Alde glycol expansion tank locations for the TaB 320, Clamshell, and 400 models
Sharon_is_SAM
Member Posts: 10,034
(A certain member suggested that we needed an easy to find thread that listed the locations of the expansion tank, so, TADA!)
The TaB Alde heating system debuted starting with the 2014 model year. The glycol expansion tank locations vary by model.Clamshell Models
The CS (no wet bath) model’s tank is located in a cabinet next to the floor A/C unit near the front of the trailer.
The CSS model tank is easily located behind the hatch over the toilet.
320 Models
The early non-clamshell model tanks (2014 to early 2015 model years) are located under the driver’s side rear shelf. Remove the square head screws to lift the shelf and expose the tank.
With the redesign of the rear shelf, beginning with the 2016 model year, the tank in the non-clamshell models is located at the end of the driver’s side rear shelf, behind the triangle-shaped, wood panel. Again, remove the square headed screws and slide the panel towards the front of the trailer to uncover the tank.
New to the 2021 320 S and Clamshell models - the tank is behind a panel under the wet-bath sink. White caps cover the screws holding the panel in place.
The 400 Models
The 400 model tank is in the closet on 400s with the 2-way refrigerator. On 400s with the 3-way refrigerator, it is inside the cubby area to the right of the driver’s side porthole window.
2-way frig model (2018 - 2020 models)
3-way frig model for 2018 - 2020 models and ALL 2021 400 models
7
Thank you for posting this organized summary, @Sharon_is_SAM. Good to have it all in one location for reference, regardless of the model T@B you own.
Greg & Marlene (Tucson, AZ)1 -
I hope it will be a good reference for the inevitable question “Where’s my expansion tank😀”Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
A note about the tab 400 2019 boondock. Two of the screws are located next to the window frame. To remove these you need a right angle ratchet screwdriver no more than 3/4" high including bit and the correct square drive bit. I slotted the panel at those holes when returning the cover so the screws opposite the window frame don't need to be removed again and stay in place.
@Tundra57, the glycol reservoir location in the window is only for those 400’s with the larger fridge and no closet.The 2019 Boondock Lite with closet will have the glycol reservoir in the closet.Verna, Columbus, IN
@Verna. Did not know that, should have specified my exact model. Doesn't change how hard it is to get to. The Nucamp guys are very creative on where to put stuff. @Sharon_is_SAM nice thread. :-). Where the heck did you get all the pictures lol?0
@Tundra57 - the pictures are all from the forum. I like that you can do a specific forum search and when the list of threads comes up, any pictures come up on the right side of the list. You just need to be willing to scroll back a few years:)Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Just bought a 2021 T@B 320S. Cannot find the glycol expansion tank in any of the locations you referenced above. I have run out of places to look.0
OK, per nuCamp Customer Service, the 2021 320 and clamshell model Alde glycol expansion tank is located in the bathroom, on the wall under the sink, behind a white panel that is held on with screws hidden by white, plastic buttons.
Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
Seems like they have finally gone with a consistent location for both models.Sharon_is_SAM said:OK, per nuCamp Customer Service, the 2021 320 and clamshell model Alde glycol expansion tank is located in the bathroom, on the wall under the sink, behind a white panel that is held on with 4 white, plastic buttons.
I found it. I will try and post a picture tomorrow.2
@ScottG ...it definitely will make nuCamp's build easier to have the same locations.. it appears they are using the same front cabinetry for both models too..except 1 opening is used for a fridge..Former 2017 T@G Max XL
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada1 -
Standardization will also simplify and make for less co fusion when helping new owners.ontheroad said:@ScottG ...it definitely will make nuCamp's build easier to have the same locations.. it appears they are using the same front cabinetry for both models too..except 1 opening is used for a fridge..2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
2 -
On all the 2021 TaB400 models, the Glycol tank is in the front dinette location shown for the 3-way fridge option. The glycol tank is no longer in the closet on this option model.
cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.1 -
Thank you @Denny16. I edited the 400 model titles to reflect this change.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
No worries, thanks.
This is a beautiful page, I wish I had found it earlier. You should have seen the amount of time I searched for the one in my 2017 T@b! And it is hard to access. I am now in the PNW and it is very hard for me to find someone to do a flush and fill. It it beyond my skill set, and I do not have a flush pump. Still trying to figure it out.2017 T@b Outback. Now towed by VW Touareg. Drove from FL to OR.0
Do a search on the forum. There are owners who have completed the exchange without a hassle. Good enough for the factory, good enough for me!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Hello all. So, I had to laugh -- thanks to this thread I now know where the tank is in my new 2020 T@B 320, but "remove the square head screws" isn't that easy -- not exactly standard! So... have ordered appropriate driver (I hope... it is a #0, right?). I am having a hard time imagining that others check the glycol level very often -- and sure do understand why the tank was moved in 2021! By the way, absolutely loving my T@B... And I am being required to get a bit smarter every day!
Yanni Lazarus 2020 T@B320S, 2018 RAV4 Adventure, Central CT1 -
@YanniLazarus, it is a #1 on my 2019 320S (I am not sure if nuCamp changed it on the 2020 model.) It sounds like you already ordered a driver and/or bits, but I would recommend that you get something that has at least sizes 0, 1, 2 and 3. I have used both the #1 and #2 on my trailer.
We have gotten by with the #1 and #2 driver.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio2
there are a few finish screws that use a no.0 driver, but these are not normally removed.
cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.2 -
Yes, this is super helpful. Our 2015 Little guy wasn't hard to find once we new to look in the farthest back corner on the drivers side under a board. Now, if they had only left a bit of a window to see the level it would really be easy but my husband was able to see it well enough! THANKS to all for your help. K
2015 Tab S with Alde0 -
@KAR, I always found a headlamp came in handy when checking the glycol. If you can’t tell by the marks on the outside of the reservoir, the headlamp shining inside the reservoir definitely made it easier to see.Verna, Columbus, IN
I have newly acquired a 2018 T@B 320S. Found the expansion tank (thank you @Sharon_is_SAM) and added glycol as directed. My problem is I am awful with screws, I don't know why, LOL. I managed to get them out (yes, we have Robertson (square) bits), but had trouble lining up the existing holes when putting the cover back on the compartment.
Has anyone found a way to modify that cover with some sort of clip or something, rather than the screws? Seems if the cover needs to be removed frequently that there should be a more user friendly way to do it.2018 T@B 320 S Boondock | 2015.5 Volvo XC60 T6 AWD | Seattle, WA, USA
"Blessed are the curious, for they shall have adventures.”― Lovelle Drachman0 -
Thank you for this! I was beginning to think they *missed* putting an expansion tank in our 2021 320S BD. Before we open that panel to confirm it's there and it's full, do people use a flathead screwdriver to pop off those white screw caps?
Editorializing: IMO, they make this pretty hard to get at if we're supposed to check often. Also, our dealer should've done a better walk-thru, so we'd know about this and probably 20 other things.1 -
@Ping, I use the blade of my pocket knife to pop off the caps (keep track of them!), or a smaller flat blade screwdriver would work just fine.I have plans of inserting a cargo door in the plastic so I can have extra dry bathroom storage and so I can easily see what the level of the glycol is. I’ll post photos when completed.Verna, Columbus, IN
2023 400 Expansion tank location. From a FB post today."Should be inside the front porthole- dinette area on the drivers side."
Towed by 2014 Touareg TDi2 -
@pthomas745 - is that the same as the 2021 and 2022 model? I will update the above list if so.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Now I see the picture up higher in the thread! I should never post before coffee! I'll delete my comment and picture later!
After checking mine a couple times on my 2021 T@B 320 I decided there must be an easier way to give the tank level a quick check besides removing screws every time. Installing a 6" marine port in the panel did the trick.
6" Marine Port: https://amzn.to/3OZl1cA
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York3
- 422 Service/Maintenance & Recall Notices
