On our first trip out this year, with city water and shore power connections, the hot faucets never showed anything better than tepid (~70° - 80°) water. Last year (our first in a 2021 400 Boondock) hot water temperature was just fine. If there was anything unusual in the dewinterizing process it was the first several seconds of running hot water after the bypass valves were opened. The sputtering had a very foul smell. As the flow ceased to sputter cold clear water came out of the faucet. On our trip we noticed that it took a while (I ran the outside shower for several minutes) for there to be a constant flow of warmish water - most likely because I hadn't run the 3 gallons or so as suggested in the manual.
What to do?
2018 Audi SQ5 + 2021 T@B 400 BD replaces '99 Roadtrek 190 Popular (same mpg with half the range)
The valves in your photo look fine? The glycol pump setting of 2.5 controls the glycol circulation and is adequate. Make sure the Alde is set to “Therm” rather than “Continuous”. Continuous mode circulates the heated glycol constantly and returns cooled glycol to the Alde. The Alde in turn uses that “warm” glycol to heat the water - this may account for a cooler water temp.
Other factors that effect water temp = starting with very cold water, cold ambient temp, thermostatic mixing valve needs adjustment, or simply not waiting enough time to let the Alde heat.
I would also try the shower “boost” setting which should stop the glycol from circulating which allows concentrated heated glycol to heat the water.
You have the Flow - as I remember there were reports of initial fluctuation in temperature out of the faucet.
That foul smell suggests that the Alde and Flow were not completely emptied with winterization.
https://tab-rv.vanillacommunity.com/discussion/14924/2022-tab-400-mixer-valve#latest
You may want to try it on propane.
While I am just as happy to not have a pesky mixing valve, I can see why nuCamp started installing them.
Do you agree with Denny16 regarding a possible mixing valve issue? If so, I'd like to get the six to eight week process started as soon as I can.
