Frame cracks where tongue bolts to frame
13468912
    The new style front window too? I'm a bit envious...!
    Jenn, why a new axle? You already had replaced with the 'Outback' axle, hadn't you?
    To be honest, I am not sure. They replaced it under warranty. It could be that they deemed it was a bad axle as they told me one tire had worn unevenly.
    @jkjenn, I'm glad they recognized the issue with the axle. That could have caused some major problems down the road (no pun intended) with the uneven tire wear. I'm always in awe, and gratitude when I see nuCamp step up to the plate to take care of issues with their products. Sounds like yet, another pleasant customer experience! Thanks for sharing. :)
    Wow. Impressive.
    ChanW said:
    Wow. Impressive.
    I couldn't agree with you, more.
    Now if NuCamp would find a fix for the rest of us with frame cracks that would be splendid.
    @Normfun and others, yes, the factory is working with Norco, the frame manufacturer. Patience is a virtue......
    @Verna. No worries, I know they are working this issue. NuCamp has shown many times that they are a stellar company. I will attempt to cultivate this “patience virtue” you mentioned.
  • rcuomorcuomo Member Posts: 319
    edited March 2018
    Might not be a bad idea to start documenting which rivet is experiencing most of the cracks.  Seems many frames are seeing cracks at the front lower rivet.
    Huntington LI
    So far they have all been lower front only. All on the driver side. Two or three on both sides. None on passenger side only.
    1. Hash  T@B Fun
  • T@BalongT@Balong Member Posts: 317
    I've heard back from the factory and based on my past experience, I'm confident they will put customer satisfaction and safety first once they have figured out an agreeable plan to address the problem.
    States Visited Map
  • db_cooperdb_cooper Member Posts: 736
    Bump
    Vote to make this thread a Sticky.
    db_cooper said:
    Bump
    Sometimes sticky’s get over looked after time. I would rather
    bump it from time to time to keep it in the forefront. JMHO
    1. Hash  T@B Fun
    I agree with @Dalehelman. How many posts asks questions about how to post photos......look in the announcements.
  • LibrarydragonLibrarydragon Member Posts: 103
    Ours is on the passenger side. That's because Carl and I like to be different.
    Sara&Carl
    2015 max s outback, TV 2011 RAV4, V6, 4x4, & 2017 Tacoma Off-road 4x4
    Soquel, CA
    Picked up the T@b and everything looks great! I will try to take some photos  tomorrow.
    Is it possible to get pictures of the damaged piece after it was  disassembled. I would like to see the backside. Could they tell if the cracks were caused by stress of over tightening, or fractures when the dimple was stamped in?
    1. Hash  T@B Fun
    We would have to see if the factory still has it and I betting they don't. Too big to keep around.
    To bad. I would hope they would examine it to help correct the problem.
    1. Hash  T@B Fun
    I would imagine Norcold, the frame manufacturer, would be the one in a better position to examine the pieces. They would have the expertise and better availability to the correct tools to examine and determine exactly what problem is.
  • CincyKidCincyKid Member Posts: 83
    As an engineer it appears to me that the cracks are propagating from the welds, where poor welding can lead to crack initiation.  Things like poor weld rod quality, inadequate weld prep, poor welding skill, etc. can all give rise to stress concentration risers.  NuCamp definitely needs to comment if this is a safety issue or not and they need to collect data to see if it is related to specific manufacturing dates (operator), etc.
    CincyKid
    Cincinnati, OH
    I don’t see any welds in this area. The  fasteners they used appear to be some sort of a  rivet.
    1. Hash  T@B Fun
    The fasteners are called Huck bolts.  According to Norco they use Huck. Bolts rather than welding on their frames.
    edited March 2018
    Thanks for that. I just checked out a YouTube video. All is clear now. I think I can see how the metal is fracturing.
    https://www.youtube.com/watch?v=4f9BDIST4GM&sns=em
    1. Hash  T@B Fun
  • ScottGScottG Administrator Posts: 5,583
    edited March 2018
    According to my records, jkjenn and Normfun also have cracks limited to the passenger side. I'm up to...
    Four on both sides.
    Three on the passenger side only.
    One on driver's side only.
    Two unspecified.
    My info is based on what I can glean from the comments in this and related threads. It may not be accurate or complete. Corrections and clarifications are welcome!
    edited March 2018
    I'll sift back through the reports and--to the extent that I can determine it from photos and descriptions--will add this information to the spreadsheet.
    EDIT: As Dale noted previously, of the eight for which I can determine a location, the cracks are limited to the lower front rivet/bolt.
    Can anyone verify that Cyclonic's 2012 should be on this list? I know he experienced a catastrophic failure of his aftermarket receiver hitch, but that was T?V related. I can't find any postings verifying any issue with the trailer frame itself.
    edited March 2018
    Cyclonic’s 2012 frame is constructed in a very different way.  It is bent just behind the entry door area so that is continue towards the back. Part of the bend is accomplished by apparently scoring the upper flange with what looks to be a grinder. I have the same frame.
    The 2015 had a totally different method of making this bend without actually bending the frame.
    I do not feel the 2014 or previous frame issues should be included in this count.
    Thanks, Verna. I'll strike Cyclonic's T@B from the record.
    I'm curious though...  Did the different construction result in some sort of frame damage? From what you said it doesn't sound that way, just that the particular construction method employed might look like damage.
