Replaced stabilizers with leveling jacks
245
    The important thing is stabilizers can not be used to lift just to support. Each stabilizer is rated at 1750lbs. The scissor jacks I used are rated at 5000lb each. Once again it is the design of the stabilizers that makes them unsafe for lifting.
    1. Hash  T@B Fun
    Most of the time we rotate our T@B 90 sometime 180 degrees at our site to take better advantage of it. Those handles are a terrific asset. Once unhooked from our tow vehicle blocks and devices that require rolling on to just do not work. The  Bal Leveler work but for me they were bulky and hard to store. The jacks do everything with no storage needed.
    1. Hash  T@B Fun
  • rfuss928rfuss928 Member Posts: 1,044
    edited December 2021
    TACOMAGUY said:
    So stabilizer jacks, are not as strong as scissor jacks is that correct
    Simply put - Stabilizers are not jacks.  This thread discussed this recently:
    https://www.tab-rv.vanillacommunity.com/discussion/42879/
    I think I've only been on pads where I could roll it around by hand a few times. Can see where the BAL works for that, hard to roll onto blocks by hand. 99.9% of the time I'm positioning by TV.
  • marknjudymarknjudy Member Posts: 378
    I had to roll mine up onto blocks by hand and by myself once... And that will absolutely positively be the only time I try to do that! One of the top 10 newbie mistakes/lessons: do NOT disconnect from TV until you have leveled from side to side.
    Another newby beware thingy - Chock the T@B wheels or it may roll off the blocks once you unhook and raise or lower the tongue.
    Yes!!! I'm not saying that happened and I'm not sayng it didn't. I'm saying the elation of finally getting it up pales to the disappointment of it immediately rolling off the front. .. Or so I've heard. If that's the only newbie mistakes I make, I will be surprised.
    Don't feel bad, I rolled mine off (hence the chauks) - Luckily it was on fairly level ground or it'd hit some trees.
  • Tabaz Tabaz Member Posts: 2,375
    One thing is nagging me about this mod. When I use the BAL to level the T@B, the weight of the trailer stays on the frame to axle contact point. With this arrangement, the contact point is moved off the axle to the frame with the scissors jacks. Does this introduce any potential bending of the frame?
    Please take time to read the original post for the answer to your question.
    1. Hash  T@B Fun
  • jdargisjdargis Member Posts: 305
    edited November 2016
    Doesn't seem to include the weight of people, walking around on an aluminum floor frame, no longer supported by the trailer suspension.  With different support points on the steel frame, rather than the designed suspension points, the weight of occupants, plus the weight of the trailer is a concern.
    This sounds like a great mod. However I would like the opinion of the folks who build T@Bs.
    Once again the rear support points are designed to support the total weight of the trailer in conjunction with the tongue jack. Even with that engineers would build in at least 20% additional capacity.  I doubt if you would ever be in a position that would put that much weight on the jacking points just to level your trailer but it could handle the load.
    1. Hash  T@B Fun
    Ed says it "should" be OK.
    TACOMAGUY said:
    So now I need 5000 lb. each x 4 scissor jacks over the leveling jacks to be safe at all times, is that correct!!
    I guess I do not understand the question sorry.
    1. Hash  T@B Fun
    Thanks Verna!
    Thanks Verna. I know that many companies would be reluctant to indorse this type of modification because they can not control if the work is done correctly.
    1. Hash  T@B Fun
    TACOMAGUY, Just how many trailers are you trying to level? I also don't understand your statement. :o
    Ok, now you've done it. Jenn is gonna get out her spreadsheets and figure out how many T@Bs can be leveled with 4 levelers at 5000# heft per level.
    For the record I only replaced the two rear ones. There is no need to replace the front because the tongue jack does the front to back lifting. Its easer to level three points  because all the points will be close to equal in weight. Then you could lower the front stabilizers if you wanted to. I have not on our last two outings and things have been very stable.
    1. Hash  T@B Fun
    Stabilizers are rated @ 1700lb each.
    1. Hash  T@B Fun
    Tacomaguy - Typically when refering to BAL, it's a left/right leveling device. Yes, the T@Bs come with four "stabilizer" jacks. They're not meant for lifting but can hold the T@B up if it's jacked up first. Personally I haven't needed anything else. If my bearings need greasing I take it to a shop. If I have a flat I call AAA. I have no need for "jacking". If I do at some point, I can use my TV jack but so far over two years full-timing I haven't needed to.
    PXL, Thanks for the clarification! :)
    BAL also manufacturers the stabilizers, though and you can buy BAL tongue jacks, too.
    edited September 2016
    To clarify, this discussion is about the scissor jacks that happen to be made by BAL.  It appears that Tacomaguy is confused with so many mentioning the other parts that are manufactured by the BAL company.
     (BAL also manufactures the tire leveler which levels side to side, the stock T@B stabilizer as insurance allied by the factory, and other trailer parts.)
    Verna thank you for all of your valuable knowledge and input, but I must respectfully disagree with the comment that stabilizers are not able to hold their rated weight for a long period. In fact they are able to support their rated weight indefinitely. Otherwise they would not be safe at all.
    1. Hash  T@B Fun
    Dale, I bow to your immense wisdom. I'll change my comment. Thank you!
    Ouch!!!!
    1. Hash  T@B Fun
  • ScottGScottG Administrator Posts: 5,572
    Dale, this is a great idea and has really caught my attention as an easy solution to leveling in tight spaces or uneven terrain.
    However, while most comments seem to be about the capacity of the jacks themselves, I'm more concerned about the load point where the jacks are actually attached. It appears this is not actually on the main frame of the camper, but rather on two smaller extensions that protrude backward from the main frame. I think this was the concern that OutbackAZ and jdargis suggested previously.
    I understand that the attachment points are designed to support the weight of the trailer for maintenance purpose. However, dynamic live loads (like people bouncing around on a floor) can increase the total load on a structure several times over.
    Did you do any research to confirm that the smaller frame extensions are adequate to support the weight of the occupied trailer while it is off the suspension? If the T@B frame was wood I could probably figure it out, but steel engineering is a little out of my pay grade!  :-)
    All I can do is suggest you reread all of the posts. If that does not convince you than I would not do this modification.
    1. Hash  T@B Fun
