Perhaps the most discussed subject on the forum is about Alde - how to operate, trouble shoot, fluid change, etc, etc.
Consider, that this hydronic system was born in Europe where hydronic heating is the norm in residential applications. In North America however, our norm (now) is forced air systems. Why because they are less expensive to install and maintain. As well they can include air filtration and humidity control.
I wonder from a builder perspective, if it is time to abandon this complex system in favour of a simpler system. Consider the Cool Cat ac unit installation includes a duct system. Truma has a forced air system (120V/Propane) that is ducted and includes a demand hot water option. So perhaps a redesign of the NuCamp heating/cooling/domestic hot water installation should be considered. The Alde system with its miriad of operator and maintenance issues by comparison seems un sustainable. Thanks for reading.
400 - 2019
St Catharines, ON
1 ·
When we purchased our TaB, the biggest selling point is the Alde heating system. Running small fluid transfer tubes in walls or under floors is much less expensive than running a maze of large duct systems, required of a distributed forced air system. I would not buy a house with forced air heating/cooling either.
My first RV, a Mobil Vacation home (think a small 30-ft Park Model type trailer), had a forced air wall type heater in it. When the temperature was set to be comfortable whilst standing, it was cold when you sat or laid down. The heat was concentrated by the heater and colder when you moved to away from the front area where the heater was located. I ripped this unit out, and replaced it with a sealed convection heater, which distributed the heat ore evenly from floor to roof.
For those that camp exclusively with electric hook ups, I agree that there are better options that are not as complex. For those of us that camp in cold weather without hook ups the Alde is hard to beat due to it's low electric needs. Plus in a small enclosed space it's much quieter than any forced air system.
2022 Ford F350 Tremor | 2022 Cirrus 620
I love the Alde but it does seem to be troublesome for many people. We’ve been lucky so far with no issues but seeing so many others having problems I do wonder if our time will run out. Or are we just seeing the negatives because that’s when people reach out for help online?
2020 Tacoma TRD Off-Road
I also own a Truma vario heater and love it. It is basically the forced air furnace without the water heater side to it. The Vario does not require any complicated, expensive and potentially messy maintenance like the Alde. And for a forced air heater it is quiet. Ours is completely exposed in our truck topper camper and while on high it certainly is loud, way louder than the Alde but quieter than a suburban heater. But when switched to night mode it is remarkedly quiet for what it is and not hard to sleep through. If it was mounted in a cabinet in a trailer I can imagine it being much quieter.
Would I trade our Alde for a Truma? At this point I probably would say no. But next year when I have to change out the glycol again I might change my mind. And if NuCamp switched to the Truma Combi it would not break my heart. Who knows if our Alde ever breaks I may install a Combi comfort plus over another Alde.
If our Alde system stops heating when we are on the road, can we get help from Alde, Nucamp, or dealerships? Maybe, but don't depend on it.
Their ignorance of the corrosion issue is absurd. If the damn aluminum convectors corrode no matter what, give us convectors made of a different material, for example.
Minnesota and Arizona
Alde radiant heat is very comfortable. In Europe where the Alde system is common, the costs of maintenance is low. We just live in a place where only NuCamp and the high end Airstream trailers use this system.
Routine fluid changes plus a little vacuuming, and you have a great system.
"Just Enough"
I do believe that Nucamp could make glycol changes much easier for DIY folks (or those who live a long distance from any dealer service facility) by equipping T@Bs with a 3-way valve to allow pushing out old glycol with distilled water rinse & refilling using an inexpensive electric pump. I have this mod installed in the hose between the glycol pump & floor drain, so it can push fluids through the Alde, hoses, convectors, expansion tank & out the floor drain..
Then, by switching the valve position & closing floor drain, it can backfill the hose between valve & tank to fill tank to desired level. Works great. Maybe it could also make glycol changes more available at dealers without the complicated & expensive special glycol pump.
Would you mind sharing the list of parts you used to make this mod? I think I could figure it out if I was in front of my camper but it's stored away until April.
When using this, all you do is operated the Alde pump in continuous mode (without heat being applied) ?
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
I have to wonder if they do not make it easier because it is intended to use a mechanical pump because it is the best way to protect the system.
My concern is that some if the DIY approaches people take will lead to downstream issues in a couple of years.
Sadly this will not help you know if you've successfully flushed your system before adding the new glycol, but will give you confidence that it was done properly after complete.
I love the Alde and the benefits outweigh the maintenance cost, to me. The efficiency of LP use, low power draw, and nearly silent delivery of heat are all amazing.
Having owned multiple other brand trailers with much simpler systems .
Odessa, Fl.
