Haven't you heard? PXL would "melt" if he had a regularly scheduled life! Just kidding - but the guy sure knows how to fly by the seat of his pants - and seems very lucky at scoring camping spots that way!marknjudy said:Nice!!! Now back to your regularly scheduled life. Very happy to hear it.
PXLated said:Ok, got the fridge working - new circuit board... $175-Board, $50-Labor, $75-OvernightAir = $300 + $125 for the thermocouple/labor with the first service guy.
More when I've got a better connection.
PXLated said:Jenn - Was gettin flame and green light while the red button was pressed. Release the button and poof, gone.
Thanks! By cover - you mean the cover the left of the fridge, right? It might be a good excuse to use my endoscope.PXLated said:Jenn - If you take the left cover off and get down low and right you can see the flame thru a little glass window - the one Ratkitty had to reinstall - if it's nice, full and blue it should be ok.
Man, I thought of your endoscope while I was re-installing that sucker!! Geeeesh. Sure wished I had it!! LOL.jkjenn said:Thanks! By cover - you mean the cover the left of the fridge, right? It might be a good excuse to use my endoscope.PXLated said:Jenn - If you take the left cover off and get down low and right you can see the flame thru a little glass window - the one Ratkitty had to reinstall - if it's nice, full and blue it should be ok.
-- your diagnosis might have been pretty much on the mark!
So if you don't want to take anything apart you just need three more people to help you flip your T@B.irvingj said:Chan, years ago when I was in the HVAC business, I had heard stories about absorption systems -- "if they quit for no apparent reason, try this first: turn 'em upside down for a few minutes and then turn 'em right side up and re-try."
I wish that would have happen. Unfortunately, it persisted all summer.ChanW said:jenn
I'm pretty sure the green light only indicates (ie: is only on if) when the flame is lit.
We had the problem a couple of times, of the green light on, and the cooling having stopped. There was no clicking, and the counter was still warm, so I'd say the flame was still going.
All I could guess is that the refrigerant had been overheated, or somehow got an 'airlock' in there or something, so the absorption cycle had got out-of-whack.
After letting it cool down, and re-starting it, it was fine again.
I have read about this. It might be part of the issue. I believe you can just pull the fridge and lay it on its side for 30-60 minutes.irvingj said:Chan, years ago when I was in the HVAC business, I had heard stories about absorption systems -- "if they quit for no apparent reason, try this first: turn 'em upside down for a few minutes and then turn 'em right side up and re-try."
Seems sometimes the brine does get semi-permanently separated, the liquid part from the gaseous (used to be ammonia) part. Sounds like --and I'm certainly no expert on these systems-- your diagnosis might have been pretty much on the mark!
Me, back then I stuck with good, old-fashioned, reciprocating compressor R-12, 22, and 502 systems. (Pretty much outlawed now....)
Mine isn't on permanently, just when light it. I am going to see if there is a flame lit and check the color of the flame.FuzzyYanni said:If you disconnect the negative voltage to the indicator lamp but leave the positive connection on, the light will be on with no flame,
So it is possible to have the green light stay on permanently. Obviously it doesn't indicate flame present in this case.
The user service manual has the specifics on page 14:
"If the negative DC supply connection is lost, the flame indicator light will remain on all the time, even withoutthe flame present."
