Got my second Battleborn battery. Ready for some extended boondocking.
Ken / 2023 Tab 400 “La Bolita” (20,000+ miles) / 2024 Toyota Sequoia
2024 - 2 Trips - 25 nights - 4 National Parks, 3 National Forests
3 ·
Brad
Concord, NC
As an aside, you both look to have very nice installations. Camp on!
1. Makes it much harder for someone to borrow them without the intent of returning.
2. Since Lithium batteries can be severely damaged if they are charged much below freezing, installing in this area
keeps them warm (not hot). Based on my observations so far (I have the optional temperature sensor
for the BMV-712) the temperature when it is cold outside is typically in the mid 70's.
Although Battleborn offers heated batteries and heating blankets to allow charging in cooler temperatures, what I have experienced so far is that I will be fine no matter what the outside temperature is.
Brad
Concord, NC
Poughquag, NY
I'm very jealous...great job!
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
Are the battery boxes also screwed/attached to the bottom of the tub or just screwed together and the weight keeps them from moving around?
Do you have a charge controller between your batteries , 7-pin connector and your alternator? My concern would be the low resistance of lithium batteries working your alternator to hard.
I see, if you are not using the alternator to charge you could disconnect the 7 pin 12v lead to the power center. That way you could keep the house battery power on when driving but battery disconnect works also unless you forget to do it.
Power to the power center is not required when towing, unless you want to run the refrigerator or something. On my 400 power to the and trailer brakes and lights is wired directly from the vehicle through the 7-pin. The only wire from the 7 pin connector that goes to the house battery for charging is the aux power #4 pin. The Breakaway Switch to the brakes is wired to the house battery before the main switch so it never looses power if the pin is pulled.
When changing to lithium batteries and not wanting the 7-pin TV charging connection, one could add a small 12VDC AGM utility battery to,operate the emergency braking, and charged via the 7-pin. Just put the battery in the front tub, and wire it to to the 7-pin charging wire at the front junction box. This way you can use the main battery cut off switch to disconnect the lithium bank, whilst leaving the emergency brake system to use the small utility battery in the tub. This is what I plan to do when I convert to Lithium batteries in our TaB400.
So, on my TV the charging circuit is fused at 30 amps and only active when the truck is running. I installed a Victron 18-amp DC-to-DC Charge Controller. Super simple on our 2020 400 BDL, a matter of removing 1 wire from the power distribution center. Since I wanted a Bluetooth version, I had to use an isolated ground model but tied the 2 grounds together and connected to the negative bus bar as you can see in the 2nd photo.
Steps I took.
1. Remove 12-gauge wire (Red) from Power Distribution Center
2. Install a 12-gauge red wire from the Power Distribution Center to connect to the controller
3. Install controller and connect 4 wires
4. Configure via Bluetooth
I now have 18 amps of charging as per my BMV-712.
In the first picture you can see my new 12-gauge wire with the yellow tube crimp on it
Second picture shows the controller mounted under the curb side dinette seat
Brad
Concord, NC
confirmed. I think it is a bit odd that the brake system is directly tied into the entire electrical system. Back to the drawing board for me.
You could certainly rewire things to make this not be the case, but this is the way every stock T@B has been wired since battery switches became standard equipment.
Yes, I don't know what I was thinking, I just replaced my AGM batteries with lithium and I did not find any lead to the brakes between the batteries and the main switch. What confused me was I received a NHTSA Recall from a previous Forest River camper I owned.
The break-away safety switch may not be wired to constant power and may be disconnected from the trailer house battery by the operator when switching off the battery disconnect.
If the vehicle operator turned off the battery disconnect switch, and in the event of a trailer separating from a tow vehicle, if the break-away switch is not wired to constant power, the brakes of the tow vehicle will not engage, increasing the risk of loss of vehicle control and a crash.
I think I will rewire my breakaway switch to the battery.
https://www.rvtravel.com/forest-river-rv-recalls-some-trailers-breakaway-safety-switch-may-fail/
Another option--albeit one that is a bit more complicated--would be to relocate the battery switch to the line between the junction box and the power center. That was where I placed mine back before battery switches were standard equipment. This arrangement allows you to disconnect only the power center while leaving the battery connected to the breakaway brakes (for safety purposes) and the tow vehicle (for charging purposes) at all times.
Or you could just remember to leave your battery on at all times when towing. :-)
I will say this topic has been a point of confusion (and sometimes contention) for as long as I have been on the forum!
