Looking for some thoughts on a mystery with my 2020 320s Boondock's Norcold fridge. At home when I'm hooked up to shore power the fridge works great. When I get to the campsite and hook up to electric, it stops. Second time at a campground this past month and the same thing happened; this last time a maintenance guy changed out the receptacle on the outlet for the site, and still doesn't work. I've called Nucamp and they don't have any ideas. I've flipped the breakers on and off at the power source and in the camper. I also can't get it to run on propane; propane is turned on, set to "propane", needle is in the green zone. I hate to have to take it back to the dealer (1.5 hours away). I'm also having weird things with the electric outlet at the rear on "passenger" side. It is not always functioning. This is my first time with a camper so lots of trial and error. I just find it hard to believe that the fridge is broken, when it works great at home. Would love to hear the experienced owner's thoughts here! TIA.
2020 Tab 320S BE "Moonbeam"
2019 Toyota Tacoma
Asheville, NC
"Don't postpone joy!"
0 ·
Basics for the 3 way on propane include opening the LPG tank very slowly, lighting the stove first making sure that air is out of the propane lines, keeping the TaB level.
Have you searched on tips for operating the 3-way frig?
https://tab-rv.vanillacommunity.com/discussion/7717/norcold-3163-3-way-refrigerator-wont-start-on-propane-what-fixed-mine-general-diagnostic-advice
https://tab-rv.vanillacommunity.com/discussion/comment/109178#Comment_109178
Do you have a surge protector similar to this to check the outlets?
Camco Analzyer 55312 Circuit Analyzer Dogbone 30 Amp
Tampa FL
Sorry if you already know all this, but I thought it could not hurt to review, especially as you said this is your first RV.
nüCamp: 2019 T@B 400 Boondock Lite
When the camper is plugged into 120V shore power, two things should happen:
- 120V is supplied to the outlets (including those to which appliances like the fridge and Alde are connected; and...
- 120V is supplied to the converter, which in turn supplies 12V to power the lights, fan, water pump, and various electronics.
I mention the 12V because even when things are running on 120V AC (i.e., shore power), devices like the fridge and Alde still require 12V from the converter in order to run. (The same applies to using propane.) In short, both power supplies must be functioning for things to work.Of course, this doesn't help you much, as things should work the same hooked up at a campground as they do at home. However, being aware that both 120V and 12v power are required may help in your troubleshooting. Good luck and please let us know what you figure out.
It's happened at three different campgrounds now. The time before last, the receptacle to replaced and still no-go. When I get home from this current trip I'll hook it up to the home power source again and it will be the true test! I'm just going to bet it works great again. I'll def do an update later this week when I get back home.
The A/C is working great btw; that was something I was asked by someone else (if the AC wasn't working, the fridge wouldn't be working either).
(Edited AC to A/C for clarity - Sharon)
2019 Toyota Tacoma
Asheville, NC
2019 Toyota Tacoma
Asheville, NC
2019 Toyota Tacoma
Asheville, NC
I'm reading the post on the 3 way gas ignition link you gave me... omg, so much technical info. My brain isn't "wired" to comprehend all of it! but I'll try and slog through it. So much helpful into there, if I can just untangle it all.
2019 Toyota Tacoma
Asheville, NC
a 110/120VAC plug-in in circuit tester, to see if camp outlets are first, working, second wired correctly, and no ground fault. Something like this is inexpensive and quick to use: https://www.staples.com/Ideal-GFI-Receptacle-Tester/product_196965?cid=PS:GooglePLAs:196965&ci_src=17588969&ci_sku=196965&KPID=196965&gclid=CjwKCAjw4rf6BRAvEiwAn2Q76vWwJ0ktpzGq8vJfNYmyRbF89Z5KZtvPH8Ek8glP2EwZo6BHpeSf4RoCrUIQAvD_BwE
- - - Does the fridge Front Panel green 'AC plug' lamp turn on? If not then that points to loose connection.
- - - Does rear 120VAC outlet not work the same time the fridge 'AC plug' lamp does not work?
For issue [B] and maybe [A]. On [B] the fridge front panel 'red line in green' indicates the Fridge is burning propane. So how long do you wait to decide the Fridge is not cooling. Depending on starting temperature it can take hours for Fridge to cool. Plus on propane how fast & cold depends on how high the propane flame is set.
Thought being;
Fridge on 120VAC at home and cold, turn fridge off and drive to campground say 2 hours, Fridge inside temperature will rise 15-20F (or more), at campground turn on propane, depending on flame setting fridge could take an hour or more to drop 5+ degrees.
How Soon Do You Say It's Not Cold?
Do you have a thermometer in Fridge?
Does anything else (regardless of whether it is 120V or 12V) not work?
I'm back in my driveway at home tomorrow night and I'll hook it back up to the outlet I've been using and see if it's cooling. I'll post an update when I do that. Thanks again everyone.
2019 Toyota Tacoma
Asheville, NC
MuttonChops asked an important question..
"So how long do you wait to decide the Fridge is not cooling. Depending on starting temperature it can take hours for Fridge to cool."
What's your answer?
Many of us leave it turned on overnight to get it cold before leaving, then pack it with frozen water bottles etc while traveling with it turned off. If you're only turning it on when you arrive at the campground & not pre-chilling, maybe you're not giving it enough time to cool down after plugging in & turning on.
BUT! News to report!! I came back to my campsite tonight and tried hooking up to the 50 amp outlet, with my 50 amp converter thing, and VOILA. It is working!!! So, at this point I don't know what to think. At home, I'm not plugged into 50 amp. But those couple of campsites I've been to that only had 50amp service, I guess I was getting juice to the fridge. If it was the 30amp power cord, then it wouldn't work at home, right? Hopefully this will be a good clue for all the wonderful sleuths here. I have zero idea of what the issue is. Glad it's working though. So my 2020 tab 320s isn't 50 amp, right? Isn't it 30 amp? Why would the AC work with the 30 amp, but not the fridge...
2019 Toyota Tacoma
Asheville, NC
2019 Toyota Tacoma
Asheville, NC
Another thing to consider is “what you have in your frig and is it packed up with food?” The 3 way frig does need to have air circulating within it to be efficient and if things are jammed in tightly this could create problems with the unit cooling efficiently and maintaining adequate temperature to keep food fresh and from spoiling. These units can be finicky and in hotter temperatures they can be less efficient and can struggle to keep things cold. My frig actually performed best on propane and there is a difference if you have it sitting in the driveway unpacked and at the campground with a full load of food.
So, You are not experiencing what you believe to be happening Or there is an intermittent part or connection that is causing this abnormal operation. With recently reported by owners (non-official) reduced manufacturing quality at NüCamp as the factory size and production rate have grown . . . it's most likely a poor connection, which can be a real pain to isolate.
And does that rear outlet work when the fridge is working?
This is not an easy (or cheap) problem to fix because, first, you need to convince the dealer that he has to plug into a GFCI protected outlet even to discover the problem. Most service bays have 50 amp and the dealer, like you, just uses a dogbone whenever he needs power. If he does that, he’ll simply say it works fine for us and you’ll be out of luck getting a diagnosis.
Second, if you can get the dealer to plug into a GFCI protected outlet and trip the breaker, isolating the fault will take some time. He has to deenergize every circuit and reenergize each one (one by one) until he finds the circuit with the fault. Once he does that, he might not even be able to identify exactly where the fault is occurring (or access It easily) and will have to run a bypass. It’s not a cheap fix if you are out of warranty.
Three things you can do to confirm the problem and work around it while you ponder your options. (1) You can continue to use a dogbone on 50 amp service. None of the 50 amp sockets are GFCI protected from what I’ve seen. (2) You can look around for 30 amp service that is not GFCI protected. This can be easy or hard, depending on where you live or travel. Federal parks don’t seem to use GFCI protection on 30 amp. But some state parks systems, like those in the Illinois, use GFCI on 30 amp service almost exclusively.
There is a third option, but it’s potentially dangerous and you should use it only if you have a dire emergency and need power to run something like a medical device. Take a 20 amp to 30 amp dogbone and use a pair of pliers to pull out the neutral pin. It’ll work, because there’s no neutral going back to the GFCI breaker making the neutral to ground fault in your trailer’s electrical system irrelevant, but YOU might become the ground if you touch something on the frame of the trailer. Then you need to hope the GFCI works as intended because it will immediately pop the breaker and cut AC power.
This problem is more common than you would think. I actually learned the dogbone trick from a camp host in Illinois who sees it occasionally and keeps a couple of these MacGyvered 20 to 30 amp dogbones on hand. But the problem often goes undiscovered even if present if you are lucky enough to always use 50 amp service or 30 amp service that has no GFCI protection.
I hope your issue isn’t what I think it is. It’s frustrating and expensive to remedy. But it sounds very familiar. . . .
2019 Toyota Tacoma
Asheville, NC
2019 Toyota Tacoma
Asheville, NC
2019 Toyota Tacoma
Asheville, NC
2019 Toyota Tacoma
Asheville, NC
2019 Toyota Tacoma
Asheville, NC
This is not a simple matter of the fridge not working. Something with regard to the power supply is different when you plug in at home vs a 30A campground outlet vs a 50A campground outlet at the same site. The most likely variables are:
- Having the battery on some times and off others (already ruled out).
- Failure to turn on the breaker at the campground outlet (which you clearly said you did).
- A bad campground outlet (not likely since the problem occurs in multiple places).
- Using different trailer cords or different adapters--one of which may be faulty. (Any chance this is the problem?)
- An intermittent short or open circuit (but those generally don't follow predictable patterns).
I remain stumped...
