propane after I had swapped out a tank. After doing the above it worked fine. Try it out and report back what happens!
*For later models or units with the large 3-way fridge, the reservoir/expansion tank is in the left side front dinette up by the round port hole window area. Also, there are small radiator units under the front dinette round windows, that I’ did not show in my simplified diagram above.
So it takes a bit for all the areas to get properly heated, especially the washroom, which is at the end of the circulation loop. Changing the propane tank will not effect the circulation, the Alde boiler is heating everything or nothing, as long as the circulation pump/s are working. Later model TaB400s with the Flo have two circulation pumps.
Once the Alde system gets heated up, after about 30-60 minutes, you should feel heat coming up from behind the bed, galley counter, under the round windows in the dinette and under the table center area, then the radiator unit in the washroom/head.
You should also see the glycol level moving up and down in the reservoir/expansion tank. Check your Glycol level in the reservoir tank, you may be low on glycol which would account for your Alde circulation issue.
Seems coincedental that this issue arose after swapping out the LP tank. I'd like to think they're unrelated. Dunno.
I also agree with @ScottG. Shut everything down in the proper sequence and begin again.
May not be related but during my last adventure I did have an issue with the Alde not firing up properly. After shutting off power and LP, I opened the top panel on the Alde, disconnected the three wires located on top of the unit (two electrical and one "ethernet" style if I recall correctly), waited a couple minutes, reconnected, turned shore power and LP back on and...Voila...heat.
The old classic PC Helpdesk trick...when in doubt, reboot.
San Diego, CA
www.airbossone.com
Gotta love the reboots! It's kinda like humans. Every once in a while we all have a synapse misfire. It's best to simply shut it down and start over!
San Diego, CA
www.airbossone.com
San Diego, CA
www.airbossone.com
Which mode are you in...thermostat or circulation and do hear gugling in circ mode?
San Diego, CA
www.airbossone.com
To bleed the heating system manually, follow the steps below:
1. Switch off the circulation pump.
2. Open the bleeder screw and leave it open until it starts to discharge glycol.
3. Close the bleeder screw.
4. Open the remaining bleeder screws in the system (please refer to the instruction manual of the RV for their locations).
5. Leave the bleeder screws open until they start discharging fluid and then close them.
6. Start the LP Gas operation on the heating system.
7. Start the circulation pump and let it run for a while. Normal setting, speed 2. Bleeding, speed 5.
8. Check that the pipes and convector’s around the vehicle are heating up. NOTICE Never open the bleeder screws while the pump is running, because this will induce air into the system.
Just in case...
San Diego, CA
www.airbossone.com
