pthomas745
Administrator, Moderator Posts: 4,386
NHTSA Campaign Number: 24V150000
Manufacturer Pleasant Valley Teardrop Trailers LLC
Components ELECTRICAL SYSTEM
Potential Number of Units Affected 163
Summary
Pleasant Valley Teardrop Trailers LLC (Pleasant Valley) is recalling certain 2023-2024 nuCamp TAB 400, Cirrus 620, and 820 trailers with the Lithium Upgrade. The incorrect battery disconnect switch may have been installed.
Remedy
Dealers will replace the battery disconnect switch, free of charge. Owner notification letters are expected to mailed March 1, 2024. Owners may contact Pleasant Valley customer service at 1-330-852-4811- ext. 327.
Notes
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), www.nhtsa.gov.
NHTSA link
https://www.nhtsa.gov/recalls?nhtsaId=24V150000
Didn't find anything over at the NuCamp web page. This showed up on a FB post earlier this afternoon.
I'll be keeping an eye on the amp draw with the Victron app.
Battery Disconnect Switch, Gioyonil 12-48V Master PowePower Cut Shut Off Isolator 275Amps
And it lists 275 amps... is that amp hours?
Really need to see the circuit wiring/design for the specific application, but 275 amps is in the ball park for a 2500W or 3000W inverter DC circuit.
I have a 2000W inverter in my 320 and the calculation for fuse size (including inverter effeciency and safety factor) resulted in the use of a 225 amp fuse for the inverter circuit (seperate circuit than the charger or any other circuit). My busbars and inverter ON/OFFswitch are sized appropriately for the larger amp inverter circuit.
2000W inverter assuming 90% efficency= 2200 Watts (2000/0.9)
Amps =Watts/Voltage=2200/12=185 amps
25% Safety Factor= 185 * 1.25 =231 amps
Southern Maryland
Southern Maryland
Victron (the manufacturer of the inverter used by nuCamp) for the 3000W/400AH Lithium package calls for a 400 Amp fuse, which means using 4/0 wire...and a much beefier disconnect than the standard one on our T@Bs.
If you're wiring with 2/0, then you must use a fuse that can protect it from melting, which is 300 Amps.
From Victron's Install manual:
4.2 Connection of battery cables
In order to utilize the full capacity of the product, batteries with sufficient capacity and battery cables with sufficient cross section should be used. See table.
12/3000/120
Recommended DC fuse 400A
Recommended battery capacity (Ah) 400–1200
0 – 5m = 2x 50mm2
5 – 10m = 2x 70mm2
So when the disconnect switch is turned off, you have no 12V power regardless of if you have shore power or not? A distinct change from earlier wiring...
In talking to a technician at BattleBorn, he suggested that I have a battery switch between the Multiplus and the battery bank, so as to isolate the Multiplus. This is what I have done.
One 2/0 cable runs to a distribution block. The other comes back to the battery. Then from the distribution block, a cable runs to the main battery disconnect that connects to the 12v distribution panel.
The Victron Multiplus inverter/charger doesn't provide DC power directly to your DC circuits as a converter charger does; it gives power to the battery, and the battery powers your DC circuits. If you disconnect your battery you will not have 12 VDC power even when on shore power with the Multiplus on, and if you turn the Multiplus off it will not pass AC power through to the AC circuits.
