Okay, I know this topic has been discussed many times and in great detail over the years. I don't want to spend hours reviewing all the minutia, but I would appreciate some quick general thoughts and recommendations regarding current battery options.
For the past three seasons I have chugged along nicely with my $90 105aH group 27 flooded cell battery. It still has plenty of life and I anticipate it lasting at least another season as my primary power source, but the battery whisperer in me suggests it's starting to show its age. I'd like to at least consider other options before replacing it with another of the same.
I know there are a dizzying array of great batteries out there, but they will not all work for me. Here are my current criteria:
- I want the battery to remain in the existing plastic tub. I have room for at least a group 27, but there may be room in my battery box to fit one size larger.
- I'd love to consider dual 6V batteries, but I'm almost certain those will not fit in my tub without further modification.
- I want something that can be adequately charged with my current 100W solar panel and stock converter.
- I'm not interested in spending $1000. I'm looking for something a little more mainstream, but would certainly consider upgrading to an AGM or other higher tech battery if it really proves worth the cost.
- Within the above criteria, my highest priority is maximizing amp-hours when dry-camping.
Thanks in advance for any ideas or suggestions!
2013 Tundra TRD 5.7L
Massachusetts
I had dual Interstate 6V golf cart batteries in my T@B S Max that were still going strong after over 3 years.
I do buy from the Interstate dealer as they do have more aH than those carried by the big retail/wholesale outlets. My dealer, Johnathan, has been extremely helpful in lifting the batteries to their final spot.
After having researched online regarding quality and reliability, etc, and finding Trojan and Crown to be highly regarded, I called all around locally for a Crown distributor, to no avail.
I finally contacted the manufacturer via email. The Eastern regional manager got back to me, thoroughly apologizing for not having a distributor in the Buffalo area!
He then offered to arrange trucking, directly to my house, two GC2 6v batteries, at about the same price I'd pay locally for Trojans.
He went on to advise me of 'proper care', ie: be sure to use a hydrometer... Since then I've contacted Crown with a question or two about charging, and they've been very responsive.
So, Crown Battery is highly recommended.
I am heading to the factory in October to convert to a dual battery system. I’m following your advice and I looked up the interstate
Batteries
Do you have any recommendations on how to choose a specific one ? I was thinking more in terms of specifications rather than a model number. I probably will not take the AGM approach
I’m going to go to a local shop to talk to them but would like to have more knowledge before getting there. Any advice would be appreciated
You will be having these wired in series....there’s enough diagrams on the forum to show you what that means. (Yes, I saw you will be having the factory do the work, but it’s always nice to know what youi will end up with.)
https://www.interstatebatteries.com/recreation-vehicles/golf-cart-batteries/extreme-cycle
Also, they have two 6 v Deep Cycle RV batteries with a 225 amp hr rating at 20 hrs. Not sure how they differ from the golf cart batteries.
https://www.interstatebatteries.com/recreation-vehicles/rv-batteries/deep-cycle
They said they have plenty in stock and a few different ones to choose from including a GM. This is going to be easier than I thought
Waiting until just before we go to the factory in October
Brought to places by a 2018 Tacoma TRD Off Road
2022 Ford F350 Tremor | 2022 Cirrus 620
This group 27 SLA/AGM on Amazon is a 100Ah (20 hour rate) battery for a decent price.
Universal Power Group 12v 100Ah SLA/AGM Group 27 Battery
Don’t let them sell you a deep cycle battery for RVs - it’s not the same thing.
You won’t be able to travel with your frig on for any significant distance (as you discovered with your previous battery) and unless you are using solar in good light, you can’t boondock - your frig alone will use about 48 Amp hrs figuring a 50% duty cycle at 4 amps/hr. Plan on stuffing your frig with frozen water bottles and keeping the door closed and turned off.
You don’t know for sure if your Goal Zero solar trickle charger is working, but you can’t recharge your battery with that - it is for maintaining a battery.
Good luck and have fun!
