I have located a 100% waterless coolant which I am planning to use in our Alde. This coolant is propylene glycol non toxic and contains no water. Therefore it needs no anti-corrosion additives which break down over time. This makes it last indefinitely with no need of replacing. It’s not cheap and costs $64 gal plus prep fluid which eliminates the water in the system after draining the old coolant. It is available on Amazon or direct from the manufacturer.
https://www.evanscoolant.com/#max-widgetDale Helman
managed by VE Smart Network
https://smile.amazon.com/dp/B0096QO4TM/ref=cm_sw_em_r_mt_imm_awdb_T53W6N86M2YXZFSAVN33?_encoding=UTF8&psc=1
There must be an engineer or scientist who picks the recommended fluids for Alde.
A sales rep will just say "Our Alde brand is the best fluid."
But if I spoke Swedish and I was a materials engineer, the use of this fluid would be a great discussion to be had with the right gal or guy at Alde.
Will this fluid ever absorb enough water to cause corrosion?
I do know that glycols are pretty useful dessicants so they will absorb water.
Will they absorb enough to cause issues. Who knows?
I put in new century fluid last year and the first thing the bottle said to do was cut it with distilled water. It is hard to think about in light of the issues that are occuring. Would it have been better to just pour it in straight?
1 - It is important not to mix different heat-transfer fluids in the Alde because they can gum up when they interact. And it is almost impossible to drain fully drain and flush the Alde without specialized equipment. Referencing this long, informative thread here .
2 - It sounds like your T@B has its 'original' Century TF-1 fluid. How have you been measuring the pH? from the reservoir? The reason I ask: when I drained the original 7-year old fluid out of the Alde of my 'new to me' 2014 T@B, the fluid in the reservoir was a healthy yellow-green but the fluid that I drained out of the system had changed to an unhealthy pink colour, a sign that it had definitely degraded. I did not measure the pH, but I think the corrosion inhibiting properties of the fluid can degrade independently of the pH.
I hope to get my Alde fully serviced at some point 'post Covid'. I live on an island and the only service I know of is on the mainland (Vancouver). For now, I've done 2 partial changes 1 month apart and will do a partial change on a yearly basis using the Century TF-1 fluid. The Alde is amazing and I've been so thankful for it to get me through some cold nights this past winter!
Mellow_Yellow, yes, the corrosion inhibiting properties of the fluid can degrade independently of the pH. Measuring the pH will not tell you the effectiveness or lack thereof of,the corrosion inhibitors in the glycol solution.
Doing a partial change of the glycol is better than none, but it should be completely changed every two years. You should be able to get to Vancouver by the end of the year to get this done.
Are not the radiators in the Tab constantly cooling the coolant the same as in a car radiator? I guess I see no difference.
I used ph test strips
There will no mixing of coolant
There is a fairly extensive procedure for removing the original coolant. Hansen’s website provides detailed instructions, and the use of a special prep fluid.
