We're very happy with 2021 320S and how well the rooftop solar panel keeps our battery charged. But our 2021 320S did not get a port added for external solar panels and I'm sure we'll be taking trips that would benefit from that connector. In Tabarado this year, I raised the question about what would be needed to add the port. With great input from the more experienced travelers there I decided to tackle the addition. Here is a brief description of the process. CAUTION: This just adds a port directly attached to the battery. Any external solar panel will also need some controller to avoid overcharging or destroying your battery. First, see how your battery is currently connected:
The attached diagram & photo shows ours
It takes a 7/8" hole saw to make the a place to put the port.
This came from
Amazon and has a nearly 22" 10AWG wire pair so it allows a fair amount of slack between the tub wall and the battery connections.
Rather than try to strip the and solder in the wires from the existing controller, I added a 30A fuse to the hot (red) wire and attached it to the positive battery terminal just like the existing connections. The black wire connects to the negative battery terminal along with the white wires from/to the electric panel and rooftop solar panel Victron controller. As seen in the next photo and diagram
I look forward to getting an additional solar panel and trying everything out in the near future.
Bill
Thanks for the suggestion. Putting the controller in the tub would certainly change some of the wiring between the port and the battery.
New Mexico
2021 T@B 320s (“T@Bañita”)
2023 T@B 400 Boondock (“Redwing”)
2020 Subaru Ascent (“Bubbles”)
The factory installed solar port does not include a solar charge controller - it is just a direct connection to your batteries, and as such, a charge controller is required to connect a solar panel to the external port.
Brad
Concord, NC
But it is my understanding that the factory installed external solar port is connected directly to the battery, and requires the use of either an external charge controller, or to have one installed to the external solar port wiring.
The external port is wired to the battery via the distribution block.
https://tab-rv.vanillacommunity.com/discussion/comment/172747/#Comment_172747
2017 F-150
Coeur d'Alene, Idaho
I took a step further and even made my controller modular. Under normal use it sits in the tub at its optimal location near the battery, but it can also be attached directly to the panel for remote use as needed. This has the added advantage of keeping my controller--which is not waterproof--out of the elements and allows me to keep my panels deployed full time once in camp.
If you can make cables (not particularly hard to do) you can be creative in ways that optimize both performance and versatility.
No one has a problem with two controllers charging the same battery from two independent panels?
Since I am a retired electrical engineer I think too much.
I had trouble keeping my battery charged over three days and my need to add movable panels to my rig.
Thanks
2020 F150 2.7l V6 Turbo
Tucson, Arizona
I can also verify that 2 Victron controllers work perfectly together. It's a great system in fact.
Here is a link to my second Victron and external solar port installation:
https://tab-rv.vanillacommunity.com/discussion/comment/173150#Comment_173150
So much to learn.
K&C
Tucson, Arizona
I think that two parallel controllers would work okay.
I also want to add a portable panel and external port for shady-campsite situations. The external panel voltage is about the same as the rooftop one. The overthinker in me asks:
What is the point of a second MPPT controller in this situation?
It ought be safe to connect the ~20V from the portable panel in parallel to the rooftop panel, at the PV input of the Victron. It is just like one panel being shaded while the other is in the sun. That happens all the time without problems.
It would deliver slightly more power to the batteries, since the long wires to the external panel would run at a higher voltage and lower current, reducing the voltage drop by about 40% for these 20V panels.
It also means that you don’t have to buy another controller and waterproof housing.
https://www.eevblog.com/forum/renewable-energy/over-dimensioning-a-pv-array-why-max-current-input-limit-for-mppt-chargers/ )
Granted, I would lose the ability carry the portable panel to another campsite’s and charge up their 12v batteries.
Given that I’ll bother to set out the portable panel only when our T@b is shaded, it seems a waste to have a second controller when, almost all the time, only one is needed.
What do you think?
How did you mount the controller in your tub?
Need you need to put it in a water proof box?
I can see the tub getting water inside at time.
I am starting to lean to your solution.
Thanks
K&C
Tucson, Arizona
2023 T@B 320 S Boondock
Thanks for your help.
2022 T@B 320-S Boondock "@ngel"
Sedona Arizona
